Battery-powered AC units for truckers...? - Fiberglass RV
Old 07-11-2015, 04:22 PM   #1
Ellpea in CA's Avatar
Question Battery-powered AC units for truckers...?
I was just digging through the Dometic website looking for other stuff and came across these. Battery powered? Work for 8-11 hours? They look (relatively) small?
Is there any chance these might be a good solution for cooling FGRV?
(this is just one model, there are others)
Inquiring minds like to know!
LP
Ellpea in CA is offline   Reply With Quote
Old 07-11-2015, 04:52 PM   #2
As most of us know, it's common practice for truckers to leave engines running when parked, meaning that the huge alternator they have, or an APU (Aux power unit), is available for powering a/c's etc. Looking at the specs it looks like it would take a substantial battery bank to get overnight cooling from battery power alone.
Which would then need to be recharged for the next nights use. Add to that, sleeper cabs are a lot smaller than FGRV's.
When it comes to generating BTU for cooling there's no free ride known, so far anyway!
Old 07-11-2015, 05:07 PM   #3
Timber Wolf's Avatar
North Florida
Battery powered AC. Would that not be the same as any other 120V Air Conditioner running off an inverter? With the inherent inefficiencies in such conversion it would take a lot of battery to pull off. Maybe one of those new high dollar Tesla batteries. I am waiting on a nice 12V compressor AC unit not unlike the 12V compressor refrigerators that are proven technology.
Old 07-12-2015, 02:33 PM   #4
This reminds me a lot of the days when we had laser copiers and laser printers, which were essentially the same machinery, but you had to purchase two items to do almost the same job. I kept wondering why they didn't combine printers and copiers. Viola. Someone finally did.
But that does beg the question, if we can get things cool using propane, would it be THAT hard to power AC somehow the same way?
(Thanks for the PM info on all of this!)
I'm curious to know what we have discovered so far... what is the most efficient, least power drawing AC we've got available right now (appropriate for a little egg)?
LP
Old 07-12-2015, 04:45 PM   #5
You could build an LP powered a/c system but, to produce the volume of cooling BTU's you need it would be about the same size and cost as a new 13' Scamp.
For a closed circuit refrigerator/freezer it's fairly easy, but also expensive, for a full scale a/c unit it would be cheaper to keep about 1000 squirrels in a wheel running a generator.... LOL
Old 07-12-2015, 06:35 PM   #6
AHA! At last we have a workable plan! Any thoughts on what's required to keep 1000 squirrels moving at a dead run for 8 hours????
LP
Old 07-12-2015, 07:06 PM   #7
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Unfortunately, federal laws prohibit squirrels from working more than 8 hours without a 30 minute break. In addition there are likely confined animal feeding operations which would limit the number of squirrels being housed in one place. They would likely be banned in California due to the excess carbon dioxide emitted while on the treadmill. While the concept seems plausible , I doubt that the bureaucracy involved in the proof of concept trials could be overcome at a reasonable cost.
mmeyer is offline   Reply With Quote
Old 07-12-2015, 08:33 PM   #8
Actually I looked up the Squirrel Labor Laws for California and their use in a/c power units has been banned due to excessive amounts of flatulent odors emitted during operation. Sorry, we will have to find a different method.
Old 07-13-2015, 12:43 PM   #9
Borden's Avatar
Name: Borden and Carole
They do make a diesel a/c unit for reefers but it is to big and heavy for us maybe we could find a small one a Quart of fuel will run for a full day.
1978 Ontario made Boler
Old 07-13-2015, 01:04 PM   #10
Borden's Avatar
Sent a message to domestic support, see what they come back with
Old 07-13-2015, 09:35 PM   #11
Borden, WOW -- that's very intriguing! Will be watching to see what you find out!
Bob and Michael J., you two are obviously squirrel huggers whose opinions are tainted by raw emotion. Everyone knows those little critters were born to run. No matter... I'm already working out a plan for using hamsters on exercise wheels instead. We always posited in the early days this would be a faster method for powering some computers; now there is an opportunity to put the hamster-powered concept to a real test.
As you can see from my initial research (see video), hamsters are ready and willing to dedicate themselves to the job of producing power, and neither bangs nor falls nor concussions will stay them from the swift completion of their appointed task.
(However, I do think it advisable to check into all details of worker's compensation insurance.)
Best,
LP
Old 07-13-2015, 11:57 PM   #12
tractors1's Avatar
Trailer: Escape 21 - Felicity
LP
The 7000 cooling unit draws 9 amps. The group 27 batteries would be good for 3-4 hours. Plus you'd have to create a hole for the condensate drain.
Charlie Y
Old 07-14-2015, 12:40 AM   #13
That's 9 amps at 120 volts I believe. That would be 90 amps at 12 Volts.
The web site says for use with shore power. It does mention batteries and inverters, but at 90 amp it work for very long at 12 volts that doesn't include starting current.
Old 07-14-2015, 04:36 AM   #14
South Carolina
I'd like to hear more about those 12V compressor fridges mentioned several posts up.
p@
patrick crawford is offline   Reply With Quote
battery
Can you wire in battery powered lights? Nelmes Electrical | Charging, Systems, Solar and Generators 4 08-20-2013 10:03 AM
the Coleman battery powered camp shower: discontinued! jen b General Chat 2 03-16-2011 01:40 PM
Solar Powered Battery Charger Rich S Electrical | Charging, Systems, Solar and Generators 6 10-17-2006 09:19 AM
Sylvania Dot-It; stickble battery-powered LED lights Laura Heiman Modifications, Alterations and Updates 2 04-12-2006 01:15 PM
Boler Repair Ideas/Other units also Legacy Posts Problem Solving | Owners Helping Owners 0 08-19-2003 08:15 PM
