Blast from the Past - 1975 Boler Restoration - Page 2 - Fiberglass RV
Old 07-21-2013, 06:40 AM   #21
GMike A's Avatar
I have to add my Kudos along with everyone else. Great work and even the pictures came out pretty doggone good.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 07-21-2013, 07:20 AM   #22
Trailer: 75 boler
Saskatchewan
mike I noticed your doing a project yourself hows that going. And hows the glassing and bondoing going hope it all worked out for you. Nat great protect man. I always like when people half the bolers but that's to ambitious for me.
sheephills is offline   Reply With Quote
Old 07-21-2013, 07:21 AM   #23
Trailer: 75 boler
Saskatchewan
that's going to be one giant window can't wait to see what it looks like when you install it.
Old 07-21-2013, 07:34 AM   #24
GMike A's Avatar
Right now I am on temp hold. I had both of my big toe toe nails removed sequentially and I cant bend down on my knees otherwise when I get up all the pressure is on the flex points of my toes and it just messes things up. With that being said all of my fiberglassing is done!!!. Right now I was in the process of removing all of the rusted out screws that were holding the OSB down. Apparently the Casita uses only those dozens of screws to hold the shell to the frame as I dont see any other bolts U or otherwise. So I will replace the back half floor and re-anchor using a flat washer to distribute the hold and then move to the front section. This way I will keep the shell aligned properly. I am pleased with the progress just not the outside 90+ temp and humidity.
Mike
K5NAN
"Miss Adventures"
Old 07-22-2013, 11:57 PM   #25
Nat
Trailer: 75 Boler
B.C.
I could be cutting 800sqft of reclaimed maple into herringbone and making my house livable again... or I could feed my boler addiction!
I'm just kind of winging it as I go, but here's the basic idea of what I'm doing.
Don't mind the duct tape, my piece of plywood had a small curve to it. I took care of that problem.
Basically I cut out the frame, mounted and leveled it until I was happy. cut and resined a few pieces of an old t-shirt to get a platform for the fiberglass. I added a layer of cloth today. By the time I'm done I expect to have a few layers of cloth on the outside and a few layers of mat on the inside, maybe some roving will be added too for extra strength.
I'm happy with where it sits, the top I hope will act as a kind of gutter system, so rain flows away from the window. I'm also planning a wrapped around counter on the inside of that window so the 4'' indentation wont be much of a problem.
The last couple pictures are for if I get bored and feel like tinkering with the brake lights.
Nat is offline   Reply With Quote
Old 07-24-2013, 01:33 PM   #26
Nat
Trailer: 75 Boler
B.C.
Question to others who have done extensive work on your trailers. Have you ever exceeded the maximum weight allowance of 2200lbs? Would it be worth upgrading to the torflex #10? Also i couldn't find any measurement on site of the track width of either axle, are they roughly the same?
Thanks,
Nate
Old 07-26-2013, 08:11 AM   #27
Night Sailor's Avatar
Connecticut
Originally Posted by Nat View Post
My "slightly" only refers to a few hours, pending on how long it takes the resin to set up.
More than slightly? How much more time do you think we're looking at here Donna?
That sort of job requires an hour a day for 3-4 days, perhaps less time per day. I suggest making templates so each side's shape is a mirror image of the other.
It's easy. Of course I tell myself every job is easy now. It keeps me motivated.
Old 07-26-2013, 08:16 AM   #28
Connecticut
Given what others trailers tend to look like, I'd say mines in pretty decent shape. Nonetheless it will all be replaced.
I recommend hot dip galvanizing the whole thing when you are done. It is not expensive and you won't have to sandblast the paint off--in the case of an old frame, or sandblast the rust off--if painting. It lasts forever, looks good, and holds up to salt or whatever you throw at it. Cost is 45 cents a pound ( weight if the steel being galvanized) over here.
Something to think about.
Old 07-27-2013, 09:02 PM   #29
Nat
Trailer: 75 Boler
B.C.
Updates of the windows sitting in their frames.
Old 07-27-2013, 09:06 PM   #30
Nat
Trailer: 75 Boler
B.C.
Also open to opinions on either...
American Cherry
or
Brazilian Teak
I'm leaning towards the teak for many reasons, but think the color of the cherry would really liven the place up.
Old 07-27-2013, 09:34 PM   #31
Which wood is lighter in weight and/or take the most abuse?
Old 07-27-2013, 10:45 PM   #32
GMike A's Avatar
Teak wont rot on you. You are very gifted. I feel like I want to put a band aide on her now.
Mike
K5NAN
"Miss Adventures"
Old 07-27-2013, 11:18 PM   #33
Nat
Trailer: 75 Boler
B.C.
I think I have about 150sqft of Teak, its 3/4" and it weighs about 5lbs per sqft. Its very heavy and very nice wood.
Janka Hardness Test Ranges from soft to hard 22-5060 (pounds-force) = Teak rates 3540
I have 300sqft of Cherry, its 1/4", probably weighs less then 1lbs per sqft. Only real benefit is its light weight and its a much warmer color than the teak.
Janka Hardness Test Ranges from soft to hard 22-5060 (pounds-force) = Cherry rates 995
Just comes down to practicality or warmer looks
boler
Boler Restoration hudson Modifications, Alterations and Updates 13 07-03-2012 04:43 PM
Old boler for restoration - $800 David Tilston Referrals: Molded Fiberglass Trailers 2 06-20-2012 03:39 PM
Total Boler Restoration Jenny Jones Modifications, Alterations and Updates 16 09-02-2011 07:44 PM
Boler Restoration Kevin Dunno Modifications, Alterations and Updates 2 06-21-2009 04:42 PM
1976 Boler Restoration petramarc Modifications, Alterations and Updates 7 06-04-2006 10:33 PM
