Any wall/ceiling carpet mods? Cover over carpet? - Fiberglass RV
Old 01-10-2019, 11:11 AM   #1
Trailer: Casita 13'
Hi, Im sure this has been talked about but I'm wanting to cover the walls with thin flexible wood or thin fiberglass sheeting. Anyone out there have an ideas or pictures?
Thanks in advance
-Ryan
mr_barbershop is offline   Reply With Quote
Old 01-10-2019, 12:59 PM   #2
Trailer: Casita 13'
Pics Ive found. Maybe from this forum.
3791B037-A3CB-4274-A3C4-F55F6011BF96.jpeg   CE99B6E4-CC94-47D4-B1A1-740EFE35A665.jpeg
Old 01-10-2019, 08:01 PM   #3
Seaross's Avatar
Trailer: Trillium 4500
I replaced the ensolite with reflective alum bubble foil and car material headliner for interior and for bathroom I used bubble foil and vinyl paneling. Here is my link to caddy shack site. https://www.facebook.com/17869471268...9056220982965/
Seaross is offline   Reply With Quote
Old 01-10-2019, 08:54 PM   #4
One of the best mods on the walls I have made on the 16' Scamp was bolsters or pads along the side of the bed(s). I used some quilted fabric with batting and several layers of Reflectex glued together for stiffening it up to provide extra insulation in the cold weather.
If I had it to do over I would make it taller and thicker
Old 01-11-2019, 07:11 AM   #5
Trailer: Casita 13'
Attachment 127200
Thanks Seaross looks great!!
Old 01-11-2019, 07:13 AM   #6
Trailer: Casita 13'
Thats the main reason why I'm doing this. I don't like breathing into the carpet when I'm laying down. Along the bed walls and bunk bed is my main concern. Thank you for sharing
Old 01-11-2019, 08:28 AM   #7
Hmmm... Ive never had my face close enough to the carpet-like marine headliner in my Scamp to feel like I was breathing into it. I usually sleep on the small lower front bunk of our Scamp.
One thing that does happen frequently is I brush against it with my hand or leg. Personally Id rather brush against warm carpet than a cool, smooth surface.
Old 01-11-2019, 12:30 PM   #8
I like the quilted look and feel. With the "Rat Fur" or carpet you could attach with velcro hook side.
I used spray on glue to hold mine.
I thought I would be higher, but the bosters go down to the bed base and the mattress is a WalMart 8" foam cut down to fit.
If I had it to do again I would go to the trouble to fit it around the windows to make it higher. My experience is when it is cold this helps with the Ensolite being pretty cold.
I have also found that from time to time the dark color shows if there is a leak from a window to find.
(Fixed the leaky window).
I used some cardboard to cut a template and added layers of Reflectex to build thickness and insulation and then covered with a quilted quilt cut to fit.
A worthwhile addition and the Wife agrees.
I would consider using thin foam instead of the Refletex as the product does not really provide a lot of insulating effect it it is in contact with another surface.
That is why I call BS on the insulation claims of the manufacturers.
Old 01-27-2019, 07:52 PM   #9
Louisiana
Grass Cloth for interior covering
My 83 Scamp was beyond nasty so I gutted the entire interior. I glued Reflextics from Lowes on the inside of the shell and then glued Grass Cloth Wallpaper over that (I disliked the rat fur).
In the corners I cut it into small strips and radius it out. Not perfect by looks cool!
8DF94AA0-F726-4783-BB70-DBE711BA6DCE.jpg   C50F3D44-5E43-407A-8237-714555B33D58.jpg
Altemplet is offline   Reply With Quote
Old 01-28-2019, 12:10 AM   #10
A cool slick surface will encourage condensation. If you like water dripping on your face, well to each their own.
Old 01-28-2019, 12:30 AM   #11
How do you spell balderdash?
Old 02-24-2019, 11:58 AM   #12
Trailer: Trails West Campster
What glue did you all use on these projects? my camper has nothing on the walls, I bought it this way and need some ideas.
AstroMark is offline   Reply With Quote
Old 02-24-2019, 03:28 PM   #13
Louisiana
I used 3M heavy duty spray adhesive first to glue the Reflextics everywhere and then the grasscloth on top of the Reflextics.
Old 02-24-2019, 06:41 PM   #14
Thank you
Replacing wall/ceiling carpet in Casita Spirit (not deluxe) Joanie R Modifications, Alterations and Updates 13 01-10-2019 06:59 PM
How should I clean wall and ceiling carpet? Stavig Care and Feeding of Molded Fiberglass Trailers 13 06-04-2017 09:29 AM
Carpeting On The Wall & Ceiling? Cathy P. General Chat 9 02-18-2007 08:47 PM
fishing wires behind Scamp's ceiling carpet Legacy Posts Electrical | Charging, Systems, Solar and Generators 6 07-11-2003 10:18 AM
