11-10-2013, 05:45 PM
#41
Originally Posted by Byron Kinnaman
Generator thefts must be a California thing.
I wouldn't leave the gen unattended in plain sight in any state. I have seen generator theft warnings posted in California state parks, and Oregon along the Columbia river. Thieves know no boundaries. Even coolers go missing! Woopie! Free beer!
11-10-2013, 06:10 PM
#42
If I were to hinge 2 hundred watt panels together, and fashion a stand for portable use it could be stowed for traveling on top of the rear mattress along with all the lawn chairs and barbecue stand. I would guess it would weigh about 40 lbs. Is the glass used on panels tempered? That 40 lbs. would adversely affect handling of the rig. Perhaps they could be stowed on edge nearer the front with some proper straps to secure. With all the chairs, tables, coolers, bbq, etc, there is a lot of stuff to haul in and out at each stop. Argh! more clutter! 40' of #4 2 conductor copper is not light either.
Russ
11-10-2013, 06:31 PM
#43
Trailer: '98 BURRO 17WB
Delaware
Byron will know for certain but I'm guessing 4 gauge conductors are complete and utter overkill IF the solar controller is placed in close proximity to the battery box. I believe Byron and I both have the controller on the panel to expedite charging vehicle battery without the cost of an additional controller. I'm using 25' of 12awg SJ cable simply because that's what I had at hand.
jack
11-10-2013, 07:14 PM
#44
Sorry, I was poking at you. I have noticed that the notices are generally in state parks. Along the Columbia or Oregon Coast anything is possible, extremely crowded, places I avoid except in the winter.
11-10-2013, 09:19 PM
#45
Or you could do as I do with my scamp side bath and make a foam cover for it and the stand I made for it and store it with bungees on the front wall of the bathroom so its totally out of the way and the front bunks can still be put up or down. If you have a front bath perhaps you could store it on the flat wall in the bathroom.
11-10-2013, 11:39 PM
#46
Carol,
That's a nice setup you have. Very tidy. In my trailer with side dinette the bath is in the front, but no space for the panel in there. I have in the past traveled with the side dinette table in the up position, but could put it in the bed mode and put the panel on top of the cushions and secure with bungees hooked to eyelets mounted to the fiberglass seat boxes near the wall. Thanks for the picture.
Russ
11-11-2013, 12:00 AM
#47
jack
Jack,
I just threw the 4 ga. comment out there. I have not figured the voltage drop yet, as I don't know how much capacity to buy. I will go overkill on the panel rating and probably on the wire size just to preserve voltage and power. The panels only start at about 17 to 18 volts, and you need 15.5 volts at times, so there is not too much voltage reserve for losses in wire, switches, fuses, connections, etc. Also for flexibility in placement I would like to have a long tether to get the panels out in the sun. Maybe 30-40 feet. That length will add some resistance if I don't go big. I don't know if I will just buy a portable folding premade setup with the controller mounted to the panel, or make one up and have the controller mounted in the front closet near the battery. The MTTP controllers are a little fatter, and won't likely fit in the folded panel cavity, so would need to go in the trailer if used.
Russ
11-11-2013, 12:35 AM
#48
I have an 80watt tether to graze rig similar to Byron's altho I sometimes bungee it to the front rock guard if the dogs are having a heavy macramé day with their tie out ropes. Depends on the season and angle of the sun also. If the sun track is high and no shade the rock guard mount makes sense. When the sun is low, I move the panel around to avoid shadows on the cells. I also have a pigtail made up of half a jumper cable lugged to a two pole flat connector that's the complement of the one exiting the cord on the panel. Gives me some solar charging for my truck battery in fall and winter. Now that I'm retired and don't drive 400mi. a week, sitting around feeding the vampire loads takes a good starter battery down pretty fast. I don't worry about conflict with the converter. It's on a breaker but the "switch" is when I pull the plug on the electricity tree and move to an offgrid site. I don't have a genset. I'm hoping I can get an honest 24 amphours of recharging daily in high summer as I recently installed a 12DVC/120VAC Norcold fridge and would like to make 48 hours offgrid before dropping to 50% battery SOC. We'll see.
jack
Jack,
My jeep tow vehicle has enough vampire loads to kill the battery in 2 weeks if not driven. I installed a knife disconnect to eliminate that. I have to remember to use it though! I have a relay to switch on the trailer charge wire from the Jeep, so the solar panel wouldn't be able to charge the tug and trailer at the same time unless the relay was triggered and the knife switch was closed.
