Burro air conditioner mod - Page 2 - Fiberglass RV
Old 08-10-2016, 07:55 AM   #15
Trailer: 85 Uhaul CT 13
Darral T.
My unit is a 3 yr old, 5K unit. You are correct on the purpose of the splash system; however not mfg for enclosed use in camper. The unit is to be sealed with no drain hole; however without the wheel the water had no place to disperse so I drilled a 1/2 hole for water to drain.
Sent from my LG-E980 using Fiberglass RV mobile app
George Lauver is offline   Reply With Quote
Old 08-10-2016, 07:59 AM   #16
GE designed "Carry Cool" A/C's years ago (5K). I drilled a hole in that one too. I have it in my workshop and about 30 yrs later, it's still running perfectly! (Ran it last nite matter of fact.) Not trying to get "political", but thank our Gov. for some of these changes and I just read where they're going to be coming down on these small units even MORE in the near future! Good luck with your unit.
I wish the OP would respond to my question about the side louver vent mounted beside his A/C.
Originally Posted by George Lauver View Post
Darral T.
Old 08-10-2016, 10:30 AM   #17
Trailer: 1998 burro 17'
i am thinking its for an intake for the condenser which is why i would bring in outside air from a floor or side mounted external intake to be more efficient
george w is offline   Reply With Quote
Old 08-10-2016, 10:36 AM   #18
My thinking exactly George! Looks like this would GREATLY hamper the cooling ability internally...fighting against itself? I've seen others install an extra fan in the rear cooling dept to help circulate the hot air out of there which is precisely what I would do.
Old 08-10-2016, 02:58 PM   #19
Trailer: Burro
Iowa
The vent does indeed bring in air to the unit. Since the unit is enclosed I wanted to ensure it had enough air supply to run the unit. The hot exhaust air is vented completely outside the camper and is not allowed to recirculate. Yes there is recirculation of air but it is the cool not the hot air that re-enters the intake. Hopefully that keeps the efficiency in check. As far as the water this unit does not recirculate the water. It drains out a hose and eventually outside the camper.
Mtanner is offline   Reply With Quote
Old 08-10-2016, 03:18 PM   #20
Thanks Mike and keep us posted on how it works if you can. This stuff is interesting to me.
Old 08-10-2016, 03:28 PM   #21
Trailer: Burro
Iowa
Will do. I can tell you it is about 95 with a heat index of 105. I turned it on and in about 15 minutes it was 78 and felt comfortable inside. I imagine when the sun goes down it will cool off more.
Old 08-10-2016, 03:30 PM   #22
That's super and PLENTY of cool for the day. I usually set my digi thermostat to 67-68 at night in my 13' Scamp. Sounds like you nailed it.
Old 08-10-2016, 05:31 PM   #23
do you have the 13 or 17 ft burro? my 5000 but carry on a/c will not cool my 27ft sailboat down in july/august in galveston unless its turned on early in the morning and runs all day! the smaller a/c wound be an easier install by i worry about its ability to cool down a 17 wide body if i turn it on in the heat of the day, thus am contemplating an 8000btu unit to cool down quickly
Old 08-10-2016, 06:39 PM   #24
Trailer: Burro
Iowa
In in iowa where it does get hot but if you are down south I'd try to use as big of airconditioner that can fit for the installation you choose.
Old 08-10-2016, 07:49 PM   #25
Trailer: Casita 16SD
Good idea George. The location in my Casita was on floor at entrance and it did not do a good job of keeping the camper cool throughout. So, I decided to move it to the rear window. Not crazy about the look of it hanging out the back but it does cool the entire camper more evenly, it cycles less often and seems to be more efficient. Plus, it is much more accessible for replacement or maintenance. If I had removed the circle from the blades like you did I would not have had the problems I did.
What you allow is what will continue!
bb4029 is offline   Reply With Quote
Old 08-11-2016, 05:23 AM   #26
I had a 5K GE with a self evaporating pan under the front bench in my Uhaul and it worked great; my wife would complain it was too cold for her.
Old 08-11-2016, 08:56 AM   #27
Maybe even a larger vent
It would seem that installing an air intake vent to recirculate the inside camper air for cooling is much the same concept as the option in auto air conditioners that allow the driver to select to either draw in outside air, or recirculate inside air.
The manual for my Toyota pu says:
“For quick cooling, move the air intake selector to recirculate for a few minutes”
“”For best results, set controls to – Air intake – Fresh (outside air).
I have no idea what the difference is, but I leave mine on recirculate all the time.
Scamper Jim is offline   Reply With Quote
Old 08-11-2016, 09:05 AM   #28
This you may know...but "Recirculate" does NOT bring in fresh air but simply uses what's in the vehicle. Obviously, the "fresh air" intake lets air in from the outside.
I personally DO NOT use "fresh air" especially here in Tennessee where it's hot/humid. It cools MUCH more quickly and continuously on "recirculate". I do this with ALL my vehicles. Notice that house units recirculate for the most part and you'll rarely see a unit that has the "fresh air" option.
In my opinion though, vehicle manufacturers may recommend that to cut down on the possibility of carbon monoxide poisoning- (bad/leaking exhaust system etc.). A mechanic just caught this on my '99 Nissan Frontier- a leak right underneath my cab! It's all been replaced.
burro
Air Conditioner for Burro joecf Problem Solving | Owners Helping Owners 3 04-05-2014 09:34 PM
Air Conditioner Louise Problem Solving | Owners Helping Owners 1 05-29-2006 10:01 PM
New Furnace ... and Air Conditioner ... Timmy G Care and Feeding of Molded Fiberglass Trailers 6 02-24-2006 08:17 AM
Solar Air Conditioner Legacy Posts Modifications, Alterations and Updates 2 06-26-2003 02:35 PM
Mounting air conditioner Legacy Posts Problem Solving | Owners Helping Owners 9 04-16-2003 10:47 AM
» Virginia Campgrounds
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
