axle choice 13Ft Trillium - Fiberglass RV
Old 12-16-2013, 04:25 PM   #1
Trailer: My 4th Trillium
Winnipeg
Well i went to day down to Specialty Tire and they offer custom made axles in the dexter style rubber torsion trailing axles.
Weights are 2000 lb and 3500 lb both have 5 bolt-4.5 BC with or without electric brakes.
Now I know that I would like electric brakes and the trailer will be down a few gravel roads for remote fishing spots.
What is the most common weight 2000 or 3500 and what 22.5 or 10 deg Down for better ride height.
I will be changing the rims from 13" to 14" with a load range C tire.
Input would be very welcome.
Craig Broughton is offline   Reply With Quote
Old 12-16-2013, 05:45 PM   #2
Craig I would suggest you weigh your trailer if you havent already, as few are under 2000lbs loaded so your best bet would probable be the 3500lb axle.
Old 12-16-2013, 06:44 PM   #3
David Tilston's Avatar
My 4500 came with a 2000 lb axle. I think it was stock. The coupler was rated at 2000 lb as well.
If you are going to upgrade the axle, I suggest that you think about the coupler also. Also, make sure that your frame has the plates welded on the sides of the frame, where it comes out from under the front of the fibreglass, as required by the recall. Just like the 4500's do.
I put a 3500 lb axle on my 4500. If I had to do it again, (and I do, since I have six Trilliums) I would have put a 2500 lb, or 2700 lb, axle on. I am not sure which axle manufacture(s) offer customized load capacity, but I know it is available. With the 3500 lb axle, the trailer bounces a lot when empty.
Old 12-17-2013, 06:38 AM   #4
Roy in TO's Avatar
You can find real life weights here:
Trailer Weights in the Real World
Keep in mind the 2000 Lb axle comes with 7" brakes, the 3500 with 10" the former being narrower than the latter as well.
Most manufacturers offer customized weight capacity. All they do is insert rubber of different lengths during manufacturing. Custom build wait times are usually in the 2 week range.
Old 12-17-2013, 07:32 AM   #5
Winnipeg
My frame is shot ...everything will be new , frame, coupler, chains, rims and tires. I thought that 3500 would be too heavy and would bounce the trailer to death when empty. I will see if they could lessen the rate at somewhere around 2700lbs
Old 12-17-2013, 07:54 AM   #6
Ian G.'s Avatar
Craig you are exactly right, a 3500 lb axle on a 13' would be WAY too stiff. Dexter actually list their axles at a variety of capacities, I use a 2200 lb on mine and although it matches the loaded weight of my 13' Boler of 1880 total and axle weight of 1600 lbs, the ride is still extremely rough.
I could not imagine a 3500 lb ride.
Old 12-17-2013, 01:20 PM   #7
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I agree with both of these posts...and do note that in David Tilston's case he's talking about a Trillium 4500, which is around 500 pounds heavier (dry) than the 1300 under consideration here.
Dexter used to make a #8 axle- its smallest and I think what was originally on 1300's, but it looks like they've rolled all weights below 2200 pounds into the # 9 (link)
In my opinion, if committed to the Dexter brand the #9 would be the most suitable size for this trailer.
Old 12-17-2013, 05:59 PM   #8
Trailer: 77 Scamp 13
Place installing (or yourself) can establish the original axle down angle and trailer height. From that figure out how much lift an increase in down angle will provide.
Based on Scamp so YMMV the square shaft welded into the torsion arm was probably originally installed with shaft corners level. Like this <> when viewed with the wheel off. If you can jack the frame up until the arm has the center shaft in that position you can see the original arm down angle and trailer height.
Don't forget to account for any difference in height from a new type or style of mounting bracket (such as bolt on bracket) which may situate the axle higher or lower than the original. Or a taller or shorter mount on the axle itself. My original axle had the bracket on the axle just barely wrapping the tube, new axle the tube runs through the center of the bracket which puts it about an inch closer to the frame. That was intentional choice to hit same trailer height as original with the other modifications.
A little extra ground clearance is good, but not if you need a boost to climb in the door.
Old 12-17-2013, 06:11 PM   #9
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
I installed a Dexter #9 axle rated at 2200# with 7" electric brakes and E-Z Lube for the bearings on my Trillium 1300. I also got the brackets to weld to the the frame to allow the axle to be bolted on.
