attach scissor jack to a stainless steel plate - Page 2 - Fiberglass RV
Old 05-13-2016, 08:58 AM   #15
Thank you ALL for your comments/suggestions.
Clif's point about "side to side sway" convinces me to think again if I should use these scissor jacks at all. Darral's $0.04 most likely is in US, is about 6 cents in Canadian, I'll take it
HawkBoler72 is offline   Reply With Quote
Old 05-13-2016, 09:04 AM   #16
Good decision. It seemed like you were trying to go through a lot of work because you got some SS cheap. I would worry about metal galling because of using two totally different metals. You may have ended up damaging the frame trying to save a few bucks.
Old 05-13-2016, 01:37 PM   #17
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Originally Posted by The Minimalist View Post
Dave;
Does your trailer actually use scissor jacks or do you have the screw activated stabilizers? See my comment on stabilizers above.
Yup Clif, scissor jacks on all corners with a 3/4" hex nut drive. I don't use them often as the SOB TT is pretty solid without them down. I use a cordless drill motor as it's easier than the handle crank.
Old 05-13-2016, 03:43 PM   #18
Manitoba
I had steel plates welded to the frame when I had it removed from the body. The jacks are bolted to those plates.
72zedd is offline   Reply With Quote
Old 05-15-2016, 09:04 AM   #19
I'd like to highlight the "carbon steel to carbon steel" advice you have received here. Galvanic corrosion can be a problem, particularly if you ever drive on salty roads or near the ocean. It's possible to mix metals of course, but there are precautions and best practices to control corrosion. I used stainless steel screws to hold our aluminum frames for example but filled the holes with calk and used rubber washers. Here is a good introductory article, but there is lots more on the internet: How to deal with dissimilar metals
Oh, our Trillium is also small. I get by with one scissor jack in the trunk of our tow and some blocks. A little more work, maybe, but simple!
Randy J. is offline   Reply With Quote
Old 05-15-2016, 08:34 PM   #20
The article referred by Randy is good. Learned a lot from there.
boler
ultra mini stainless steel stove bonnie w General Chat 6 12-17-2008 07:20 PM
Drilling stainless steel sheet metal? Tom Myers Problem Solving | Owners Helping Owners 8 11-02-2007 08:13 AM
ALL-STAINLESS STEEL FOLD-UP TOILET & SINK Karalyn Classified Archives 16 09-20-2006 07:51 AM
Stainless Steel and Aluminum d_wildemann Problem Solving | Owners Helping Owners 5 08-16-2006 01:33 PM
Stainless steel stove Maggie O. Care and Feeding of Molded Fiberglass Trailers 24 11-19-2005 07:43 PM
» Trailer Showcase
Beach Shack
BuddyLee
Burro
JMS
