Being On a Scamp - Fiberglass RV
Old 03-21-2011, 09:00 PM   #1
barryra's Avatar
Trailer: 1993 13 ft Scamp
Being On a Scamp
I think there should be an anonymous section here for dumb questions but here it goes... When I am installing a Fantastic fan in my 13 scamp.. can I be on top with my full weight? (260 lbs) Or do I need to lean & do half at a time? Thanks for all your help.
barryra is offline   Reply With Quote
Old 03-22-2011, 04:52 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I would lean & do half at a time?
Old 03-22-2011, 05:46 AM   #3
I don't weigh that much and there's no way I'd put all my weight on the roof. I'm trying to figure out a scaffolding system so I can do some work on the roof of my Scamp. Sky hook?
Old 03-22-2011, 10:57 AM   #4
Donna,
Any chance you could hang a plank from your carport brace's ?
I think mine would be strong enough for that.
Bill K
Old 03-22-2011, 11:48 AM   #5
IllAnnoy
Originally Posted by Bill K View Post
Donna,
Bill K
A step ladder and leaning over is just fine, you might even consider two stepladders with a 2X12 plank across (not touching the roof) then put part of your weight on that.
Old 03-22-2011, 01:29 PM   #6
Bill, I've thought about that. Unfortunately the sides are 18' across from one another. May rent some ladders/scaffolding and do as Floyd suggested though.
Old 03-22-2011, 03:09 PM   #7
Ed Harris's Avatar
I have used the 2 ladder approach and it works well for me.
I also have freakish Monkey Arms and can lean a ladder and reach almost anything and it is lot easier to do this than the 2 ladder deal.
I also use a Little Giant ladder and can make the ladder lean without leaning against the trailer so I can be slightly away from it but near the roof.
Also the Giant NEVER feels like it will tip or slide on its own.
I would not get on the roof myself.
Old 03-22-2011, 11:02 PM   #8
Flygal's Avatar
no way
Flygal is offline   Reply With Quote
Old 03-22-2011, 11:04 PM   #9
Flygal's Avatar
I did not know this about you...
Old 03-23-2011, 09:09 AM   #10
barryra's Avatar
Thanks for your tips Now... if the blizzards stop before summer I can actually start putting the fan in & start cleaning & polishing.
Old 03-26-2011, 08:07 PM   #11
When I did mine I installed the fan over the rear table and was able to reach most of it by opening the escape hatch and standing up through it.
Old 03-26-2011, 09:24 PM   #12
Trailer: 2000 Scamp 16 ft Side Dinette Deluxe / 2006 Toyota Tundra
Get the ladders, but rent a plank for scaffoldng to place across them.They should be the right length, do not flex and easy to strap to the ladder for safety.
D Tharp is offline   Reply With Quote
