battery wire mod - Fiberglass RV
Old 05-23-2008, 06:37 PM   #1
shane n's Avatar
The factory battery wires are very stiff and after sliding battery out of the side compartment on trailer just once I had broken strands so I mounted an isolator block and ran soft 8 gauge boat cables to battery with shrink wrap and made them long enough so battery can now reach the ground to check water level. I found this mod on another forum
shane n is offline   Reply With Quote
Old 05-24-2008, 07:34 AM   #2
Dan Meyer's Avatar
What a cool idea!
In addition to solving the problems you outline above, it also solves the problem of having a black wire and white wire at the battery (and hooking them up backward...), changing them to the automotive standard of red and black.
-- Dan Meyer
Old 06-22-2008, 10:20 AM   #3
Trailer: 2004 Casita 17 ft
Shane-
I'd like to try this mod on our Casita. Where did you find the isolator block?
Thanks,
Glenn H.
glennakay@sbcglobal.net
Glenn Hoffpauir is offline   Reply With Quote
Old 06-22-2008, 10:27 AM   #4
Roy in TO's Avatar
Just a suggestion, it might be a good time to install a fuse to the battery at the same time.
Old 06-22-2008, 12:04 PM   #5
Trailer: Fiber Stream
Talking
I did a similar mod in my Fiber Stream.
I used a fuse block instead of an isolator block, and it makes a good connection point for the solar charge controller.
Old 06-22-2008, 01:38 PM   #6
Pete Dumbleton's Avatar
For those who want a flexible cable, welding cable is very good because it is made up of a large number of small strands. Not cheap.
Contrary to conventional wisdom, it has no extra current carrying capacity in DC use.
battery
Battery wire Brad Judd Care and Feeding of Molded Fiberglass Trailers 3 09-30-2007 02:43 PM
Battery charging wire J Martin Problem Solving | Owners Helping Owners 27 07-25-2007 04:26 PM
110 VAC re-wire job done Gerry Modifications, Alterations and Updates 0 06-21-2007 03:41 AM
Battery re-charging wire Gerry Problem Solving | Owners Helping Owners 10 10-16-2006 08:41 PM
Battery Charging Wire? Chris73 Electrical | Charging, Systems, Solar and Generators 22 08-25-2006 11:20 PM
