Battery location - Page 3 - Fiberglass RV
Old 05-06-2006, 02:49 PM   #29
Trailer: '74 Ventura
Without question the "gas" will rise (go UP) - But having had Motorcycles in the past, those batteries have the "vent" nipple with a hose going downward (thus I assume the full size battery will also have just a "vent" nipple to attach a hose to as well) - anyways - I "assume" the gas will go through the "vent" down the hose (thus outside) since it will be the path of least resistance - the battery I intend to purchase is a sealed one (yes I know you can pry the panel away on top and add distilled water).
OR
Am I missing something here?
I think it is time for a trip to the parts place and get a battery
and start this project
Any more suggestions OR ideas are welcomed
ttmatson is offline   Reply With Quote
Old 05-06-2006, 05:39 PM   #30
Murphy`s law...if something can go wrong, it surely will....have a great evening...Benny
Old 05-06-2006, 08:51 PM   #31
So "apt"
Went to the parts store AND the battery I have selected does not have a side vent
The "regular" style battery box has a vent on TOP of each pole
So now what
Wellllllllllllllllllll after much discussion in the aisle at the battery display, we decided that we would go with this because:
1) It will be under the seat;
2) Chances are there will be enough ventilation not to "matter";
3) "IF" I don't do something, I will keep "second guessing it" and camping season will be over OR so She Who Must Be Obeyed sez
So sometime this week (after the solar panel arrives) the installation process will begin
Old 05-06-2006, 09:16 PM   #32
Ryan Kennelly's Avatar
Trailer: Trillium 4500
I know this topic is getting out of hand! The group 31 I have selected has 3/16 holes on each cap. a plastic vacume connector will push right into it! now you have a place to put vacume line! next week, I'll get the gas leak detector out and set up a battery in this configuration. and we will know for sure if this works!
and just for TT, I'll take lots of pics for future reference!
Ryan Kennelly is offline   Reply With Quote
Old 05-06-2006, 09:41 PM   #33
Unhappy
Great
Good idea - will be looking forward to the report
Yes - this is getting a bit long - but it IS helping and being informative - I guess I owe an
apology to Dan for "hijacking" the thread
As She Who Must Be Obeyed would say - "Bad Toad"
Old 05-10-2006, 06:28 PM   #34
Myron Leski's Avatar
Trailer: 19' Escape
NM
So I bought a vented battery box, came today, and it looks exactly like the picture shown earlier and seen below. What you don't see here is underneath where there's a 2 inch diameter hole extending out 1 inch deep from the bottom tray. A second vent for a second hose? What's that all about??
Myron Leski is offline   Reply With Quote
Old 05-10-2006, 07:55 PM   #35
From the original link:
http://www.pplmotorhomes.com/parts/rv-conv...oxes-vented.htm
""Battery boxes that are vented include a kit (wall connector, outside vent and 9" hose) for inside installations. This battery box that is vented [b]also has a hole at the bottom to help with air circulation. This product meets the RVIA Code.""
Hope this helps
Old 05-11-2006, 06:11 PM   #36
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
Does anyone else see a certain family resemblance here?
Ok, sorry... going to my room now...
Roger
Old 05-14-2006, 09:30 AM   #37
Rick B's Avatar
So you would drill a hole in the wall or floor for the hose to expell what its venting? Gosh I don't think I would do that.
My 17' Bigfoot used to have two 12 volt batteries under the front bench seat. They were in a custom wooden box with a gasketed lid that screwed down. The box was vented outside of the trailer via clean plastic tubing - seemed to work well
Rick B is offline   Reply With Quote
Old 05-14-2006, 11:04 AM   #38
Victor Benz's Avatar
I have a 1982 Fiber Stream with a steel interior battery box. It is unsupported as descrribed by Frederick Simpson in another thread, plus taking the battery in and out is a real pain!
I was lucky to purchase a used vented battery box of this description plus hose yesterday. The [b]real problem solver was that a standard 1.5" crumb cup (PlumbShop PS2256) is a friction fit into the 2' vent nozzles on the tank. This is also a standard drain stop for many RV sinks. I plan to install two, with metal window mesh to prevent insects getting in.
I plan to install the box as follows.
1. Site the box location on the trailer floor.
2. Nail in 1"x2" support strips on the floor to frame the battery box and keep it positioned.
3. Mark the floor drain hole.
4. Drill the floor hole to allow the hose to pass.
5. Plush the first crumb cup in the bottom section vent with the window mesh, from inside the box (then it won't fall out).
6. Glue a short section (2" to 3") of hose to this vent. This will ensure anything leaking from the box (like battery acid) will exit below the trailer floor.
7. Place bottom section in between the 1"x2" framing supports.
8. Insert the battery, and connect cables, using wiring grommets to seal the box at the cable entry points.
9. Run a small width, thin foam weatherstrip arond the bottom sealing surface.
10. Place the top half of the box onto the bottom half.
11. Screw fiber straps with buckles to the 1'x2" side supports, and strap in the battery box
12. Push the second crumb cup in the top section vent with the window mesh, from outside the box (then it won't fall into the box).
13. Install a manual water filler unit upside down (so that rain water coming in won't run to the battery box) on the side of the trailer, plugging the 3/8" vent line.
14. Grind angled vent slots in the manual water filler cap with a Dremel tool, and permanently glue in place.
15. Connect one end of the vent hose to the battery box top vent.
16. Connect the other end of the vent hose to the modified manual water unit.
Voila!
I'll provide phtos as this comes together.
Victor
Victor Benz is offline   Reply With Quote
Old 05-14-2006, 12:29 PM   #39
Trailer: 19' Escape
NM
Wow, Victor, pix of that I gotta see. I especially want to see that crumb cup.
Old 05-27-2006, 10:22 AM   #40
Louise's Avatar
Trailer: Casita 13 ft
We have just had a battery installed and it is located underneath the seat in the bed area. It is in a sealed battery box with a hose to a vent on the side of the trailer. It's exactly the same setup as we had in our old camper van which vented out of the side of the van. We never had a problem with it if we remembered to check its fluids. The only time we had a problem with fumes was when we forgot to check the fluids and it dried up. Otherwise, never had any fumes or obviously no explosions!
Louise
Louise is offline   Reply With Quote
battery
Bigfoot battery location Legacy Posts Problem Solving | Owners Helping Owners 16 08-23-2010 11:09 PM
VIN location Isaac M Problem Solving | Owners Helping Owners 3 03-29-2009 10:03 PM
Battery position / location AdamB Problem Solving | Owners Helping Owners 15 10-10-2008 03:46 AM
Battery location in Campster Bobbie Mayer Problem Solving | Owners Helping Owners 4 08-08-2007 09:45 AM