Is your new fridge all electric or can it use propane too? My Dometic fridge is a 10 year old 120v or propane version. No 12v. It really gets cold and works perfectly even in the desert. I understand 10 years is probably near the end, so am collecting info on possible replacements for that sad day when it bites the dust.
Russ
11-11-2013, 01:27 AM
#49
I've decided to hold off on the solar portable 40W panel and hope for the price to drop and technology to advance.
Meantime, I'm experimenting with Coke and Mentos.
11-11-2013, 06:38 AM
#50
Trailer: asdf
Alabama
Lol. Makes an awsome mess. The kids loved it.
11-11-2013, 08:57 AM
#51
jack
I'm sorry I missed this earlier.
Like Jack I have the controller mounted on the panel so that I can charge other batteries, like my ham radio battery, or the tow if needed. I believe I'm using about 25' of 10 awg that's what I had on hand for the ham radio. The difference between 10 and 12 awg at worst would be it could take a bit longer to recharge with 12 awg than 10 awg, but not much. I believe it would take some pretty careful measurements to tell the difference.
11-11-2013, 07:36 PM
#52
Byron,
From what I have read voltage drop can be a significant factor in these 12 volt systems. As long as you end up with enough voltage at the batteries all is well. The more panels you have the amperage increases and wire size needs to increase. At least that's my limited understanding of how it works. If I put together a two 100w panel system it would produce about 10.5 amps at full sunlight. Then if I were to need a 30' tether, I should be able to figure the voltage drop using Mr. Ohm's law and resistance of wire size charts. EE's please chime in if I am off base. The 200w system is probably overkill for a one battery system, but I may go to 2 batteries in the future if needed. The system will probably cost as much as a Honda 2000i, but will be even quieter and use no gas.
Russ
11-11-2013, 09:33 PM
#53
Trailer: Escape 19 ft 2010
If I may expand on some of your observations. First, I believe the panels put out considerable more that you realize, the usual voltage on a 75 watt panel is up to 18 volts. Since the controller is dropping the voltage between the solar panel and the battery from 18 volts to 13.4 the gauge of wire is not critical. I run over 100 feet using 14 gauge and I am positive the controller is still reducing the volts. If you run the resistance calculations you do not loose enough to make a difference.
The controller should be mounted as close to the battery as possible and the gauge wire here may need your attention. However, the inexpensive controllers only have 16 gauge on the output side so it may not make sense to go with anything larger.
11-11-2013, 09:52 PM
#54
Byron,
Russ
Voltage drop depends on current. The farther away from being fully charged the greater the difference between the charge voltage and the battery voltage the grater the current the greater the voltage drop in the wire. The closer to fully charged the battery the less voltage differential between the charging source and the battery voltage the less current required the less voltage drop in the wire. This continues until the voltage drop in the wire is so small it's not significant.
The idea that voltage drops are significant in 12 volt systems in not necessarily true, it all depends on what the current is. The more important is the heat generated in too small a wire for the current particularly in battery charging situations. Therefore it's best to select a wire size based the charts for current carrying capabilities vs wire gauge. Select a wire sized for the maximum current expected to flow in the wire.
Using a wire size much larger is simply a wast of resources, both in copper and cost for insignificant gain.
A 200 watt system is way over kill for most of our trailers and batteries. You'll get a much faster recharge, but that's it. After 2 or 3 days with running the furnace in the mornings it takes about 4 hours to fully recharge my battery with a 65 Watt system. With a 200 Watt system it would take probably somewhere between 2 to 3 hours. Hardly worth the additional cost.
I do keep two batteries charged.
11-11-2013, 11:19 PM
#55
Byron,
Are your 2 batteries always connected as in 2 x 12v in parallel or 2 x 6v in series? If you are using both batteries and charging both I would say 4 hours is pretty acceptable charging time with a 65 w panel. Two batteries I would think would take twice as long to recharge as one. I wonder if one battery that was more deeply discharged would in theory accept a higher charging current than 2 slightly discharged batteries, and therefore recharge faster? Does your on panel controller feature voltage sense for reading actual voltage at the batteries? You would have another 2 small wires run along with your 10ga. current carrying wires. Sorry for all the questions, just interested in what others are using. Thanks for your comments.
Russ
11-11-2013, 11:30 PM
#56
Byron,
Russ
My two batteries are separate most of the time one is on the trailer the other in the back of my truck. Used for two different purposes.
It would make no difference two, three or more batteries with the same about of total discharge. If I had several batteries and used the same amount of current as I do with, the charge time would be the same as one battery.
