Bulbs Replaced With LED's in Escape - Fantastic! - Fiberglass RV
Old 05-27-2008, 09:03 PM   #1
Trailer: 2006 Escape
Summer finally arrived and we've pulled our Escape out of storage. Over the weekend, we replaced all of the incandescent light bulbs with LED towers from Autolumination. They work great. We 've used the superbright white ones and the light looks very much like flourescent light. These things draw almost no current so anyone concerned with conserving their battery should strongly consider switching to these LED's. They aren't that expensive, they drop right in to the existing fixture (at least in the Escape, don't know about other makes) and will significantly outlast the conventional bulbs.
Doug
dkdavies is offline   Reply With Quote
Old 05-27-2008, 10:04 PM   #2
Trailer: Escape
Can you post the website link for the bulbs?
Thanks, it sounds like a good idea.
Thane is offline   Reply With Quote
Old 05-27-2008, 10:16 PM   #3
Trailer: 1970 Campster
I just looked it up. . . www.autolumination.com.
Lisa H. is offline   Reply With Quote
Old 05-28-2008, 03:59 PM   #4
Trailer: 19 ft Escape
Hi Doug
Didn't know there was another Escape here in Terrace. Did you buy your bulbs here in town or order them? Do you have a part or bulb number. We would like to do the same as you and change over the bulbs.
Ellen Smith is offline   Reply With Quote
Old 05-28-2008, 05:18 PM   #5
Chester Taje's Avatar
Hi Doug
Me too
Old 05-28-2008, 06:53 PM   #6
Hi Ellen et.al,
I see the link to the autolumination site has been posted. Just search for LED Tower and the ones we have are the T10 versions. They are very bright and work fine for us. The are others with more LED's but I think that's overkill, especially in something as small as our Escape. Remember also that each tower only draws 0.085 amps of current. Compare that to the 1.075 amps drawn by one incandescent bulb and you can readily see the advantage. To put it in perspective, you could put LED towers in every fixture in the Escape, turn them all on at the same time and still not draw as much current as one incandescent bulb. Major savings on battery energy.
We also installed a 24-LED dome light over the dining table. This required some "creative engineering" as I installed it right next to the existing fixture and wired it into a toggle switch mounted in the rear of the fixture. It provides double the light of the LED tower and will be used for reading, etc.
Doug
Old 05-28-2008, 07:21 PM   #7
Hi Ellen et.al,
Doug
Old 05-28-2008, 07:22 PM   #8
Gina D.'s Avatar
West Coast USA
All of my fixtures have come from autolumination. I have 4 of the 24 LED Domes and have wired in the same up front, behind two existing fixtures.
The ones in the back have thier own switches mounted on the bottom side of the rear cabinet.
A word of caution on the towers. They are voltage sensitive. Anything over 14.5 will start popping LEDS in the array. The domes seem a bit less picky, but my old converter has smoked a couple of them when it shoots up to 16vs periodically.Keep n eye on the converter and what it's upper voltage throwing is.
If I am going to use the LEDs, I run off the battery. As you mention, they won't put a dent in it.
When converter is on, I use the incandescents.
Old 05-28-2008, 09:39 PM   #9
Thanks for that tip, Gina. I will monitor the voltage on our converter and see what it's doing when hooked up to shore power. Sounds like I need to install both a volt and amp meter permanently in the Escape to keep an eye on what's going on. Don't know where I'd mount them offhand but it's something to consider.
Doug
Old 05-31-2008, 11:28 PM   #10
peterh's Avatar
Doug
What I did was make a voltage regulator circuit that guarantees my LEDs don't get more volts than is safe for them.
escape, led lights, lighting
LED bulbs Perry Mac Donald General Chat 6 01-27-2010 01:51 PM
correct bulbs Flygal Problem Solving | Owners Helping Owners 10 04-18-2009 04:20 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
LED taillight bulbs Alistair Camelford General Chat 9 11-10-2006 12:39 PM
Bulbs and Lighting Legacy Posts Modifications, Alterations and Updates 11 05-15-2003 09:53 AM
