05-24-2013, 03:13 PM
Trailer: 1982 13ft Scamp purchased on May 2nd
Brakes on 13'
Getting new tires on the 82 Scamp and find out there are drum brakes on it that aren't hooked up. What's THAT about?!?!
05-24-2013, 03:20 PM
My guess: one previous owner realized that it should have brakes and had them installed; a later previous owner (or even the same one) decided they didn't want to maintain them and stopped using them. If it has only a 4-pin electrical connector to the tug, someone may have started towing with a vehicle without brake wiring and rather than equipping the tug, abandoned the trailer brakes.
05-24-2013, 03:28 PM
Connector from Scamp is a 4, but wires look to have been hacked somewhere along the way.
05-24-2013, 03:32 PM
Also...
They're drum brakes, but are they electric or hydraulic? Someone could abandon electric brakes because their tug is not set up with a controller and wiring (see above post); they could abandon hydraulic surge brakes if the coupler/actuator failed and they didn't bother to fix it.
05-24-2013, 03:36 PM
I would recommend to you that you get the brakes fixed. If they are all rusty and messed up you can install new ones very cheaply (just 4 bolts to remove). You'd need to add a controller to your tow vehicle.
Brakes make towing a lot nicer - stops are faster and smoother and you can stop trailer sway with the manual switch on the controller.
05-24-2013, 03:42 PM
Courtney did the PO replace the axle by chance? If so it may be the trailer didnt have an axle that allowed for brakes and they replaced they decided to have an axle and brake drums added but never got around to having the brake wiring added or the pads added... just another possibility.
05-24-2013, 06:25 PM
Unfortunately, I never met the true PO. The person I bought it from got it at an estate sale and flipped it :-/
05-24-2013, 07:08 PM
There are one or two Youtube videos that tell you how to test your brakes to see if they are functional. Essentially hooking a battery up the magnets and see if they activate the pads. Others can provide more data. I replaced both of mine with brand new all the way around rather cheaply but you can replace individual components if you so desire.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
05-24-2013, 07:22 PM
As Carol mentioned, brake drums don't necessarily mean you have brake shoes (magnet and springs either). Have you looked?
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Brakes
Rick Mooyman |
7 |
02-08-2012 06:13 AM |
? on brakes
thunter |
11 |
02-04-2012 06:33 PM |
Brakes
Roger C H |
9 |
01-12-2012 08:44 PM |
Brakes
JasonWesterman |
3 |
12-04-2011 03:04 PM |
brakes or no brakes
Penney H. & Mike E. |
17 |
08-13-2007 02:35 PM |
