11-08-2013, 01:29 PM
Battery charging questions
My 2003 16' Scamp has an American brand converter, and a lead acid Costco RV 12v battery. I have installed a Trimetric monitor to see what is going on when charging and monitor power usage real time. I experience very long re-charging times, and see not much current being dumped into the battery. My question is would there be an advantage in installing a smarter converter, or would that be redundant if I went to a solar system utilizing a sophisticated MTTP controller later on? The PD4045 seems like it would be a step up from the stock converter, but is physically larger than the American, and may not fit under the side dinette seat. I hate to run the Honda gen for hours just to top off a 20% discharged battery. I also use a stand alone CTEK 7002 smart charger at times, but it is also slow. Any ideas?
Russ
11-08-2013, 01:58 PM
Trailer: Lil Snoozy
I use an Iota 30 amp smart charger/converter in my Snoozy. That is bigger than you would want for one regular size 12z battery. Unit is very compact, whisper quiet, cost $130.
Note the last bit of energy takes a long time to force into the battery.. When using the gas genny you might be better off starting when batt is at 50% stopping at 80% or 90%
11-08-2013, 02:09 PM
Russ
This has been discussed many many times usually ending up with the thread closed.
I'll tell you what I do. I have the same American converter, with the circuit breaker set to the OFF position. In other words I never use it.
When the trailer is sitting at home in it's nest I use a Battery Minder to keep the battery charges and it has a desulfate mode to keep the battery in good condition.
When traveling I rely on the tow to keep the battery charged while in motion. When camped for more than 2 to 4 days or more depending on the weather I have a 65 Watt solar panel with PWM solar controller charge the battery. The biggest thing I did to improve the battery situation is change all the light, except the running lights, to LED.
I think the longest we've camped in one place using this system without electricity hookups was almost 30 days. A typical winter for us is in the SW for 90+ days without hookups.
11-08-2013, 02:10 PM
Here's an article about recharging strategy. Note how once the battery is dragged back to whatever voltage the charger is using for the absorption voltage, the amps going in really drops off. A solar controller will do pretty much the same thing, that is, taper off the amperage as the battery voltage reaches some level.
http://www.xantrex.com/documents/Bat...whitepaper.pdf
Battery resources are like my pay...I can spend it faster than I can earn it.
11-08-2013, 03:09 PM
Trailer: Class A Motorhome
I replaced the American (Brand) converter in our 13' Scamp with a PD-4045 without any problems, lots of room unless you have a water heater, in which case you may have to "Relieve" one corner of the case for clearance.
It's an excellent choice for a replacement converter/charger, I have done 6 or 7 of them in different FGRV's.
Yep, maybe this time it will stick to the question asked without falling into the abyss of battery charging engineering, mostly on the negative side (of the battery)
11-08-2013, 04:28 PM
I would check each battery cell with a hydrometer to make sure you don't have a goofy cell. Then I would check the connections to the battery and to the charger and make sure there are good connections not just at the battery but at the crimps of the eyelets themselves. Maybe wilggle the accessable wires while charging looking for a fatigued wire. Check the simple stuff first.
11-08-2013, 09:13 PM
Trailer: Bigfoot 25RQ
When camping, do not try to charge the battery to 100% using the generator. It would take far too long, even with a good converter/charger charging at over 14 volts. When the Trimetric reads around 50% run the generator for a few hours and stop when it gets to 85-90% as mentioned above. When you get home and plug it in to shore power it will charge to 100% over a much longer time. While not charging completely is considered bad because the crystals that form on the plates of a discharged battery are more likely to become permanent the longer they are left on there, you won't be going that long before taking care of it with a complete charge at home.
11-08-2013, 11:53 PM
The smarter converters could in theory speed up the charging. But that last 10% is going to take time from what I have gathered. It will cost a few hundred for the converter, some 45 amp capable cables out to the battery, and fuses. Maybe I should really be thinking a solar setup, which would add boondocking capability, and would keep the battery charged at home when in storage. I use a CPAP which blows about 10% of my battery capacity per night. The trailer has all LED lighting. The roof of the trailer has very little space for panels. One could go above the roof AC unit, and one could go between the AC and front. The AC could cast a shadow on the front panel unless it was raised to the same level. Shadows really kill the output of some panels from what I have read.
