Breaking news - Scamp moving to 8-ply D-rated tires - Page 5 - Fiberglass RV
Old 10-23-2022, 06:44 AM   #81
Tire pressure
I have a Scamp 13 with Carlisle D tires. I run them at 55 psi and this works well for me. I always check both hub and tire sidewall temp at gas stops and they run cool to the touch.
John DL is offline   Reply With Quote
Old 10-23-2022, 08:54 AM   #82
Dittto.. Carlise's response is worth the paper it is written on, and that only assuming that you read it on a PC or tablet and don't hit the print button. In other words, useless.
I run my Carlise LR D tires (max 65 PSI) at 60 PSI all the time and the temp reading on the TPMS is fine. 50 or 55 might be OK but with a good axle I don't see much bouncing even at 60 PSI.
Old 10-23-2022, 12:54 PM   #83
Roy in TO's Avatar
Originally Posted by Roy in TO View Post
Choosing the 175/80R13 load range D 6H04521 because I thought it would have a stiffer sidewall to accommodate any effect of side/cross winds.
Load Range C is rated @ 1360 Lbs @ 50 PSI
Load Range D is rated @ 1570 Lbs @ 65 PSI
After reading this post:
https://www.fiberglassrv.com/forums/...tml#post849760
Can't tell you the tongue weight. Steer Axle: 2920 lbs, Drive Axle: 2960 lbs, and Trailer Axle: 2800 lbs, for a gross weight of 8680 lbs.
The D Range is likely better suited to a Scamp 5th wheel or similar.
scamp, tires, vin
Bias Ply Tire Life? bobinyelm Towing, Hitching, Axles and Running Gear 10 03-07-2014 09:21 PM
Radials v. Bias Ply Tires for 2008 16' Scamp JenSho Towing, Hitching, Axles and Running Gear 2 09-18-2013 05:00 PM
bias ply or radial tires Mr.Gauch Towing, Hitching, Axles and Running Gear 14 10-26-2011 12:28 AM
Good News -- Bad News Pete Dumbleton Towing, Hitching, Axles and Running Gear 2 11-06-2008 12:16 PM
D rated 14 inch TRAILER TIRES? Bob Radenbaugh Care and Feeding of Molded Fiberglass Trailers 4 12-21-2007 10:14 AM
