Burro Front Window - Fiberglass RV
Old 05-15-2018, 11:19 AM   #1
Green Frog's Avatar
Trailer: '83 Burro
Virginia
Burro Front Window
After several seasons of just taping over the gap in my ‘83 Burro’s incorrectly reinstalled front window, I’ve decided to try and do a proper repair. When I picked it up, the seller just stuck the window frame in place with the two sliding window sections in random grooves and the screen tossed in with all the loose flotsam and jetsam inside.
My problem is that although the lucite seems OK and the latch edge on the inner slide window seems OK, the edge of the other window is bare, so when it is all installled in the original configuration, there is nothing there to seal the closed joint. Does anybody know where I can get this part or what I can substitute there to get a good seal? My alternative will be to go back to my old Plan A and just install a solid, one piece window sealed closed.
Tia ~ Froggie
Green Frog is offline   Reply With Quote
Old 05-16-2018, 07:50 PM   #2
Scoboatn's Avatar
Trailer: Burro
A one piece window looks nice, is less likely to leak, and is much easier to rebuild. I did several of mine that way, and rebuilt a couple to be sliders also. Try to Google Pelland. They have lots of window stripping. You are just looking for a piece of stripping that will slide in the groove on the back of the channel and act as a "wiper" for the sliding window. Good luck.
Scoboatn is offline   Reply With Quote
burro
Wanted: Would like info on a Burro front window rockguard/cover..... gailanneM Parts: Buy | Sell | Trade 1 08-20-2013 12:54 PM
Burro Front Window Green Frog Problem Solving | Owners Helping Owners 12 10-15-2011 08:46 PM
Front window u-haul 13' and Burro 13' daman4799 Problem Solving | Owners Helping Owners 3 05-03-2011 09:10 AM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 07:21 AM
Burro Front Window Awning & Rock Shield Legacy Posts Problem Solving | Owners Helping Owners 3 07-25-2003 05:38 PM
