Boler door hinge - Fiberglass RV
Old 12-01-2016, 08:15 AM   #1
DrKyle1's Avatar
Trailer: '71 Boler
Boler door hinge
Before I ordered from Scamp trailers I wanted to see if anybody else has a different source for Boler style door hinges need to replace mine...
Sent from my SAMSUNG-SM-N920A using Fiberglass RV mobile app
DrKyle1 is offline   Reply With Quote
Old 12-01-2016, 08:29 AM   #2
Scamp hinges are three bolt. Boler hinges are two bolt. The Scamp door hinges are NOT a direct replacement for Boler door hinges. There's probably nothing wrong with your hinge, other than the fact that I see the spring is missing. You may want to get the bolt, spring and brass ball from Ian Giles. Boler Parts - Boler-Camping
Old 12-01-2016, 10:42 AM   #3
DrKyle1's Avatar
Trailer: '71 Boler
The guts are new but the hinge itself is buggered up. I just have it too tight in the pick to see the spring...the cup that the brass ball sits in has been deformed by wrong parts from PO so need to replace
Old 12-01-2016, 12:31 PM   #4
Ian G.'s Avatar
Hi Kyle, I sure we have chatted and gone into detail about the condition of your Boler hinges. I tend to agree that the wear is extreme and replacement is the best option. Scamp is the only hinge that will work as a replacement. Their mounting is different as is the offset of the leaf sections so the best way to mount Scamp hinges is to drill all new holes.
I recommend that you measure the total length of the door which I think you will find is about 63" long. If you mount the hinges at the 1/3 and 2/3 locations (21" & 42") from the top the door will open wide against the side of the trailer without hitting the belly band.
boler
Door hinge repair kit for Boler or Trail Mite KenandJaney Problem Solving | Owners Helping Owners 2 07-16-2012 09:56 PM
The subtle mysteries of the Boler Door hinge sara maccalman Problem Solving | Owners Helping Owners 21 09-01-2011 04:50 AM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
boler door hinge pins Ben, Vanden Berg Problem Solving | Owners Helping Owners 9 07-23-2009 12:25 PM
