Boler reno help needed - Page 2 - Fiberglass RV
Old 05-15-2012, 05:58 AM   #15
Ian G.'s Avatar
Originally Posted by Frederick L. Simson View Post
I think the hardest part would be to match the curve across the back of the trailer in the folding or sliding part.
I agree that the hardest part of a sliding futon style would be the curved base and back needed.
I am completely changing the interior floor plan of my Boler. Larger kitchen and true double size (54") bed. A warning that it is a tremendous amount of work, if you have removed the closet and kitchen support to the upper cupboards you will need to build some manner of wall and roof supports as structural members.
Here is an diagram of my floor plan, the build is well underway with the plan to take it for its maiden voyage in early June.
Old 05-15-2012, 06:39 PM   #16
I'm sure the layout is more functional for you. But, I have to ask... are there any internal supports from floor to ceiling? These molded trailers are like a balloon and require support, usually at the door and across from the door.. as in a floor to ceiling cabinet. Without supporting the roof eventually the sides start to bulge out and the door becomes illfitting. And then...
Old 05-15-2012, 08:51 PM   #17
Ian G.'s Avatar
Hi Donna, if this is referencing my post yes there are 4 wall to ceiling supports in my design. One on each side of the door and one one each side mid-cabin. The design of my supports are a curved lamination so they hug the walls only sticking out 1 1/2" they follow the wall and into the ceiling area the same distance as the factory supports. They are epoxy bonded directly to the fiberglass shell their entire length which makes them considerably stronger than the factory supports and there are no stress points at the pop rivets where cracking often occures.
Old 05-15-2012, 08:52 PM   #18
Cool beans Ian!!
Old 05-19-2012, 10:09 AM   #19
Robert Johans's Avatar
Trailer: Nest Caravans
My 1971 Boler restoration featured a galley in front and a 54" bed in back...
boler
Boler door sag fix help needed Michael Collins Problem Solving | Owners Helping Owners 46 06-11-2016 03:32 PM
BOLER RENO - 17' - Not bad for a newbie! Dawn S Modifications, Alterations and Updates 20 09-06-2009 12:50 AM
Boler Reno pics David Konduc Modifications, Alterations and Updates 1 08-20-2009 05:57 PM
Boler furnace info needed James Problem Solving | Owners Helping Owners 4 11-03-2007 02:16 PM
Reno advice needed randyl Care and Feeding of Molded Fiberglass Trailers 12 03-29-2006 07:52 PM
