Best furnace? - Page 2 - Fiberglass RV
Old 10-05-2016, 01:38 PM   #15
John Linck's Avatar
Madison, Wisconsin
Still hoping some company will introduce a gravity furnace with no electrical demand, no noise and no fan. Had one 40 years ago and loved it in my first camper. Nice even heat, no noise and convection exhaust to the outside.
Many direct vent household heaters have the similar features and use the same principles. Why not in RV's?
Can't quite face the fumes and moisture of the catalytic heaters.
John
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is offline   Reply With Quote
Old 10-05-2016, 02:30 PM   #16
Daniel V.'s Avatar
Trailer: '74 Trillium 1300
I have been on a similar quest for a while myself, and came across this one recently...
BISMAR
Not sure about availability and haven't read about any RV install yet, but perhaps worth inquiring about.
Daniel V. is offline   Reply With Quote
Old 10-05-2016, 02:55 PM   #17
tractors1's Avatar
Trailer: Escape 21 - Felicity
Originally Posted by Dudley View Post
Just a heads up folks, you can change out the fan blades in the NE12se, 16se to the new fans from the 16seq. Lowers the noise level quite a bit. If you want it even lower then change the motor or use a voltage regulator or PWM to slow the old motor down a bit. The new blades more a lot more air. The 2 blades are cheap under $15 for the 2
Here is my write up without pictures, (sorry the one with pics is too large to attach) PM me for a copy.
Note that if the motor runs too slowly, there won't be enough air pressure to close the sail switch, which controls the gas valve. This would become even more of a problem as the battery voltage falls while boondocking.
Charlie Y
Old 10-05-2016, 03:36 PM   #18
a good spot....
if a guy had a good and convenient spot to mount this unit in an RV it would be a real winner in my book....heat AND a nice flame to look at....
Old 10-05-2016, 05:16 PM   #19
Patricia D.'s Avatar
Trailer: 1975 Ventura
Manitoba
"Option one is a ProPex furnace. I have done a lot of research on the SH2211 (6,500 BTU. 1.7 amps). I am sure I would be very happy with it but the installation is proving to be more difficult than I am comfortable with. The reasons are quite involved so let me just say that it is still on my list but I am leaning toward the traditional style of RV furnace."
I am just curious about the difficulty of the Propex installation. This was my first choice, if I decided that I really do need a furnace. Is it possible to briefly describe the problems as you see them?
Thanks.
Patricia D. is offline   Reply With Quote
Old 10-05-2016, 05:28 PM   #20
Clayton's Avatar
Trailer: 1975 Trillium
I am extremely happy with my Propex furnace. Super quite, very efficient and you can install it virtually anywhere in the trailer with the supplied ducting. The install is not difficult at all. In fact it is very simple with a minimum of tools. I did get Joe at Trillium Outback to install the LP line but other than that I did everything myself with no problem. Here is the link for anyone interested.
Propex HS2800 Heater Install - Trillium
Clayton is offline   Reply With Quote
Old 10-05-2016, 05:34 PM   #21
Originally Posted by gordon2 View Post
I am also wondering if, with the Atwood side vent option, would it be worth the effort to add ducting that goes through the bottom front of the cabinet to the floor level. I think this may make it quieter and also improve heat distribution somewhat.
The side vent model uses a different fan that draws more power.
stevebaz is online now   Reply With Quote
Old 10-05-2016, 06:12 PM   #22
Dudley's Avatar
Trailer: 1998 Casita 17 SD
Hi Charlie
the new blades are from the NE16seq and when installed on the old motor move a lot more air. Changing out the motor to the 16SEQ motor would be best but also expensive. I used a variable voltage regulator to dial down just the voltage to the motor and have tested it down to below 9v dc and it will still activate the sail switch. Others have tested it over at the casita forum including Gene and have got similar results. Basically this just converts the 12SE and 16SE to a 16seq. The blades and motor are the only difference in them
Old 10-05-2016, 10:12 PM   #23
Trailer: Trillium 4500
John
The Duo-Therm gravity furnace in my 4500 is awesome! Silent and warm. The only thing it lacks is an external thermostat and a lower setting (low=high, med=very high) I just crack a window. I'm tempted to try and source another for spare parts. Why reinvent the wheel. O'yeah, "safety".
Scott H is offline   Reply With Quote
Old 10-06-2016, 07:08 AM   #24
I see that on the specs chart on lower right of page one HERE, all the models are spec-ed at 3.4 amps except for the previously stated discontinued model. I would buy the lower amp model in a minute if it was still being sold.
Old 10-06-2016, 07:52 AM   #25
Thanks.
