07-07-2014, 04:47 AM
Trailer: 1972 Trillium
Nova Scotia
Building a Screen Door
Hello
I have a 1972 Trillium. I want to build a screen door. I 'm sure I saw details here somewhere where someone build one. I can't find much in my search. Can someone provide a link? Thanks
Harvey
07-07-2014, 06:00 AM
Name: Norm and Ginny
I can't find our screen door information on the web site but here's a short description of what we did. If you're interested I'll take some pictures.
We went to Lowes and purchased a window screen kit. I made two screens and purchased a few small hinges and formed them into a folding door. I attached a fitted piece of wood to the cabinet on one side of our door way and attached the folding door to it. It closed against a similar piece mounted on the otherside.
The screen door is light and works very well. It is held closed by two magnetic latches. When it folds against the wall it is held in place by two other magnetic latches.
If you're interested PM me and I'll take and post some pictures.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
07-07-2014, 06:43 AM
Screen Door Pictures
Here are a few pictures of our approach to a screen door. If you ever what finer details let me know,
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
07-07-2014, 07:13 AM
Trailer: 1994 Scamp 16
Arkansas
Norm,
That door looks just like a Factory built job! Great workmanship! That door will do the job and let in plenty of fresh air!!!! And, keep out the bugs!
Carl
07-07-2014, 07:30 AM
It works very well to keep the bugs out.
We seal the hinge end of the door by letting the screening extend beyond the edge of the white door and tacking it to the wooden piece on the cabinet wall.
We seal the bottom of the door the same as the hinge side. except with out tacks. When we installed the screening in it's white frame we left a couple of inches over lap at the bottom which drags on the floor and seals the bottom gap.
We seal the center gap between the two pieces of the door with a piece of foam insulation that sticks to one side of the door and seals against the other side in the center when the door is closed.
The door closes against a wooden lip on the left side and top. At the top we have a piece of soft foam insulation as a seal.
The door was my first attempt and in retrospect I could do better in terms, particularly in terms of 'look-ability'. As to function it works pretty well better than some I've seen with small gaps here and there.
Thanks for the kind words.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
07-07-2014, 07:47 AM
Gord100 is often quoted and referenced.
Gord100's Trillium Trailer Webpage
07-07-2014, 08:04 AM
Norm/Ginny, that screen door look like the factory one that came on my new Scamp. Can't tell the difference. Likely homemade is cheaper too! If you don't want to do the work you can probably buy one from them.
07-07-2014, 11:18 AM
North Florida
I have the factory screen door on my Scamp with one mod. I took off the knob and bolted a doubled piece of 1" nylon strap in its' place. I kept bumping the knob coming and going (mostly while installing the new A/C) and decided it was quick and easy enough to change.
07-07-2014, 11:30 AM
It probably doesn't show in the pictures, we use a cabinet knob on the inside and a knitted cord on the front.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
07-08-2014, 09:43 AM
I just got a magic mesh like magnetic door, and cut down to size. We have two little kids, so as they go in and out the screen closes itself. Also when taking stuff in and out we don't need a free hand to open the screen.
07-08-2014, 10:05 AM
North Florida
This seems like an ideal usage for a magnetic screen door, wish I had thought of it!
07-09-2014, 09:16 AM
Nova Scotia
Thanks for all the info.
Harvey
07-23-2014, 11:17 PM
West Virginia
How did you attach the Magic Mesh Magnet screen to your camper doorway?
07-24-2014, 02:53 PM
I plan to do it install another magnetic screen on my Red Boler, and will document it on this forum as it will have the original parts.
On my green trailer I was rebuilding it, so using the rivet holes for the drip cap above the door, I used screws from the outside to attach a piece of wood trim on the inside. Along the closet I ran a piece of trim down to the floor. These pieces where used to hold the screen in place.
I took the metal support off that helps keep the curve of the trailer and reinforces the door (on the bunk side) and replaced it with a wood piece I made. This allowed me to bring the wood out enough to make a vertical surface to attach the screen to.
Boler Screen Door installed | Family Outdoor Adventures
I plan to install one when I am back form my next trip, so in two weeks, and will be doing it without the need for so many custom pieces.
I also used speed sew fabric glue, as I do not have use of a sewing machine.
It is on it's second season now, sometimes the plastic pieces that hold the magnets open up, so I have used epoxy to glue them shut. I also had a piece of the screens fabric trim rip (users fault), so on the next one I plan to reinforce the outer trim.
07-24-2014, 05:48 PM
Originally Posted by Roy in TO
Roy THANKS for posting this. I've been hunting for Gord100's site since the Antitomato site went elsewhere. Cool beans!
06-24-2018, 07:46 PM
Trailer: Trillium 1979 13ft.
Screen door
How does one attach screening to wooden door frame? I don't have the tools or know how to rabbet the wood to hold screen plastic retainer rope...
06-24-2018, 07:57 PM
Trailer: 2012 Escape 19
The ropey stuff is called spline (I learned that last summer when I built a wood screen door for our back sunroom). I cut a groove in the wood that the spline would fit into. Best tool is a router, but I do not have one so I used a wobble blade on my table saw.
Some people have metal frames with screens made and insert them into the openings of the wood door. The outer face of the door is made with a lip that the frame butts up against, and some plastic clips on the inner face swivel on screws to hold from the other side.
A less elegant scheme woild be to lay the screen across the wood and tack the wood strips over the edges all around... but screen replacement later on would be messy.
Someone far handier than I will probably suggest an even better way.
06-24-2018, 08:14 PM
Screen Door
Well, I haven't used my router or table saw in over 8 years so I got rid of them! Typical..NOW I need them! Lol! Getting metal framed inserts might be pricey, but will check into that. Wooden strips won't let me tighten the screening enough. I must think this thing out. Thanks for your speedy reply!
06-25-2018, 05:38 AM
I am in the process of replace the wooden screens on the family camp with new wooden frame screens. Originals are from 1932 so they have some problems. I am using mahogany and mitering the corners of the frames with biscuits at each. Before assembly I am running the wood members through the table to cut the groove for the spine. My spline is about 1/8 wide. I do a groove on scrap to figure out the width I want then run the members through. I did four last year and just finished two more for this year. I think this method would work well for a trailer door.
