Bed Mods - Fiberglass RV
Old 03-11-2003, 06:52 PM   #1
Bed Mods
As some of you may or may not know we have a 2000 16' Casita SD. Well we as I believe many of you do not use the rear bed as a table area at all and keep it as a bed full time.
I just ordered a foam mattress to make it a bit more comfortable, but let me tell you what else I did...
At the end of the bed where Julie sleeps sags a lot because where it has the "V" angle cuts there is no bed support where the bed cusions overlap. So I cut out a 4X4 piece of birch plywood that will fill the gap in this section. Now we have a full bed where there was no support before. Trust me it makes a huge difference for us because now Julie can actually stay on her side of the bed and not smother me... at least not all the time.
It does not seem like much but Julie (sleeping towards the bath side) has that little be extra where gravity does not pull on the cusions as it did before.
Take a look at what I mean...
<img src=http://www.datazap.net/free/jewels/images/P3110003.jpg/>
Old 03-11-2003, 07:13 PM   #2
Hi Steve
Good idea you got there.One question.Did you order high density foam.This is the best to have.:wave
Old 03-11-2003, 07:16 PM   #3
Bed Mod
Steven - that is exactly what we did. In fact, we doubled the front so that when anyone sits on the edge there is zero give. You are correct. It makes a tremendous difference.
Old 03-11-2003, 07:27 PM   #4
Ches, when you say high density do you mean firm?
Old 03-11-2003, 07:47 PM   #5
Steven
There are different types of foam.High density should be the type that you got in your cushions.Some of this foam is deceving.It looks good but a year down the road its sagging and will not spring back to normal shape.I just put in my Boler today two peices of high density foam for our beds.I still got job to complete.
<img src=http://www.fiberglassrv.com/board/uploads/3e6e913008f06mat.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3e6e913f7999emat1.jpg/>
These are bunk beds.75x36 inches.Works for us.:wave
Old 03-12-2003, 06:41 AM   #6
Glad to hear that Michael might have a sibling at some point!
Old 03-12-2003, 07:08 AM   #7
Now now Charles
I love Michael but another baby at this time is not in the plans. Our little family of 3 works perfect for our Casita I don't know what would happen if we had another little one. I think we want to keep things as they are for now... however the act in producing another baby is not toally out of the question!:wave
Did I just say that...
Old 03-12-2003, 10:06 AM   #8
bunk beds
Ches,
I am very interested in how you are doing the bunk beds. Personally, I would rather have the bunk beds in the rear of the trailer. I would then turn the front into a mini dinette. We spend more time outside camping that in. Any info or additional pictures would be great!
Old 03-13-2003, 12:31 PM   #9
similar treatment
Looks good...and our trailers are siblings!!! I had the same prob with company and did a similar arrangement with melamine.....added a flare to cover the heater discharge below and protect bedding.<img src=http://www.fiberglassrv.com/board/uploads/3e70ce5834fc83e39d9c7b8f6abedboard1.jpg/>
Old 03-13-2003, 02:25 PM   #10
What exactly is melamine?
Old 03-13-2003, 04:03 PM   #11
You know that cheap/inexpensive (usually white) stuff on bathroom and kitchen cupboards which coats particle board? That is melamine.
It's basically a wood finish replacement.
Old 03-13-2003, 04:11 PM   #12
Oh, cripes! I knew that! Duh. :o
Something made me think it was thick like wood. So you just got white laminate covered particle board?
Old 03-13-2003, 04:48 PM   #13
I don't think this is the same thing. he talks about it
http://www.fiberglassrv.com/board/read.php...11&page=1#11120
and it's 5/8 inches thick
Old 03-13-2003, 05:00 PM   #14
No, I think it is. He paid someone for a large piece. What he paid for was someone to apply the laminate on all sides (or at least the top and sides), I'll bet.
I had a brain-fart and forgot the troubles I have been through, doing just that - laminating. In my misspent youth, I laminated, what seems like, miles of countertops. I completely forgot the term melamine, somehow I thought (from the image perhaps) it was a sheet of white plastic. Doh!
Old 03-13-2003, 06:45 PM   #15
Orginally posted by Jamie Auch
Ches,
Jamie
Ok hope this works for you.
<img src=http://www.fiberglassrv.com/board/uploads/3e7124286acf4bunk.jpg/>
Top bunk steel frame with 3/4 plywood base.
<img src=http://www.fiberglassrv.com/board/uploads/3e71243dc0b84bunk1.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3e7124581db75bunk3.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3e712468e3d4fbunk4.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3e7124782a9cebunk5.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3e71248940f5fbunk6.jpg/>
The legs are just 2x4s routered on edges.The legs on the ones closest to you are lagged bolted into counter top and also back wall.The legs on back end are angle brackets on bottom with the big cross brace you see.:wave
Old 03-13-2003, 09:58 PM   #16
Bunk Beds
Thanks Ches,
Is the bottom bunk on the floor or is it raised up a bit? I am going to have to explore the possibilities in The Love Bug this weekend. ;)
Old 03-13-2003, 10:13 PM   #17
Jamie
The bottom bunk is 1 ft from the floor.We bought 2 blue plastic containers and slide under for extra storage.Got at Wallmart.
Mods Harry Berry Modifications, Alterations and Updates 8 07-25-2007 09:58 AM
Anyone want more mods to do? Lainey Modifications, Alterations and Updates 0 06-22-2007 07:35 AM
Pop-top mods DonInChatt Problem Solving | Owners Helping Owners 12 02-21-2007 12:31 PM
outside mods james kent Modifications, Alterations and Updates 3 04-19-2006 09:57 AM
more mods Legacy Posts Modifications, Alterations and Updates 33 05-28-2003 11:04 AM
