Burro Rehab So Far - Page 2 - Fiberglass RV
Old 11-07-2009, 05:04 PM   #15
Raya's Avatar
Aha, now I'm seeing the new one too. Thanks, Donna.
I always love photos with 13-ers next to bigger trailers - they always look so ridiculously tiny, and it's such a contrast to see just how much BIGGER they get to add a few more luxuries.
Old 11-07-2009, 06:42 PM   #16
MikeCM's Avatar
Trailer: Actively shopping for a project, again.
Cool
Our Roo is larger 23 foot vs. 13 foot, but the only extra luxuries are a full bath, microwave, tv, and air conditioning. However, it does have far more sleeping capacity ( 3 queen beds and 2 twins). Its all about sleeping capacity with three teenage sons, and their friends. We had the smallest try and sleep on the front bed in the Burro, he preferred to sleep out in a tent (where he could roll).
On my last weekend trip I pulled up next to one of those 40 foot buses with about five slide outs. That was quite a sight, both my truck and Burro were completely hidden. The bus slept two, so I guess they must have had a few "conveniences" that I am missing, I just can't think what I forgotten that I need for camping.
Mike
Former 83 Burro Owner (destroyed in fire)
Looking for a new Fiberglass Project Trailer in New England.
MikeCM is offline   Reply With Quote
Old 11-08-2009, 06:55 AM   #17
Trailer: Trillium 4500
Can anyone help ... I can only see 3 of the pictures in this whole topic area, but I'm assuming there's a lot more .. any ideas why I can't see all of them? Thanks. Love the games table in the camper!
Donna H is offline   Reply With Quote
Old 11-08-2009, 07:09 AM   #18
PM sent
Old 02-15-2010, 04:18 AM   #19
Trailer: U-Haul CT13
Hi Mike,
Nice work... I'm renovating an '85 Uhaul CT-13... very similar... I am looking at your headliner and it looks much more like the "stock" material... I don't want to put carpet if I can find something lighter... can you tell me what you used and where to find it?
Thanks and good luck.
Dale
Dale A Smith is offline   Reply With Quote
Old 02-15-2010, 05:51 AM   #20
MikeCM's Avatar
Dale, I used an indoor/outdoor carpet, glued in place with contact cement. I found it at a local surplus store. It is much lighter and thinner than any normal carpet. I think it might be very similar to automotive carpet. Walmart sells a similar weight carpet roll in the auto section, unfortunately only in a dark grey.
I liked it because it was so light compared to the original brown shag, the new liner is grey but close to white/beige.
Dale consider adding reflectix insulation under the headliner, I had it at the house and forgot to install, kick myself every time I look up.
Mike
Old 02-18-2010, 10:41 PM   #21
Mike
HI Mike,
Thanks for the info... I did consider adding the reflectix as a first layer, but I think it might make the edge too thick, or look "lumpy"... I do plan on making inserts out of it for the windows.
I will look for a thin indoor outdoor carpet... I thought there was a specific product... I've seen on walls as a sound treatment. I'll post if I find it. Right now, I'm trying to seal all the leaks before I start installing the new stuff. Photos as I progress.
Best Regards
Dale
Old 02-19-2010, 09:07 AM   #22
MikeCM's Avatar
Dale what kind of leaks are you chasing? Window related? I had a few places where I thought I was getting leaks from the window frame seals, (and I may have been). I scraped out some of the butyl from the outside and used plumbers putty to make a smooth seal. But still had a lot of moisture, I sat out in the burro during a heavy rainstorm and noticed that the water was pooling in the bottom of the windows (front and rear). I pulled the lower track insert and found a lot of dirt build up. I could not see this buildup until I pulled out the plastic insert. After I cleaned the track and drain slits, I slid the plastic insert track back in. I have not had any leaks since. I had used the plumbers putty as a quick fix, as I knew I wouldn't have time to pull all the windows and get them back in. That was 20 months ago, and no leaks so far, so pulling the window frames is on the bottom of my priority list.
Not sure on the headliner depth on a u-haul, but on the burro there was plenty of depth for both reflectix and the thin head liner I used. I think it may have come very close to flush. Oh well there is always next time. The added insulation would have really helped up here in the northeast, but not to the point where I would pull the headliner off and start over. I'm sure there are many products that could be used, I just hated the shag carpet look (and after 28 years mine had somewhat stale and musty smell).
Good luck with the leak remediation, and I am looking forward the progress via pictures. I like the look of the u-hauls and that would have been my first choice, but any fiberglass egg is rare up here.