The complications with the ProPex are related to installation on my Scamp 16 (layout 4). These issues might be different on different trailers and in any case could be overcome. In fact, it is such a nice heater it might be worth the extra effort, it is just adding more complications than I want to tackle. I’m sure that some will think I am getting bogged down in details of little concern but this is how I see it…
The ProPex unit is designed so that a primary installation option is under-floor however there is no room under my trailer for it underneath except at the back, and I do not want to add any more weight at the back since I already have to make an effort to not go under 10% tongue weight. Plus I would have to remove a sewer hose holder that I mounted under the rear floor.
Installation in the lower side cabinet (perpendicular to the camper’s body and under the stove in my case) would probably not leave enough room for ducting. It also makes it very difficult to access the gas connection. I could use it without any duct but that creates more noise and less efficiency since the cold air intake is right next to the hot air output.
The exhaust flue must be between .75 and 2 meters and should terminate at the outside of the trailer and not within specified distances from windows, etc. This is so that exhaust gas does not enter the camper. The exhaust flue can get near 300 degrees heater and should not be run in contact with the wood floor or close to any area that would be damaged by high heat. All this is do-able, just more difficult and ProPex does not even publish safe clearances for the flue and duct so it’s a bit of a gamble. The output duct should not be in direct contact with anything that could be damaged by heat, especially near the heater. The heater also requires about one inch clearance whereas the Atwood is a zero-clearance appliance, making the install simpler.
ProPex install instructions are at: http://www.propexheatsource.co.uk/hs...r-installation
Old 10-11-2016, 01:08 PM   #26
I decided on the Atwood 7912 over the ProPex heater and made a trip to one of the largest RV dealer/Service Centers in the Carolinas who is an authorized Atwood dealer. I took some photos of the Scamp and the cabinet where the furnace goes. I spent about 30 minutes discussing the installation of a furnace in my Scamp with the service department. The first thing I found out was that they were not really familiar with the smallest RV furnaces and upon investigation they said that the 7900 series (as well as the 8012 model) were discontinued. I had my doubts about that so I called Atwood and even they did not seem to know... the exact words were “my best is that yes, they are discontinued.” The Atwood person went on to say they could still be found in the retail chain, or you could use a Suburban furnace. So left on my own I did some more research and it seems that the current offerings from (Dometic)-Atwood is the AFS series. So I am looking at the AFSSAD12, 12,00 BTU input, 9,120 BTU out, 2.4 amps.
I figured I could buy the furnace myself and have the RV place install it. I discussed an option with the technician to use the side vent option on the Suburban or Atwood furnaces. My thought was that by running a short vent to the cabinet overhang so it discharged downward onto the floor, it would be much more comfortable than having the warm air discharged at knee level. This should not be much added work over an above the basic installation.
That is when I found out that the technician thought it would him take about a half day to do it on a Scamp (and to do it so its looks good). So figure 4-5 hours labor… That is at $126 an hour. Ouch.
So, my research continues. I am wondering if the Atwood can be installed with the service door on the outside. It is 12.5 wide by 7.5 high and it looks like the curve of the camper will make it hard to get a good seal on the outside service door. Or should I just use the small (3.5 inch circular) vent hole and plan on removing the furnace when it needs service? Anyone have experience with this?
Old 10-13-2016, 01:53 PM   #27
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
Speed of movement needed by the motor and the power of the motor to generate sufficient CFMs to move the sail switch. That depends on the design of the fan blades and on the quality of the bearings they turn on. There are many blade designs that are superior to the barely good enough blades for "built to cost" products.
One example of poor fan blade design is the truly inefficient fan blades in most RV stove vent hoods that have truly marginal CFM capability given their size and the motor that powers them. An example of efficient blade design is the blades in the Fantastic Fan that are designed for good CFM.
Fan blade design is important and those old RV furnaces did not use very good fan blades in the manufacture of them. But I can't speak as to the blades in newer furnace units as I have not been hands on with one of them.
Old 10-13-2016, 03:03 PM   #28
Raz
Raz's Avatar
Vermont
I would suggest you stick to campgrounds with electrical hookups and buy a $20 electric heater when camping in the shoulder seasons. Sounds like it would be cheaper. Or you can do what we do. Flannel sheets, lots of blankets and a big dog.
furnace
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 08:30 AM
Best methods to fill holes & best glue Becky B Problem Solving | Owners Helping Owners 19 08-11-2012 09:14 PM
Best caulking material? TonyL Problem Solving | Owners Helping Owners 14 12-04-2005 12:35 PM
Best mounted low watt reading lights Kurt & Ann K. Modifications, Alterations and Updates 4 11-24-2005 07:38 PM
Best vehicle for hauling Scamp Legacy Posts Towing, Hitching, Axles and Running Gear 17 01-20-2003 09:17 AM
» Virginia Campgrounds
