Bunk Support Posts - Fiberglass RV
Old 07-16-2016, 08:41 AM   #1
Name: Steve in NY
Bunk Support Posts
I'm just about finished rehabbing a 88 Scamp 16. The front bunk has a couple of support posts. My question is what holds them captive at the top. There is a about a 1" post that fits in a socket at the bottom, and little loop welded to it that supports the front edge of the top bunk. But it seems there should be something that captures the top of this post to prevent it from accidently slipping out and causing what would be big trouble to an upper and lower bunk occupant.
Please help clarify.
Thanks,
Steve
Steve in NY is offline   Reply With Quote
Old 07-16-2016, 08:47 AM   #2
Trailer: 2014 Escape 21
Virginia
There is suppose to be two screw heads sticking out under the seat back that set in the post loops when the post are in place.
Eddie
Eddie Longest is online now   Reply With Quote
Old 07-17-2016, 12:56 PM   #3
Clayton's Avatar
Trailer: 1975 Trillium
I just finished reinstalling the bunk back in our Trillium 1300. I actually changed the original legs to Ikea desk legs. They are super solid and only required a few modifications. Really happy with the result.
Name:	ImageUploadedByFiberglass RV1468781761.606100.jpg
Clayton is offline   Reply With Quote
Old 08-07-2016, 07:35 PM   #4
The screws should be tightened so that you cannot remove the pole without removing it from the bottom flange. On mine, that means I cant the pole in about 20 degrees, attach it to the screw, then pivot bottom into the flange.
Sent from my iPad using Tapatalk
chrischampion is offline   Reply With Quote
Scamp front bunk modification to support adults John Carter Modifications, Alterations and Updates 17 06-23-2017 01:31 PM
bunk bed support rrank Care and Feeding of Molded Fiberglass Trailers 8 06-27-2014 07:27 AM
What's behind a 19' scamp bunk support? Jared J Care and Feeding of Molded Fiberglass Trailers 2 03-09-2013 07:51 PM
front bunk support collapse CharleneM Problem Solving | Owners Helping Owners 5 09-12-2010 07:07 PM
"View New Posts": can I exclude For Sale posts? E. Graham Forum Admin, News & Announcements 4 07-20-2008 11:59 AM
