Antenna question - Fiberglass RV
Old 10-14-2018, 11:32 AM   #1
Trailer: Currently Shopping
Antenna question
I am planning to keep the 16' SD 2005 model in the garage I am sure if I will drop the camper on a wheel dolly, without tires, it will clear off the distance and will go through the 83" tall garage door. The only problem is the antenna. Is anyone ever removed it?
Atti is offline   Reply With Quote
Old 10-14-2018, 12:01 PM   #2
Trailer: 2008 Casita 17 SD
Have you thought about remounting it on some kind of a rotatable mount, so it can be loosened and rotated downward horizontally?
Old 10-14-2018, 02:01 PM   #3
Honestly i didn't climb up there enough to see how it is mounted. The rotating mount with a quick connection would be perfect solution, but i think this setup goes through the sealing... That little adjustable arm on the sealing i think should be open the antenna up, not sure, I have to find out more how was this thing installed
Old 10-14-2018, 02:39 PM   #4
Ok, here is the antenna. Any idea how to remove this, and if it was removed what can I do with the hole?
Old 10-14-2018, 04:33 PM   #5
John in Santa Cruz's Avatar
Trailer: 2014 Escape 21, 2002 Ford F250 7.3 Diesel 4x4
I'd consider replacing it with something like this, that folds flat when not in use.
https://www.amazon.com/Winegard-RVW-.../dp/B003VAZ6OG
specs say that one is 4" high when folded down, I dunno if thats adequate for your clearance.
Winegard Sensar RV TV Antenna
Old 10-14-2018, 05:37 PM   #6
Inside: Rotate the inner and outer knob to align the slots to undo the allen setscrew holding the knobs on the shaft. It takes a long shaft smaller allen wrench to remove the set screw. (The allen wrench needed is a 3/32")
Outside: Remove the RF cable. Remove sealant that should expose 8 rivets or screws to be removed. Then you should be able remove the antenna. You will need a to make a 6" diameter cover plate to cover the holes in your roof. I made mine out of 3/16 aluminum. In my trailer documents was a manual on the antenna which had a template, or you could make a template from the antenna base. Then reattach your cover plate and seal.
Your antenna is a Delta which is no longer made and seals for it are unavailable. I would select another antenna for use on a removable mast.
Eddie
Old 10-14-2018, 07:50 PM   #7
Instructions for removal.
1. take screws loose until it is off.
Reinstallation.
Reverse #1
Old 10-15-2018, 07:04 AM   #8
Trailer: 2018 Casita Independence
I went with this antenna an I'm totally happy with it, very versatile and works in an direction. Yes it is portable and is all carried in a small caring case, look for YouTube videos on this product. https://www.ebay.com/itm/KING-OmniGo...jEvH:rk:3:pf:0
trainman
trainman is offline   Reply With Quote
Another TV Antenna Question/Puzzle dmad1 Problem Solving | Owners Helping Owners 2 05-29-2017 01:25 PM
TV antenna question for owners of any brand of trailer rgrugg Care and Feeding of Molded Fiberglass Trailers 12 10-16-2013 03:52 PM
Antenna Question Chris C Problem Solving | Owners Helping Owners 31 03-11-2008 11:05 AM
boomerang antenna question Legacy Posts Problem Solving | Owners Helping Owners 5 03-09-2003 05:07 AM
TV Antenna with Amplifier Question Legacy Posts Problem Solving | Owners Helping Owners 9 11-30-2002 04:05 PM
