Building a new Bigfoot rock cover - Page 2 - Fiberglass RV
Old 08-24-2016, 01:49 AM   #15
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
It does indeed look good. Great progress and good inventive problem solving as you go along.
Old 08-29-2016, 10:24 PM   #16
Trailer: Bigfoot 19'
moving along
Well Since I last posted I have attached the two Pieces togeather using a jig that represented the angle of the front of the trailer. I have done one test fit and found success is near.
I now have flipped the unit over to expose the glass side of the cover and placed two more layers of CSM where the junction of the two pieces join. .
So far I have gone through the better part of a gallon of resin and 5 yards of CSM. I think I went way to heavy on the resin. No mater its all about learning and creating.
The other evening I took some time to make up some hinges using angle aluminium. I'm going to look for a nylon ball like object to use as a bearing and perhaps use that as a part of the mechanism to compensate for the hinges on opposing plane issue. Much like a Boler door.
Any thoughts on the hinge issue.
Also I will need some mechanism to prop the cover up while camping. Any recommendations? I was thinking gas jacks but I am concerned about torquing the cover as it lifts by the uncontrollable force applied during the lift.
I am open to inspiration at this point. Any thoughts?
Richard
evenweight is offline   Reply With Quote
Old 08-30-2016, 01:31 AM   #17
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Originally Posted by evenweight View Post
So far I have gone through the better part of a gallon of resin and 5 yards of CSM. I think I went way to heavy on the resin. No mater its all about learning and creating. Richard
Looks good Richard. I do believe you'll have the strongest "boulder" guard on any TT .
Old 08-30-2016, 08:25 AM   #18
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
I'm not sure when Bigfoot switched to gas struts, but the early 80's models used manual sliding braces with locking wingnuts. These in the link look like the same ones.
Window Rock Guards
Old 08-30-2016, 10:41 PM   #19
boulder guard
I think you are right boulder guard is a term that fits.
If I were to do this again I would...
Make a foam form of the entire part (both parts together) I wanted to make. I would use plastic and packing tape to make sure the foam for would pop out of the new part. I would use West System Epoxy so that there would not be the big smell that I have had to tape the garage door shut.
I would lay four layers of glass at least in quick succession in order to keep weight and time down on the project. The glass cloth would probably give a better or easier finish at the mend of the project as well.
I haven't any regrets so far. But then again I have not drilled any holes in the trailer. YET
Old 09-06-2016, 10:47 PM   #20
Well last night I gel coated the under-side of the cover tonight I did the outside. Now to move the thinking parts to hinges, lifts and hold-downs.
Given the angles on the front of the trailer I think I will use Bondo to put a 3.75 mm wedge under the hinges so that they will be on a straight plane. Once I get the cover on I will have a chance to observe the action of the cover and how much room I actually left myself inside.
bigfoot
Nest Caravans Building a new FG trailer, step by step Robert Johans General Chat 569 06-30-2017 04:56 PM
Building your own rock guard? SnappleofDiscord Problem Solving | Owners Helping Owners 4 09-18-2012 07:37 PM
Building new door? bgeery Problem Solving | Owners Helping Owners 1 09-19-2009 04:40 PM
Building a new frame from scratch....... ursulap Care and Feeding of Molded Fiberglass Trailers 10 09-02-2009 08:43 PM
» Virginia Campgrounds