Bought it from Humphrey's : Humphrey’s Hitch & Trailer Parts | Trailer Axles, Parts & Accessories
Very reasonable prices and fast shipping. I am very pleased with the set-up.
Here are the specs from "back then" for your original axle set up on a Trillium 1300:
48" OS mounting bracket
65" track
0 starting angle
Trailing arm
2000 lb. capacity
Brake flanges
Tapered spindles
5 x 4.5 Wheel pattern
I went with the original 0 starting angle. You may want more of a down angle since it sounds like you may be driving on rougher terrain than I am.
"Flexiride" makes a torsion axle with the ability to adjust the angle on the arm to fit your needs. With the Dexter it is fixed. This feature does come with a premium price over the Dexter.
Hope this helps.
Spanke
Trilliums Rock!
Old 12-17-2013, 06:49 PM   #10
Ian G.'s Avatar
Originally Posted by Spanke View Post
..."Flexiride" makes a torsion axle with the ability to adjust the angle on the arm to fit your needs. With the Dexter it is fixed. This feature does come with a premium price over the Dexter.
Spanke
One important thing to note is that the Dexter axle uses 6" arms from the axle tube to the spindle. Flexiride uses 4.5" arms. Unless you make modifications to the mounting points the shorter arm on the Flexiride will move the wheel location 1.5" from the original position. Forward if the axle is installed as a trailing arm and back towards the rear in most FGRV applications which use a leading arm configuration.
I actually used the 2200 lb Flexiride on my Boler but designed the entire Frame build around using that axle in a trailing arm configuration. But I also love the ability to change the ride height of my Boler when needed.
Old 12-17-2013, 07:05 PM   #11
I'm a Flexiride fan, too, though my Trillium doesn't have one yet. I confined my earlier remarks to the Dexter since the O.P. seemed to indicate a preference.
That said, Ian's point above makes the Flexiride well worth considering, especially since the trailer under discussion here is getting a completely rebuilt frame as well as a new axle. Perfect opportunity to upgrade to a Flexiride, in my opinion.
Old 12-17-2013, 07:26 PM   #12
Spanke's Avatar
Cumberland, Indiana
Thanks Ian for the insight on the Flexiride arm length. I was unaware of the difference.
Since the back part of the frame on a Trillium is higher than the front, it would not be a problem to move the axle bracket back 1.5 inches to the rear of the trailer if you were installing it on an existing frame.
Spanke
Trilliums Rock!
Old 12-20-2013, 10:25 AM   #13
Trailer: 1976 Trillium 1300; Invertec Falcon 190 class b rv
Axle Choice - Flexiride Advantages
One advantage of the Flexiride axle is that you can replace the spindles if need be. Should you have a wheel bearing fail and have spindle damage, you could just replace the spindle rather than the whole axle. This scenario may not be as remote as it may seem at first glance.
Another potential advantage of the Flexiride is that they custom make each axle for each order. There is a possibility they could put a spindle for a 10" hub/brake on a 2200lb axle.You would have to ask the person who actually builds these axles . This would not be possible with theDexter or Al-ko axles unless you went with a 3500 lb axle which would come with 10" brakes because of the different spindle size required.
Of course, the Flexiride axles cost more, and when I priced them a year ago, it would be about $250 more for a 2200lb axle with 7" brakes.
So there are pros and cons to the choices.
georgewa is offline   Reply With Quote
Old 12-20-2013, 06:36 PM   #14
Ian G.'s Avatar
I like your thinking and it is true that you can replace the spindle but ... the 10" brakes will not fit on the 2000 lb spindle (the spindle length is too short, 5.38" vs 5.72") and the 3500 lb spindle will not fit on the 2000 lb spline (the 2000 lb axle spline is smaller diameter)
You are definitely correct that the Flexiride costs more $$$$.
axle, trillium
81 13ft Scamp axle questions 81scamp Problem Solving | Owners Helping Owners 10 04-10-2012 09:16 AM
Need a new axle on 13ft Scamp 81scamp Towing, Hitching, Axles and Running Gear 6 10-27-2011 03:30 PM
Axle Upgrade Questions - '81 Scamp 13ft Jon W Towing, Hitching, Axles and Running Gear 6 08-05-2010 07:53 PM
1989 13ft Scamp Axle Dave J Care and Feeding of Molded Fiberglass Trailers 18 10-08-2006 04:04 PM
Replacing 13ft Scamp axle Legacy Posts General Chat 12 08-21-2003 04:40 PM