Russ
11-09-2013, 12:08 AM
Steve,
The battery is only 2 months old, and it will take a 100% charge with enough time. What seems strange though are some of the readings I get with the Trimetric during charging. During my last campout the battery was down to 86% after the first night. I fired off the Honda and plugged in the shore power into it. The voltage read in the low 13's and the amperage read minus .2. I tried adding load with the water pump and some lights to see if the current would change. It only fluctuated a tenth. Why would it be showing discharge with the converter online? I also tried unplugging the shore power and using the CTEK charger. Same reading! Discharge.... Weird. I ran the Honda for about 4 hours and got the battery up to 100%, so it must have been the Trimetric giving me a bad reading?
Russ
11-09-2013, 12:18 AM
Byron,
Does your battery minder do a better job charging the batteries than the solar controller? Is the controller a multi-stage type? I have LED's in all the light fixtures, but my CPAP draws a couple of amps x hours slept. I have to put those amps back every day! Maybe need lunar panels?
Russ
11-09-2013, 12:27 AM
Bob,
My converter is mounted under the side dinette seat just above a transom storage door. It looks like the PD 4045 is about an inch taller and about an inch wider than the American unit. It would require moving the storage door hinges outboard a few inches and maybe move the door downward until it just overlaps the cutout. It will probably look crowded and kludgy, but may be doable. I don't know if the PD would need any vent cut outs, but that should be easy. They would also let fan sound out though.
Russ
11-09-2013, 12:31 AM
Denny,
I'll read up on that converter.
Thanks
11-09-2013, 01:03 AM
Byron,
Russ
The battery minder is only for when the trailer is at home. My solar panel charges with 4 amps with direct sunlight. In your case a bigger solar panel is probably a good idea. The solar charge controller is a MorningStar PWM. The panel is 65 Watts 4.1 amp. With my solar system if you sleep 8 hours you'd need 4 hours of sun the recharge.
I've got mine set up for portable use, meaning I move panel around to keep it in the sun.
I think I would be tempted to go with more battery and a larger solar panel than I have so that could go an extra day if needed. Also some days are cloudy you don't get as much from the sun.
If you're always plugged in then all this doesn't matter.
11-09-2013, 08:26 AM
You can buy a new PD-4045 From Frank Bear at Vintage Technologies, a Teardrop Supply House: Teardrop Trailer Parts for about $160 including shipping. I have bought a lot of parts and PD stuff from him and he is excellent for prices, service and delivery.
That American (Brand) converter only has about a 85% chance of smoking at some point. It's better to be proactive and replace it on your terms rather than wait for the inevitable to happen.
11-09-2013, 08:53 AM
Trailer: '98 BURRO 17WB
Delaware
Russ, most of the physical footprint of the 4000 series is the distribution panel and housing. The 9000 series is converter only, possibly a desirable option for those with space limitations. I have the PD9245 bolted to the back side of a Magnatek minus the original converter.
jack
11-09-2013, 10:02 AM
Where in the world did you get that number? 85%????
11-09-2013, 10:17 AM
Actually sorta/kinda from the guy that answered the phone at the "American" distributor 2 years ago, after mine smoked the second time it was plugged in (1st time was at the sellers place, 2nd time was that same day after we towed it home)
His approximate statement was something like "That board was a high failure item and we have replaced it with a newer design board with a better charger as well."
As it was only $120.00 for the new board, and a PD-4045 was only about $20 more at the time, out it went. Added to that is the high incidence of failures reported hereabouts as well.
BTW: It really smoked, and the s.o. just about wanted to sell the whole trailer at that point
An 85% failure rate might be a little high, maybe only 80% (LOL)
11-09-2013, 10:28 AM
In other words you pulled that 85% number out of ........
Having been in electronic manufacturing all my life "high rate of failure" equals somewhere between 1% and 5% return rate. Maximum assuming that only 50% of failures are returned would between 2% and 10%. A long way from your 85%.
11-09-2013, 10:44 AM
The American brand converter in my trailer takes forever to charge a partially depleted battery. It may not be defective, but doesn't work to my satisfaction. I will probably upgrade it even if I go solar. I like to have the best reliability I can afford when out relaxing and having fun. When camping with hook-ups we have had no problem with the converter running the lighting and water pump. I think the charging is the weak point.
Russ
11-09-2013, 10:45 AM
One more thing. Many failures are "customer" caused. Converter failures can happen when the fan is blocked causing the converter over heat, sometimes smoke.
