06-22-2013, 08:36 PM
Trailer: Burro
Burro Ceiling Ideas
We are redoing a 1981 Burro and would like to hear about alternatives for the ceiling "carpet". Does the original carpet serve any other purpose other than to hide the seam? Has anyone tried wood or anything else to "glamp" it some while keeping the original purpose of the carpet-whatever that was?? Thanks!
06-22-2013, 08:54 PM
Trailer: '98 BURRO 17WB
Delaware
I'm thinkin tuck n roll turtles, argyle alligators, crystal stalactites and sound of water dripping into pool w/ echo on 8-track.
jack
06-22-2013, 09:07 PM
06-22-2013, 10:10 PM
NE Oklahoma
Those are some impressive mods.........
06-22-2013, 11:03 PM
Trailer: 13' Burro
I’m doing mine with about ¼” foam installation and 1/8” birch ply that will match my cabinet doors.
06-23-2013, 05:35 AM
Trailer: Burro
Hmmm...I'm new to this group. Interesting, Jack. Did you grow up in the 70s?? I've always wondered if that era would have an effect on us as we got older....
06-23-2013, 05:38 AM
Trailer: Burro
These are some great ideas! Thanks for the posts and welcome!
06-23-2013, 06:26 AM
That 8 Track didn't fool you did it. I think he has one of the largest collections east of the Mississippi.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
06-23-2013, 06:37 AM
Trailer: 1980 13 ft. burro
I covered mine with 1/8 inch closed cell foam to which I'd spray-glued automotive headliner fabric. I did it in 5 or 6 square sections rather than an 11 foot long strip in order to minimize cost of the 60-inch wide foam and headliner (that is, I ordered 6 linear feet of both instead of 12 feet). I hot glued some upholstery ropey-stuff in the seams between to dress it up a bit.
It looks great. It is sagging. I haven't entirely figured out how to beat gravity.
While doing our body work, we did a strip of fiberglass resin down the middle of the inside ceiling seam to provide a smoother surface than the rough raw stuff. I used super-duty sticky-back velcro strips, but I'm finding they are separating from the ceiling - though the rest of it is sticking together okay. I have supplemented with both hot glue and OSI Quad. It's not actually falling-on-my-head sagging, but gapping in enough places to be annoying.
06-23-2013, 07:53 AM
Delaware
I was pretty much finished growing up by 1970 which makes me contemporary with, if not older than, dirt, Liz.
jack
06-23-2013, 01:09 PM
This is a non-stressed area you can make uniquely your own. I'm referring to non-stress, as you're not sleeping on it, not walking on it and not cooking on it.
Now use your imagination, but how about fabric?
Or, maybe pictures or postcards. Yes, I realize this is a wall, but it may work for your narrow ceiling portion.
06-23-2013, 01:13 PM
NE Oklahoma
I had a '63 Fairlane that I custom installed a 4-track player
where the ash tray used to be. I cut it out with a hack saw.
I've never had the "nasties" habit.
06-23-2013, 01:14 PM
NE Oklahoma
Attachment 60890
Attachment 60891
Those are come cool pics of cool ideas..........KEWL!
06-23-2013, 04:18 PM
83 Burro
My ceiling is in work. Prior to starting any of it I epoxied the center seam from front to back. When finished it will have 2 layers of foam centered reflective insulation with a grey textured vinyl covering as the finish layer. Went very neutral for maximum flexibility with other colors and wanted something that could be easily cleaned and would not hold odors. Ran wires for lights and fan that will come after the ceiling is finished. Currently have no 12 volt system, installing a converter.
06-23-2013, 04:21 PM
Birch Ply
Gage,
How do you plan to attach the birch ply?? I had thought about something like that but didn't think it would stay up due to no real structure to attach it to and possibly too much weight. jd
06-23-2013, 07:18 PM
Trailer: '77 Scamp
Cover insullation with these maps of your state like this one. I think that would be so darn neat. Another option is to take US maps and cover with clear plastic or laminate and attach to the ceiling.
06-30-2013, 10:44 AM
Droopy Ceiling Solution ??
Originally Posted by jen b
I covered mine with 1/8 inch closed cell foam to which I'd spray-glued automotive headliner fabric. It looks great. It is sagging. I haven't entirely figured out how to beat gravity.
Jen b. -- I may have finally found something that will work to adhere the self stick velcro to the headliner material. AFTER I used the same velcro, I saw your posting and sure enough the same thing started happening to my headliner. After several days of experimenting with who knows how many products, including the 3M Hi-strength 90 spray stuff, I saved the one that actually worked for last.
I did not want to use this type stuff since it had taken me more than a week, with a hammer and chisel, to get it off the ceiling as the PO went crazy with "Liquid Nails". This stuff is a little different than LN and since it was not going to have direct contact with the fiberglass, used it. The application conditions couldn't have been worse, temps in the 90s, storms with heavy rain every day, unreal humidity and all that. So far so good.
Evenly coat the area that the velcro goes onto the material but avoid side oozing as you will need to weight it down for about 24 hours for drying time to bond. I used long strips of wood and blocks to hold it down. No more edge puckering on the material and is still plenty flexible to make the curve in the ceiling. Might want to give it a test run on a scrap piece of your material. BTW, I did mine in 2 sections with them joining just beyond the roof vent area. This material I got is not as heavy as it may look plus I bonded a layer of reflective insulation on the back of it. Insulation doesn't go all way to the edges, left room for direct contact of the velco to the material.
The rear piece is in and the front area is going under the blocks today.
If you get this sealant and use only a small amount for a test run, tape up the end of the tube and store it in the freezer and it won't harden up keeping you from using again it later.
Hope this helps, jd
06-30-2013, 12:08 PM
Delaware
Another approach to Burro centerline trim hiding here: http://www.fiberglassrv.com/forums/f...a-59256-2.html
This approach using wood blocking to receive screws thru the headliner is the approach used in the later Escondido Burros. Certainly worth a look.
jack
06-30-2013, 12:47 PM
Trailer: '77 Scamp
Forgot to add the link
Coastal Decor North Carolina Outer Banks Road Map Shower Curtain 72" New | eBay
06-30-2013, 01:08 PM
Wooden Blocks
Originally Posted by rabbit
Rabbit,
Thanks for that link, the ac would be wonderful right now !! As for the ceiling, I did add some blocks up top for help in attaching the ceiling and to use to mount lights since there are none. I've also been thinking about a center strip of some sort to just dress it up a bit.
My headliner problem was between the fabric and the velcro, getting them to stay together. The other side of the self stick velcro is placed on the body surface and is doing well. No sign of it trying to come loose. I think the heat up there has actually been good for it. Just have to wait to see long term results but if it does start opening up I have the fix.
Otter: You're gonna make me spend some more money! That shower curtain displays one of my favorite places on Earth, Outer Banks NC.
Thanks much for that link too... jd
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
New Ceiling in Boler
CliveAlive |
3 |
03-17-2013 05:10 PM |
Burro ceiling finish
Sue and Henry |
6 |
01-03-2013 09:30 PM |
Ceiling
Marcus T |
5 |
05-13-2012 10:09 PM |
Burro ceiling
Patricia LW |
18 |
08-01-2011 02:15 PM |
Burro ceiling
Dave Russell |
3 |
08-04-2010 03:11 PM |
