Awning - Fiberglass RV
Old 03-01-2014, 06:52 AM   #1
Filbert V.'s Avatar
Trailer: Tote N Tarry
Awning
Could one of you wonderful folks direct me to posts or websites that will teach me how to build a simple awning that can be attached to the length of the trailer and be removed easily? The commercial ones are all too large, not to mention expensive. Thanks all! Filbert
Filbert V. is offline   Reply With Quote
Old 03-01-2014, 07:01 AM   #2
This is one of my favorites! Inexpensive Awning - DIY
Old 03-01-2014, 07:13 AM   #3
Filbert V.'s Avatar
Thanks Donna, just what I was looking for! You'd make a great librarian with your informational skills. Thanks also for sending some rain down to parched San Diego. Filbert
Awning rail here:
http://www.vintagetrailersupply.com/..._p/vts-876.htm
Old 03-01-2014, 09:22 AM   #4
Roy in TO's Avatar
Check your local RV supplier for the Awing rail. It is typically a stock item that can be cut to size and picked up.
Old 03-01-2014, 03:50 PM   #5
Filbert V.'s Avatar
Will do Roy, than you!
Old 03-01-2014, 06:07 PM   #6
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Filbert you could also do a "down and dirty" tarp thing. Which I have used at times.
First make sure you have an awning rail installed. then get a tarp that is the same width as your rail. Lay the tarp down and lay a rope (One that will fit into the rail)
about 3 inches in parallel to the edge. Fold the edge over the rope and tape it down with DUCT Tape. Now feed the rope edge into the rail. Then get two expandable tent poles and 4 tent stakes from Wal Mart. Then attach the expended tarp to the poles. One pole on each corner. Then tie down the two poles with two ropes each at a 45 degree angle and stake it.
D Davis is offline   Reply With Quote
Old 03-01-2014, 06:11 PM   #7
Filbert V.'s Avatar
Thanks Diane, and that should match my 5 liter box of fine wine at the campground! Seriously, you have a great inexpensive idea. I don't know what the opposite of "glamping" is, but that would be me.
Old 03-02-2014, 06:38 AM   #8
Mike Watters's Avatar
Trailer: Amerigo & Trailmanor (popupish)
Indiana
Our first trailer (Boler) didn't have an awning rail. But, for some reason, the previous owner had installed a couple of eye bolts through the belly band on each end of the trailer.
What we did for an awning:
I bought a cheap self-supporting awning from K-Mart (I swear, I think it was something like $5 for a 10x10 awning. Has a pole in each corner and one in the middle.
On one side of the awning, I just laid it up on top of the Boler tying lines to the corners which then tied into the eye bolts.
From this point, I'd just set up the rest as originally intended. Pole on each corner with lines to the ground. Pole in the middle.
Sure it's not as fancy as PVC plumbing... but it got the job done for $5.
I may actually have to recreate that (or something similar) for the Amerigo I'm working on. I'm not sure there is room for an awning rail on it. There's VERY little room between the top edge of the drip rail over the door and where the roof starts to curve to the roof. Not enough for an awning rail I fear. So I may be stuck doing some sort of clever alternative instead.
Mike Watters is offline   Reply With Quote
Old 03-02-2014, 06:43 AM   #9
Indiana
Found an old photo with the awning.
Old 03-04-2014, 05:55 PM   #10
Filbert V.'s Avatar
That looks great Mike! Thanks for the idea and sharing the photo.
awning
Bag Awning vs. Regular Awning Pamela S. Problem Solving | Owners Helping Owners 6 05-21-2010 09:09 AM
Catalina 2500 Awning Elizabeth Schneider Classified Archives 4 10-03-2009 01:21 PM
wanted slide awning or add-a-room for 13" trillium Travis & Nora Taylor Classified Archives 11 08-14-2009 07:04 AM
New awning Rick Brown Modifications, Alterations and Updates 22 08-02-2009 08:18 PM
adding Awning rail and awning to Surfside ericmarlo Problem Solving | Owners Helping Owners 5 06-15-2008 11:01 PM
