Another boler frame off... - Fiberglass RV
Old 04-08-2009, 10:29 PM   #1
Trailer: 1977 Boler
Newbie from BC here working on cleaning up an egg for the summer vacation. One thing led to another and figured it was easier to fix it right the first time. 1972 fairly abused Boler that I picked up last month in need of some freshening up. After some rust repairs and a quick paint, it should be back on its frame tomorrow.
I read a number of posts regarding the bolts/screws that hold them together. I helped a neighbor with his late 80`s model, and found out the earlier ones sure have a lot more rusted, hard to get out screws!!
I have some engineered flooring to install, clean up and repair the cabinets, benches etc., rewire, replace the side windows and several other list items. Seems like everytime I view the other mods and alterations on this forum, the list gets longer.
Not sure if I will make the weekend in Fort Langley but will see how things progress and still need to get the tow vehicle, a 55 Chevy pickup, sorted out as well.
RogerH is offline   Reply With Quote
Old 04-09-2009, 04:34 AM   #2
Don N's Avatar
Trailer: 1978 Boler 1700
Good start Roger. It will go back together faster than you think. I did it to my Trillium in Feb. Love the truck (gearhead here)...original V8 or 6 cyl truck?
Don N is offline   Reply With Quote
Old 04-09-2009, 09:43 AM   #3
Trailer: 1977 Boler
Truck is fairly original besides the paint and still has it`s 6 cylinder 3 on the tree powertrain.
Roger
Old 04-09-2009, 09:55 AM   #4
Trailer: U-Haul CT13 ('Pearl')
Rodger,
How much did the shell weigh?
Pat B Ohio is offline   Reply With Quote
Old 04-09-2009, 12:23 PM   #5
Trailer: 1977 Boler
Rodger,
I am not sure as we used an automotive jack to lift with 4x4 beams for support.
Old 04-09-2009, 10:17 PM   #6
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
ROGER!!!
BRING THE TRUCK,
Bring The Truck,
bring the truck!
Come talk with the rest of us Eggers at the Fort (best time is Saturday).
I know of no fewer than 3 frame off Boler restos going on right now in M'Ridge.
I don't know IF any of them know of our board here, let alone the twice yearly GEM (Glass Egg Meet) at the Fort.
Old 04-09-2009, 10:57 PM   #7
Trailer: 1977 Boler
ROGER!!!
BRING THE TRUCK,
Bring The Truck,
bring the truck!
Mated the frame with the body this evening with a fellow Boler owner who will be there that weekend and the person I was going to share a site with. Either way we will be there dragging a project or not.
Roger
Old 04-10-2009, 09:03 AM   #8
Doug Mager's Avatar
Lookin forward to meeting ya....
Old 04-13-2009, 10:43 PM   #9
Trailer: 1977 Boler
Rodger,
I had 3 neighbors and myself do the lifting and a 4th slid the frame in place. It was an easy lift so suspect it does not weigh too much.
Old 04-22-2009, 03:58 PM   #10
Trailer: 1977 Boler
Windows are finally in after 2 days of fiberglassing the corners and sanding to contour. Corners will get color when I paint the rest of the body. On to the benches, closet, kitchen and overhead cabinet in order to make the Fort.
Old 04-22-2009, 04:09 PM   #11
Trailer: 1977 Boler
Some pictures of the frame after sandblasting, paint and welding the new battery box holder. Also replaced the lino with engineered flooring.
Old 04-22-2009, 07:25 PM   #12
Roy in TO's Avatar
Looking good!
Old 04-22-2009, 08:30 PM   #13
james kent's Avatar
Trailer: Boler 1984
Things are looking good.
Did you beef that pretty frame up any?
Old 04-23-2009, 09:43 AM   #14
Trailer: 1977 Boler
No real need to as it was in good shape with no cracks. I added some metal to the lower floor perimeter as it had rusted through. Also added an "A" frame coupler as mine was bent.
Old 06-14-2009, 03:18 PM   #15
Trailer: 1977 Boler
Still plugging away and have made lots of progress over the spring but unfortunately never made the Fort with the trailer.
I installed a stainless steel countertop with a Smev sink/cook top combo, new engineered flooring, repainted the benches, closet etc, retaped the seams, installed a power converter, 110 GFI outlet inside and one outside by the door.
I decided not to use a range hood and instead mounted 3 flush pot lights under the cabinet along with a 12 volt rv unit from Princess Auto plus 2 more either side of the closet. Rewired the running lights and 110/12 volt circuits. Installed a new faucet assy, plumbed for water and gas so the kitchen is now up and running. Modified the cooktop for electronic lighter thanks to previous posts on this forum.
I just have some interior trimming to complete and a 12 volt water pump to work out/install before the end of the month. I ordered a Shademaker awning this morning and need to make a upper bunk to complete the inside. Hope to clean up the outside and paint early July.
Old 06-14-2009, 06:36 PM   #16
Trailer: 1977 Boler
A couple more interior pictures.
Old 06-16-2009, 08:33 PM   #17
Don N's Avatar
Very nice reno Robert. Looks real good. Just curious if you had trouble with the handle on the tongue jack interferring with the battery box? Look pretty close together to me.
Old 06-16-2009, 08:55 PM   #18
Trailer: 1977 Boler
No problem what so ever with clearance.
Old 06-16-2009, 09:18 PM   #19
Don N's Avatar
Really like the cook top Roger. Found one on ebay from Aery Corp, Model # Mo911 for $135. U.S. Is this the one you used and which igniter did you add to it? You buy it from there or is there a supplier in Canada? Presume any faucet will work. My Boler had a larger stove with oven installed in it but I am thinking I would like this unit and put a micro wave in where the oven sat.
Thanks..Don
Old 06-16-2009, 09:59 PM   #20
Trailer: 1977 Boler
Thanks..Don
I bought it on eBay from the Aery corp but it was an auction he occasionaly has for $81.00. I think the one for $135 has the igniter installed. Very slow to ship and no communication from seller so be prepared for this if you buy. Really nice unit and gives me a foot of extra counterspace at the table end plus space between the unit and back splash. The ignitor is from Walmart, $15.00 , and installed it fairly easily. Faucet was on sale last week at Canadian Tire. The only challenge was the stainless countertop as it is tough to drill and cut.
boler
Boler #2 frame off RogerH Modifications, Alterations and Updates 18 04-28-2010 06:05 PM
For those who've removed the frame from a Boler 13 RussL Problem Solving | Owners Helping Owners 5 10-21-2009 05:31 PM
Change my Boler frame Jayson Wall Problem Solving | Owners Helping Owners 0 05-12-2009 06:57 PM
New Frame for a Boler Cheryl Lee Problem Solving | Owners Helping Owners 2 01-28-2008 10:13 AM
Boler Frame RobJ Modifications, Alterations and Updates 6 03-19-2007 03:16 PM
