Burro seam up the middle - Page 2 - Fiberglass RV
Old 08-31-2016, 08:14 AM   #15
Trailer: 1978 Burro
Burro seam up middle
Originally Posted by Eric Johnson View Post
the short of it is it was a $ savings to (even slowly) mass produce to not have a seam due to mold and gell coat issues to fix after the fg mold
On a remodel fix up( before putting 7K miles on it on our trip out west) I cut off and ground down the seam, used fg EPOXY RESIN with 1/4 in chop strand mixed in finished smooth with Bono and tip brushed white Rustolium on top of Bens Bonding Primer (very important according to the tech at Rustolium). Strength is already there with the fiberglass mat used by the manufacturer on the inside..
RESULTS: after seven thousand miles not even a spider web crack.I can post pics if your interested
Oh yeah, I'd like to see photos of your project.
Is this what you used when you mixed in the "chop strand" in the fg resin?
1/4 Chopped Glass Fibers in stock for same day shipping | Fibre Glast
Now I have another alternative to consider with your method.
I have been considering adding tint to the resin too in case I don't get a chance to finish the job before heading out this winter. I haven't found any real good information on the web though yet.
Thanks for the info. Next summer I'll tackle the ridge.
DuaneQ is offline   Reply With Quote
Old 08-31-2016, 11:31 PM   #16
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
You stated it as "Bens Bonding Primer" I believe may have meant "B-I-N Bonding Primer". Just want to make sure of the spelling so if people go looking for it they can find the primer you used. BIN is produced by Zinsser products. Rustoleum now owns that product line so it makes sense that they would recommend its use with their other products. But as there are several variations of B-I-N primer can you be specific about exactly which one you used? I would suspect it is the original shellac formula which can be used indoors or outdoors versus the synthetic shellac formula.
BIN is one of my favorite primers. I see that they now also have a mold killing primer under that product line name of BIN.
Old 09-05-2016, 10:43 AM   #17
Trailer: Burro
Iowa
Seam in burro
The lip on burro seam actually was only to be able to clamp it all together. I put lots of these together in the factory. The inside laminated seam is what seals it all. Thanks Brian
Burropartsman is offline   Reply With Quote
Old 09-05-2016, 08:00 PM   #18
Eric Johnson's Avatar
Name: Eric and Sharon
Trailer: Burro
Ohio
Haircut on Burro?....yes!
The correct Primer to use is an oil based one that is also tintable. The primer is ZINSSER 3554 called COVER STAIN stain blocker bond coat. The 1/4 in chop strand and Epoxy Resin came from Fiber Glast co. Love Fiber Glast for their friendly help. Ill post pics as soon as I can.
Eric Johnson is offline   Reply With Quote
Old 09-06-2016, 05:36 PM   #19
Trailer: Burro
Ohio
Burro seam removal
a few pics of seam removal after fiber g work , prime and tip brush paint. I plan to put on a two tone paint with a stripe addition but want to try my H.V.L.P. paint sprayer and a clear coat next.
sorry if pic doesn't show up...still trying
burro
Vertical Seam Versus Horizontal Seam Cathy P. Care and Feeding of Molded Fiberglass Trailers 17 03-17-2015 11:25 AM
1981 Burro $2900 middle of Texas brian m. Referrals: Molded Fiberglass Trailers 3 11-28-2012 02:18 AM
Fiber Stream middle-age spread Tom U Problem Solving | Owners Helping Owners 4 04-18-2009 04:26 PM
Tech Support in Middle Ages Pete Dumbleton General Chat 3 03-24-2008 07:59 PM
Middle Fork Campground, WA Dan Simon Camping, Campout Reports 1 07-16-2006 08:11 AM
» Virginia Campgrounds
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
