Beachcomber TM15 - The build, starting with gutting the inside - Page 8 - Fiberglass RV
Old 10-16-2013, 10:34 AM   #99
goggles's Avatar
Trailer: 197? Beachcomber
Manitoba
Originally Posted by Rick n View Post
Michelle,
Here's those pictures I promised of the door bracing.
I'll post pictures of them mounted in the trailer when we get it put back together.
And just a guess but I bet they're a lot stronger than MDF board which in my opinion is the worst building material out there.
You can probably see from the shape of them they match the contour of the trailer doorway and one fits on either side of the doorway, they have about 20 screws when they're installed holding them to the trailer. the effect is they pull the doorway into it's shape and they are very rigid and strong.
I'm quite sure you can make something similar or have something made for you.
Can you give me any dimensions or angles for these door braces? I would like to have some made for mine.
goggles is offline   Reply With Quote
Old 10-16-2013, 12:24 PM   #100
Rick n's Avatar
Trailer: Beachcomber TM15
I think Michelle had some made by her father inlaw
If she can't give you the info I'd be happy to take some measurement for you.
Rick n is offline   Reply With Quote
Old 01-14-2014, 10:05 AM   #101
I'm about to embark on the same rebuild project and I have some questions if you dont mind.
-Is there a retailer for that aluminum foam or do you order directly from the supplier? - What Size blue wood did you use for the floor and walls, ex. 2x4
- Did you bond the blue wood to the shell with the PL300?
- Where did you order from / how did you fix your broken door handle and lock?
- When you did the fiberglass repair on the floor did you need to vaccum bag it? or did you just lay up FG and smear resin on it?
- Did you anyone ever agree on the stock tire size for these trailers?
Thanks a bunch
Kyle
ferniebiker is offline   Reply With Quote
Old 01-14-2014, 11:32 AM   #102
Rick n's Avatar
Hey Kyle
Thanks a bunch
Kyle
The aluminum foam comes from a company in the Toronto area called Cymat
CYMAT The blue wood was 1"X3" and was sold at Lowes.
I used PL but you have to get the one that is compatible with fibreglass.
As for the door latch I made one from metal, the door lock have done nothing with yet because replacement lock cylinders are not available for these old door handles, if you look on ebay however new ones pop up now and again.
Fibreglass was layed down and then smeared resin as you say, stock tire size is 14"
I hope this helps, gl on your build and keep us up to date on your progress.
Rick.
Old 09-01-2015, 06:40 AM   #103
Rick n's Avatar
The new awning, let's see if this works
Old 09-01-2015, 06:45 AM   #104
Rick n's Avatar
https://goo.gl/photos/6yNtk8hXsWDxgdDE6
Old 09-01-2015, 06:54 AM   #105
Rick n's Avatar
Old 09-01-2015, 06:59 AM   #106
Rick n's Avatar
Trying to post video of new awning
Can't post video but there's a couple of pictures in the previous post, awning is from a dodge sprinter Camper van.
Old 03-16-2016, 09:55 PM   #107
bkm
Trailer: 79 Trillium Beachcomber 15ft,
So what did it set you back?
Rick, I loved the detail and the rebuild looks great. Owning an identical trailer (pre rebuild) I was wondering what you would estimate the total rebuild set you back. I realize this is a best guess. If you can break it out by areas that would be awesome. ie
Total: $3,000
Fiberglass work $300
frame& tires $1,000
interior cabinets etc $1700
The reason I ask is I am trying to decide if I am better to sell and upgrade or if this work would be reasonable and achieve what I want. (which is really a bigger main bed and better layout)
finally if you have already mentioned it just direct me to the page. 8 page of notes means I didn't read it all.
bkm is offline   Reply With Quote
beachcomber
Need Help - Vancouver BC - Gutting - Face Call Dawn S Problem Solving | Owners Helping Owners 2 08-07-2009 08:23 AM
If you could build a Scamp Kevin K General Chat 17 04-03-2009 12:51 AM
Build your own camper. Roger C H Jokes, Stories & Tall Tales 5 10-20-2008 09:29 PM
Build your own Compact III... Cliff General Chat 8 09-17-2008 05:15 PM
What would you build? Legacy Posts General Chat 11 06-01-2003 02:01 AM
» Trailer Showcase
ECO
Suanne
BIGFOOT
jboy3435
