10-12-2014, 06:05 AM
Trailer: Scamp 13'
Bike Rack
I've been trying to find a bike rack that actually dosen't take much space. I even took the Scamp to the local shop and was going to have him put a receiver on the rear. After reading forums on how they effect towing I decided not to do that. This fits on top of the bed rails so no underneath storage is lost.
10-12-2014, 07:24 AM
Trailer: U-Haul 1985
That is a sweet setup!
10-12-2014, 07:33 AM
Trailer: Scamp 13'
Thanks... Very simple to make and still have storage underneath for tables, chairs, coolers, lp tanks etc.
10-12-2014, 07:38 AM
Trailer: Scamp 13'
One more picture of rear 2x6.
10-12-2014, 09:45 AM
Great idea Mike, I had considered doing something similar. Could you post a few close ups & details (brand of product) as to what you used and how you mounted the front forks, as well as what use used for securing the rear wheels.
10-12-2014, 05:07 PM
Trailer: Scamp 13'
The front forks are Yakima's with locks. You can find cheaper ones at many bike shops that attach to a board and rest on the front bed rails. The rear 2x6 is attached to the adjustable cargo tie downs again there are various different types of mounts. The rear tires are secured with heavy duty cable ties. This is solid as a rock and will be going across county with them.
04-05-2017, 01:31 PM
Trailer: Oliver
Utah
Bikes in Pickup Bed
Family was just visiting with their Casita. Previously they had one of these bike racks in the pickup bed that held up the bikes. My brother in law complained that the bikes sat in the middle of the bed, and basically took up most of the useable space in the pickup bed. He is a clever guy, and he crafted his own.
The horizontal support is a piece of ABS plastic pipe, sized based upon the width of the pickup bed. This piece of pipe is glued to two ABS tees, with part of each tee cut out with a saw, to fit over the top tube of the bike. A hole is drilled at each end of the ABS pipe, so that an elastic strap or a bungee cord can secure the bike to the pickup. The front wheels tend to move toward the center as the truck moves, but that was solved with boxes of stuff between the front wheels, keeping them apart.
Simple and cheap, and most of the pickup bed is available for other stuff.
David from Salt Lake City, UT
Oliver Elite II Trailer
Audi Q7 Tow Vehicle
04-19-2017, 06:56 AM
Trailer: In the market
Odessa, Florida
I hauled my mountain bikes like this for years across the States. The only problem is when it rains it washes all your bike grease and grime off on the the following vehicle.
04-19-2017, 09:09 AM
If you take one of those bungee ball cords and loop it around the down tube and through the front wheel it will gently hold the wheel in line with the frame. For a road bike this works better than a flickstand with less impact. It also GREATLY facilitates lifting and handling the bike. You can then lift with one hand on the downtube and the other on the seat post without the wheel and the bar flopping around and slapping you in the face.
It makes the bike feel a lot lighter when lifting and the cord can also be used as a bicycle clip to keep your pant leg away from the chainring when riding.
04-19-2017, 09:57 AM
Trailer: 1979 Boler 1700
Our current setup our 2011 Ford Escape towing our Trillium 4500. Haven't tried bringing bikes but I definitely want to bring 2 bikes on some trips. The LEAST complicated cheapest way would be to attach our Thule trunk mount to the Ford Escape hatch, and I will try that first. I don't like the alternatives such as (1) compound front hitch mount, (2) trailer rear hitch mount or (3) tongue mount.
04-19-2017, 10:33 AM
your Trillium is a great trailer but I think it could actually benefit from a tongue mount.
04-19-2017, 10:38 AM
Are there tongue mount hardware kits available? What would be a good tongue mount design?
04-19-2017, 10:46 AM
Tongue mount racks are available from etrailer. Arvika makes a nice one, but expensive. I've adapted a rear mount rack to fit on the tongue, and have seen a couple nice homemade ones.
04-19-2017, 11:17 AM
Here's one I made for a 16Scamp and one I made for my 13Scamp....
04-19-2017, 11:20 AM
platform style bike rack adapted to tongue area (not the hitch)
Looks like it wouldn't be too much trouble to adapt and attach a platform style bike rack to the frame rails in the tongue area. Thoughts?
04-19-2017, 11:27 AM
My Trillium is in Ont. right now getting a new axle. I'll look at it when I get it back...
I would want a solution that I can also use on the Boler 1700 that we're going to start getting camp-able (first want to do some body work, get all exterior lights working, replace the body-to-frame bolts, pull and re-seal the windows, etc).
