Originally Posted by Timber Wolf
Thanks for posting that Carol, it is very interesting. I tow with a full size pickup so would be inclined to toss it in the back of the truck though. I just had the thought that the blue tote could of course be used both for Black and Grey waste as the need arose. I will have to look around for one just the right size/capacity.
Mine also stays tucked away on its side up against the front of the box of my truck - doesn't take up much room.
Yes it can indeed be used for draining off both the grey or black water. They do have in addition to the garden hose attachment that works well for draining off water only an attachment for the larger slinky hose for using with the black tank. If your going to use it often to drain the black water tank you might find it easier to use if you cut down an old slinky hose with end fittings to about 2' in length to use with the portable tote.