Mike
Old 02-28-2010, 02:17 AM   #23
Mike
Hi MIke,
Well I finally got my trailer back from DJM in Hammond, LA... DON'T EVER USE THEM!!
They gave me an estimate of $50 per window to seal... they said they would take them out and use butyl putty to seal...
After getting a price of $110 per side window from Sunview, I decided that I would replace the sides and have the pros seal the front and rear. After keeping it for two weeks, they said that the rear was not able to be sealed but the front was done... I showed up there to pick it up and the guy was squirting silicone around the front window and had not removed it... I removed the inside frame and left it there... The following week I went to retrieve it and they had the front sealed. I had purchased some rubber/felt v-notch track for the windows from Perfect fit to seal the track for the sliders and they charged me $100 to install it in the back window plus $150 for sealing and "shop materials".
When I got it home, I got the hose out and tested it... the front is sealed but the rear and sides (with the new rubber track) also leaked...
At that point, I removed all the windows but the front and placed my order with Sunview in BC 250/494-1327. They only charged me $110 for the rear window (same as the side sliders).
After a conversation with Larry at Sunview, I followed his recommendation to get a solid rear window as opposed to a slider... He said that the vacuum at the rear might draw water in and I just want to have confidence of a dry bed... I bought some butyl tape and will be re-bedding the awning rails and am going to replace the marker lights with LEDs and rebed while I'm at it. The round tail lights are another source of water... they have the rubber grommets so I will be replacing them with a set of LED round lights with built in flanges, so I can seal around them and tighten them down to the body.
In the scheme of things, I'm glad to be replacing the windows... the 26 year old gaskets would have been very difficult to pull and seal on the side windows since they didn't have a frame like the front and rear... all three new windows will have a "sandwich" of an inner and outer aluminum flange that should make installation and sealing easier... the main thing will be to sand the gelcoat and clean clean clean with acetone, MEK, or both before applying sealant.
I have called the credit card company an am going to dispute the charges from DJM.
I already have the Avanti AC/DC fridge, new tiny window unit AC, microwave, foam, and upholstery on hand, but couldn't proceed untill I was assured of a weathertight platform.
Oh, I also got a new converter and fuse panel.... and a set of new hubs from Uhaul.
Lots of projects to complete before July.
Best Regards.
Dale
Old 02-28-2010, 03:14 AM   #24
Raya's Avatar
I can't say more until I get my heart started again. OMG!!
Good on you for getting your egg OUT OF THERE and disputing the charges.
Raya
Old 02-28-2010, 06:55 AM   #25
Phil Underwood's Avatar
Trailer: Bigfoot 21ft (25B21RB)
Odem,Texas
Send a message via AIM to Phil Underwood
I like your style. nice work on the burro
Phil & Denise Underwood
1997 Bigfoot 21 RB
2002 F-250
Phil Underwood is offline   Reply With Quote
Old 02-28-2010, 09:27 PM   #26
MikeCM's Avatar
Question
Dale, that sounds like a nightmare, glad to hear that you found a solution (I would have gone with the new windows too). You have quite a list of projects, I look forward to seeing pictures. Where are you planning to install the AC? Are you replacing an icebox with the fridge?
Mike
Old 02-28-2010, 09:29 PM   #27
MikeCM's Avatar
Thanks Phil, now if it would just stop snowing up here I could get out there and work on a few more projects. The snow is stacked up above the frame.
Mike
Old 02-28-2010, 09:37 PM   #28
MikeCM's Avatar
Thumbs down
I showed up there to pick it up and the guy was squirting silicone...
It always amazes me that repair shops just start squirting silicone, guess they think a quick fix is best for repeat business?
Our larger camper (a Rockwood Roo) had a front bunk leak. I brought it in for warranty repair, two squirts of silicone and they said it was all set (1.5 hours each way to the dealer). Leaked the very next trip, so back it went. Three weeks later it came home with a brand new front bunk hatch. The new one was a completely different design that pushed the water out instead of pouring in. All three bunk hatches also had new seals all around. Huge difference when they do the job right.
Mike
burro
Horizon Camper under rehab Tim Wood General Chat 10 10-26-2008 08:49 AM
Looking for help for Fiberstream rehab lindsay Care and Feeding of Molded Fiberglass Trailers 12 02-19-2008 07:23 PM
My 1981 Burro rehab Myron Leski Modifications, Alterations and Updates 14 03-26-2007 10:45 AM
Question for rehab lwehrly Care and Feeding of Molded Fiberglass Trailers 32 02-01-2007 09:19 PM
Burro Rehab D Shubel Modifications, Alterations and Updates 16 06-23-2006 05:50 AM
