Bigfoot axle - Fiberglass RV
Old 08-23-2015, 12:19 PM   #1
Trailer: Bgfoot
Bigfoot axle
I know there has been several conversations about axles, but none of them mention the length of the axle. I am picking up a 1988 bigfoot 17 foot trailer but do not have yet. I am already planning to replace the axle. I am pretty sure it won't go up my driveway. I found a deal for an axle fairly close to where I am picking up the trailer. It is 70 inches between leaf springs and just over 7 feet, rated for 5200 lbs. I realize that it is a little over wt rated, but I plan on replacing the tires, rims as well and probably the leafs.
Thanks for any input.
MAGS is offline   Reply With Quote
Old 08-23-2015, 12:50 PM   #2
Trailer: Class A Motorhome
I don't know anything about a BigFoot 17's axle, but I do know that axle dimensions are usually measured:
a. Face to Face (meaning the brake drum face that the wheel rests against)
b. Spring center to spring center
Old 08-30-2015, 09:14 PM   #3
We just bought the same trailer you are picking up, 1988 b17. You shouldn't need to change the axle. The previous owner changed our axle to spring over. Our leafs are in good shape. 5200lb will be too heavy and will ride stiff. I would wait until you get your trailer to do anything. My bet is you won't have to get a new axle.
Michael Collins is offline   Reply With Quote
Old 08-31-2015, 12:38 AM   #4
The Bigfoot axle from the factory was a 3500# axle. Replacing it with a 5200# axle would require new 6 lug hubs and 12 inch brake drums as well as new rims and tires.
Old 09-02-2015, 10:26 PM   #5
Trailer: Bigfoot 19 ft
I have a 1993 bigfoot 17foot and replaced the axle last year. It has 66 inch spring center and 84 inch face to face. The original axle was 85in long, but i went a little shorter as the tire was rubbing the wheel casing. It fits just perfect now.
Sent from my SM-T230NU using Fiberglass RV mobile app
edward van ruyven is offline   Reply With Quote
axle, bigfoot
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
