05-11-2012, 11:03 AM
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
bed mod
I have a 13' Bigfoot. I wished the bed was wider. reading threads about what others have done I thought I would give it a try. The base or floor of the bed extension is 3/4" plywood sanded down to 1/2". std. 1/2" is what I wanted. ( it came from a cabinet shop, and that is what they had available, the dark area is the glue between layers, not sanded away) the feet came from a damaged sewing table with fold up legs, I cut them to length; measuring the height of the existing ledge to support the table top. here are some pictures. I ordered some foam from a foam supply company out of San Francisco. Haven't received it yet.
05-11-2012, 12:03 PM
Utah
these are some pictures, Kenny
05-11-2012, 12:40 PM
Trailer: 2010 Scamp 16
I like that, simple yet it looks effective.
Where do you plan to stow it when you want the floor space? Will it slip under the table?
05-14-2012, 07:42 AM
Utah
I thought I would just set the extension outside next to a chair, it then becomes a table to support a beer glass and chips, it is too wide to fit under the existing table.
05-14-2012, 10:32 AM
We used a small folding camp stool and a board to do the same thing in a school bus conversion. Extended a bench seat by 18 inches if we needed that bed but ALWAYS saw use as a drinks and snack table
Looks like you can sleep lengthwise now. Nice.
05-14-2012, 11:06 AM
Trailer: 1999 Scamp 13 ft and 2003 Bigfoot 17 ft (15B17CB)
Thanks Kenny, I'm going to look for a damaged sewing table/lightweight folding legs in my night before garbage pickup tours. We have the same issue in our BF. Tony
10-16-2012, 10:06 AM
As long as either one has very cold feet this would work.
Ron
10-18-2012, 05:04 PM
A 13' trailer with a 17' bed. Good solution. I missed it when it was first posted. Glad it resurfaced. Thanks for sharing. Raz
10-18-2012, 05:13 PM
Trailer: 1991 17 ft Horizon
Nice job, it looks like it will work great.
10-18-2012, 05:40 PM
I may be wrong, but the dark area sure looks like s cat to me:-)
11-03-2012, 10:53 AM
Utah
thanks Dave,,,I wondered what that black thing in the picture was!
11-03-2012, 07:28 PM
Saskatchewan
I'm wondering if you use your bed extension when the furnace is on? I would be concerned about igniting the bedcovers.
11-05-2012, 10:16 AM
Utah
Hi Hazel
the furnace is quite hot,,,to the touch,,,but my wife and I sleep in a connected sleeping bag that is too wide for the space between the furnace and the pantry, so we fold both sides of the ends of the sleeping bag inward it is away from the furnace outlet to let the air pass beside it. the cold air return is below the support platform. the sleeping bag has come in contact with the furnace outlet at times and it has not become very hot. I can put my hand on the furnace outlet and in is uncomfortable, but I feel it would not ignite fabric if I held it against it. I will give it a try.
11-05-2012, 11:56 AM
A small screen guard about 4 inches out from furnace might be the (safe) answer.
11-05-2012, 07:44 PM
Utah
thanks Ron I think that is a perfect solution.
11-07-2012, 06:43 PM
ATTACHING PHOTOS TO FIBERGLASS RV SITE
Scroll down and click to “GO ADVANCE”
Click on the PAPER CLIP.
Click on BROUSE (go to your pictures and select a picture, double click on it) if you want another picture click again on BROUSE and repeat process.
When all picture are selected (4) click on “UPLOAD”
WAIT till uploading is finished.
Close this window and you will return to Thread.
Click on the PAPER CLIP , click on insert, you will see only the text for pict, you can add text notes at this time.
When ready to send you can preview (click on PREVIEW POST.) if all OK click on SUBMIT REPLY and that should be it.
HOPE THIS HELPS ….
11-27-2012, 11:46 AM
Utah
Bed extension
My wife, and I, just took a 6 week trip, from Ut. to the east coast down into Virgina,then up thru D.C. into N.Y. and Connecticut, Left N.Y. and N.J. as the waves were starting to crash along the shores. went over to Buffalo and Niagara Falls. into Ontario, back into the USA then home by the northern route. We have a Electra glide Harley. so we had to go to the Harley museum in Milwaukee Wisconsin. then home. We decided that the bed extension, made it very problematic (to use the Dometic toilet). there is only about a foot of space at the end of the extension; if there was a rush in the morning (with my companion), and the campground bathroom was to far away,I would get up, while she sat up in the std. bed area. I would take the bed extension down, set it outside, throw the sleeping bag bottom up onto the std. bed area. I would pull the toilet out from under the front seating/bed. I have thought about this and decided we can go back to the original sleeping method with about a foot extension; where knees or a rear end could be extended! All will be good!
lATER kENNY
03-09-2013, 01:18 AM
Trailer: Scamp 13 ft
Kenny, I love your idea! I have placed a large plastic storage tote with thick patio cushions on top to attempt the same thing! It works pretty good and the box doubles as storage. It then has a third use as a coffee table when the bed is made up! Since you felt your platform table left too little room for the porta potty, did you ever shorten it? If so can you post an updated photo? I'd love to see it!
