Building a Screen Door - Fiberglass RV
Old 07-07-2014, 04:47 AM   #1
Trailer: 1972 Trillium
Nova Scotia
Hello
I have a 1972 Trillium. I want to build a screen door. I 'm sure I saw details here somewhere where someone build one. I can't find much in my search. Can someone provide a link? Thanks
Harvey
Harvey9 is offline   Reply With Quote
Old 07-07-2014, 06:00 AM   #2
honda03842's Avatar
Name: Norm and Ginny
I can't find our screen door information on the web site but here's a short description of what we did. If you're interested I'll take some pictures.
We went to Lowes and purchased a window screen kit. I made two screens and purchased a few small hinges and formed them into a folding door. I attached a fitted piece of wood to the cabinet on one side of our door way and attached the folding door to it. It closed against a similar piece mounted on the otherside.
The screen door is light and works very well. It is held closed by two magnetic latches. When it folds against the wall it is held in place by two other magnetic latches.
If you're interested PM me and I'll take and post some pictures.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 07-07-2014, 06:43 AM   #3
honda03842's Avatar
Screen Door Pictures
Here are a few pictures of our approach to a screen door. If you ever what finer details let me know,
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 07-07-2014, 07:13 AM   #4
Trailer: 1994 Scamp 16
Arkansas
Norm,
That door looks just like a Factory built job! Great workmanship! That door will do the job and let in plenty of fresh air!!!! And, keep out the bugs!
Carl
Nut501 is offline   Reply With Quote
Old 07-07-2014, 07:30 AM   #5
honda03842's Avatar
It works very well to keep the bugs out.
We seal the hinge end of the door by letting the screening extend beyond the edge of the white door and tacking it to the wooden piece on the cabinet wall.
We seal the bottom of the door the same as the hinge side. except with out tacks. When we installed the screening in it's white frame we left a couple of inches over lap at the bottom which drags on the floor and seals the bottom gap.
We seal the center gap between the two pieces of the door with a piece of foam insulation that sticks to one side of the door and seals against the other side in the center when the door is closed.
The door closes against a wooden lip on the left side and top. At the top we have a piece of soft foam insulation as a seal.
The door was my first attempt and in retrospect I could do better in terms, particularly in terms of 'look-ability'. As to function it works pretty well better than some I've seen with small gaps here and there.
Thanks for the kind words.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 07-07-2014, 07:47 AM   #6
Roy in TO's Avatar
Gord100 is often quoted and referenced.
Gord100's Trillium Trailer Webpage
Old 07-07-2014, 08:04 AM   #7
North Dakota
Norm/Ginny, that screen door look like the factory one that came on my new Scamp. Can't tell the difference. Likely homemade is cheaper too! If you don't want to do the work you can probably buy one from them.
Gene Masse is offline   Reply With Quote
Old 07-07-2014, 11:18 AM   #8
Timber Wolf's Avatar
North Florida
I have the factory screen door on my Scamp with one mod. I took off the knob and bolted a doubled piece of 1" nylon strap in its' place. I kept bumping the knob coming and going (mostly while installing the new A/C) and decided it was quick and easy enough to change.
Old 07-07-2014, 11:30 AM   #9
honda03842's Avatar
It probably doesn't show in the pictures, we use a cabinet knob on the inside and a knitted cord on the front.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 07-08-2014, 09:43 AM   #10
I just got a magic mesh like magnetic door, and cut down to size. We have two little kids, so as they go in and out the screen closes itself. Also when taking stuff in and out we don't need a free hand to open the screen.
Nelmes is offline   Reply With Quote
Old 07-08-2014, 10:05 AM   #11
North Florida
This seems like an ideal usage for a magnetic screen door, wish I had thought of it!
Old 07-09-2014, 09:16 AM   #12
Nova Scotia
Thanks for all the info.
Harvey
Old 07-23-2014, 11:17 PM   #13
West Virginia
How did you attach the Magic Mesh Magnet screen to your camper doorway?
Barbe is offline   Reply With Quote
Old 07-24-2014, 02:53 PM   #14
I plan to do it install another magnetic screen on my Red Boler, and will document it on this forum as it will have the original parts.
On my green trailer I was rebuilding it, so using the rivet holes for the drip cap above the door, I used screws from the outside to attach a piece of wood trim on the inside. Along the closet I ran a piece of trim down to the floor. These pieces where used to hold the screen in place.
I took the metal support off that helps keep the curve of the trailer and reinforces the door (on the bunk side) and replaced it with a wood piece I made. This allowed me to bring the wood out enough to make a vertical surface to attach the screen to.
Boler Screen Door installed | Family Outdoor Adventures
I plan to install one when I am back form my next trip, so in two weeks, and will be doing it without the need for so many custom pieces.
I also used speed sew fabric glue, as I do not have use of a sewing machine.
It is on it's second season now, sometimes the plastic pieces that hold the magnets open up, so I have used epoxy to glue them shut. I also had a piece of the screens fabric trim rip (users fault), so on the next one I plan to reinforce the outer trim.
Looking for screen room or screen panels Deb & Chuck Classified Archives 0 09-19-2009 04:07 PM
Building new door? bgeery Problem Solving | Owners Helping Owners 1 09-19-2009 03:40 PM
"Green" Building Ideas Frederick L. Simson General Chat 0 06-28-2009 02:10 PM
Are they still building Burro trailers? Monica M General Chat 7 12-01-2008 09:35 PM
