Another boler frame off... - Page 2 - Fiberglass RV
Old 06-14-2009, 03:18 PM   #15
Trailer: 1977 Boler
Still plugging away and have made lots of progress over the spring but unfortunately never made the Fort with the trailer.
I installed a stainless steel countertop with a Smev sink/cook top combo, new engineered flooring, repainted the benches, closet etc, retaped the seams, installed a power converter, 110 GFI outlet inside and one outside by the door.
I decided not to use a range hood and instead mounted 3 flush pot lights under the cabinet along with a 12 volt rv unit from Princess Auto plus 2 more either side of the closet. Rewired the running lights and 110/12 volt circuits. Installed a new faucet assy, plumbed for water and gas so the kitchen is now up and running. Modified the cooktop for electronic lighter thanks to previous posts on this forum.
I just have some interior trimming to complete and a 12 volt water pump to work out/install before the end of the month. I ordered a Shademaker awning this morning and need to make a upper bunk to complete the inside. Hope to clean up the outside and paint early July.
RogerH is offline   Reply With Quote
Old 06-14-2009, 06:36 PM   #16
Trailer: 1977 Boler
A couple more interior pictures.
Old 06-16-2009, 08:33 PM   #17
Don N's Avatar
Trailer: 1989 Bigfoot 17'
Very nice reno Robert. Looks real good. Just curious if you had trouble with the handle on the tongue jack interferring with the battery box? Look pretty close together to me.
Don N is offline   Reply With Quote
Old 06-16-2009, 08:55 PM   #18
Trailer: 1977 Boler
No problem what so ever with clearance.
Old 06-16-2009, 09:18 PM   #19
Don N's Avatar
Really like the cook top Roger. Found one on ebay from Aery Corp, Model # Mo911 for $135. U.S. Is this the one you used and which igniter did you add to it? You buy it from there or is there a supplier in Canada? Presume any faucet will work. My Boler had a larger stove with oven installed in it but I am thinking I would like this unit and put a micro wave in where the oven sat.
Thanks..Don
Old 06-16-2009, 09:59 PM   #20
Trailer: 1977 Boler
Thanks..Don
I bought it on eBay from the Aery corp but it was an auction he occasionaly has for $81.00. I think the one for $135 has the igniter installed. Very slow to ship and no communication from seller so be prepared for this if you buy. Really nice unit and gives me a foot of extra counterspace at the table end plus space between the unit and back splash. The ignitor is from Walmart, $15.00 , and installed it fairly easily. Faucet was on sale last week at Canadian Tire. The only challenge was the stainless countertop as it is tough to drill and cut.
Old 06-17-2009, 03:54 PM   #21
Don N's Avatar
Thanks Roger. I will keep an eye on his auctions. I can see where it will free up a lot of counter space. More than likely a job for later in the year along with a new counter top. No problems hooking up the water or propane to the unit?
Old 06-18-2009, 06:38 AM   #22
Trailer: 1977 Boler
I modified the regulator location by moving it to the back. The drain was fairly straight forward and I used a piece of 5/8 diswasher tubing. It did not come with a drain assy but they are available at an RV parts dealer plus Home Depot has the abs fittings.
boler
Boler #2 frame off RogerH Modifications, Alterations and Updates 18 04-28-2010 06:05 PM
For those who've removed the frame from a Boler 13 RussL Problem Solving | Owners Helping Owners 5 10-21-2009 05:31 PM
Change my Boler frame Jayson Wall Problem Solving | Owners Helping Owners 0 05-12-2009 06:57 PM
New Frame for a Boler Cheryl Lee Problem Solving | Owners Helping Owners 2 01-28-2008 09:13 AM
Boler Frame RobJ Modifications, Alterations and Updates 6 03-19-2007 03:16 PM