If two batteries were discharged to the same level I don't think the charge time would be double. The charge current is NOT linear and changes as the battery or batteries are charged. More current is used at the beginning of the charge cycle than at the end of charge cycle. Without doing more research I can't predict how much different it would be. However it would the same as if the same about of current had been used by a single battery.
11-12-2013, 09:53 AM
#57
So far we have not boondocked for more than 3 days. (still have to show up for work) During the 3 days we always battle the depletion of battery reserves and have to run the tug or Honda to recharge. I kept thinking we needed more battery capacity. Adding a second battery only goes so far though. We may be fine with the single group 27 with a robust solar charger. The battery is set low between the front tongue frame members with no room for a second without raising them above the frame level. Adding the weight of another battery is another concern. We'll install the solar and see how the camping style evolves before thinking of a second battery.
Thanks everyone for your replies,
Russ
11-12-2013, 10:46 AM
#58
On my 13 foot Scamp I put together my Solar system to recharge my single Group 27 lead acid battery. According to experts I did it all wrong and it works great. I used (2) 30 watt mono-crystalline panels from e-Bay because they fit through my escape hatch. I used a cheap Sunflex 10A Pwm controller also bought on E-Bay and used Radio shack 12 awg ofc wiring used for audio systems, why, because I had it and its 2 wire and very flexible. I use a jumper between the 2 panels long enough so they can fit alongside the escape hatch. I splurged on a trolling motor plug and socket and a large size fuse holder used in audio equipment. The controller was installed wrong as it is inside the trailer by my Progressive Dynamics PD-4045 panel. Trolling motor socket is mounted by my incoming trailer wiring which goes close to where I mounted panel. I put the panels on top of my trailer and toss the cable to the front of the trailer and plug it in. With the plug in the front I can move my panels at whim should I have a shade issue. I tie my panels together around the escape hatch with rope. The panels are not noticeable up on top. Last winter we were in Quartzsite and the sun is low in the south. I hung the panels over the side if the trailer with the same rope around the hatch. We used the trailer with the heater on as the overnight temps were in the low 30’s.
My Attwood 2 furnace doesn’t draw much power through out the night, comes on about once an hour at that temperature and I like the trailer fairly warm. All of our lighting is L.E.D.'s. I checked the battery every morning before the sun came up and we were about 90% and in four hours or so in the sun we were recharged. This was using a digital volt gauge and not fancy monitors. We use allot of light and have a water pump but we don’t have a bathroom or shower using power after sundown. It works for us and we are happy with it. We live in Southern California so there is far more sun than shade. It cost me about $200 to put it together. Prior to this project the only thing I knew about Solar was what a Panel looked like.
11-12-2013, 11:12 AM
#59
Russ
Russ, is this a new battery or a battery that was on the trailer when you acquired it?
I can get by without much worry with one group 27 battery for 3 days of dry camping without draining it below 50% capacity & before I need to put the solar out to top it back up.
I use only LED lights in the trailer and use them only as really needed. If reading late into the night I use a head lamp. Fridge runs on propane so the lights and water pump and the Fantastic Fan (again used only as really needed) are the main power consumers and they are all pretty easy on the power consumption. When dry camping in winter and I need to use the furnace which is a power hog I restrict its use as much as possible - only to heat the trailer up prior to going to bed and again in the morning. I set it very low so it does not come on at all or if it does not that often during the night. If I know its going to be a very cold night I may even shut it right off to prevent it from coming on and off all night. Just use lots of blankets instead. I will often use the battery power for phone & camera battery recharging as well but not much else - I dont run the mp3 player (use a battery operated radio instead) or the tv when dry camping.
If its an older battery that has been drained below 50% cap or drained dry a few times its not going to hold much of a charge for long and it can be as you say a struggle to get by.
11-12-2013, 11:16 AM
#60
Russ
There's a couple of ways to extend battery life. The one I prefer is to reduce usage. I changed all the lights to LED. In the case where you have of a water pump use water sparingly. Wet Ones for cleaning hands reduce a lot of water needs. Try to use the local bathroom facilities as much as possible.
Basicly try to determine where you can reduce the need for battery power. I can get by with a group 24 for 3 or 4 days, unless it's warm at night then I can go for weeks. The LED lights don't take much current. The only other thing I have is fan in the furnace. No TV, Stereo, or DVD player.
The other way is to increase the amount of battery or constant recharge from solar.
Power consumption is something each person has to evaluate for them selves and how to reduce it.
