Cabinet doors - up or down - Fiberglass RV
Old 10-24-2012, 12:55 PM   #1
Greetings fellow owners,
I'm thinking about revamping all my cabinet doors, they're currently particle board with a white surface. For some reason, all the doors are quite a bit larger than the opening, don't know if that was done for style reasons or what, but I would like to make new smaller doors out of oak or birch plywood. One question I had for all you folks, there are two overhead cabinets above the stove/counter area. Currently the doors swing upward, which really annoys me, because they require one hand to open and hold up, and another to get the item you're after. My thought is that once I'm set up at the camp site, I would like to open the doors and just leave them open. When I replace the doors, I could make them swing down instead. Any disadvantage to this?
Also, instead of cabinet door knobs, I would like to use thumb latches to hold the door close during travel, kind of like a cam lock but no key required. Right now there's a kind of spring roller thing that isn't very good at keeping the door closed on rough roads. My goal is to never have any door pop open during travel.
ThomasE is offline   Reply With Quote
Old 10-24-2012, 01:02 PM   #2
There are spring cylinders at amost all RV stores that will hold those doors up as well as closed. Less than $3 each. Lower doors that swing down are OK if small, but also get in the way if there is more than one person thereabouts.
Old 10-24-2012, 01:19 PM   #3
honda03842's Avatar
Name: Norm and Ginny
Thomas,
I just did all my doors in birch plywood. They formerly opened sideways and I had not considered other options. All former RVs opened up with a support piston. The piston is a pain on smaller doors so if I were redoing it I would op for down.
With our birch plywood I opted to leave the edges untreated. They look fine to me.
The topic " How have you improved your eggcamper..." shows Harley's cabinets opening downward.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-24-2012, 02:47 PM   #4
Gilda's Avatar
Trailer: 2011 Scamp 13'
I'm so glad you asked this question because I want to improve my latches as well. I think many of us cope by using bungee cords in transit to keep cabinets and fridge closed, however some cabinets cannot be anchored in this manner.
Old 10-24-2012, 03:05 PM   #5
cpaharley2008's Avatar
I reversed all my doors on my Egg camper so that you only needed one hand, just a matter of filling in the holes and moving the backer wood from top to the bottom of each opening. Also less change of opening while in transit this way. While you have the doors off, install some LED lights inside, you will love being able to see into the cabinets.
Old 10-24-2012, 04:43 PM   #6
Dudley's Avatar
Trailer: 1998 Casita 17 SD
My top cabinet doors were hinged on the sides but I have a "vertically challenged" wife so when I redid my Ventura I went with top hinges and the spring loaded prop rods from an rv shop. The wife loves them!
Old 10-24-2012, 06:19 PM   #7
This has more to do with those that aren't looking to change the doors, but hate having to hold the upper cabinet doors with one hand while rooting around with the other! Years back, back before the hack... someone posted a simple solution. A Pink Pearl Eraser that had been filed down to slip between the cabinet door and the cabinet. It effectively pinched the door to the point it wouldn't slam shut and held it in an open position. Absolutely no damage to the cabinets either. Cheap solution! Wish I would have captured the image before it went to alphabet heaven. Guess you'll have to use your imagination.
Old 10-24-2012, 06:21 PM   #8
You've got some really nice cabinets there.
Old 10-25-2012, 07:21 AM   #9
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I only have one cabinet that opens upward. I used a door stay from West Marine. Basically it's a spring. I had to put a piece of wood against the left wall of the cabinet to get the attachment point flush with the left side of the opening.
Old 10-25-2012, 08:52 AM   #10
Trailer: Bigfoot 1981 Trailer
Dudley, does the door accidentally open while travelling on bumpy roads, or do you have an attachment to keep the door closed while travelling. I am planning to redo all my doors the same way, as they actually slide now. Thanks, Jim
Old 10-25-2012, 08:57 AM   #11
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Steve, do you happen to have a source for these spring type holders?
Old 10-25-2012, 09:07 AM   #12
Tim Wood's Avatar
Trailer: Class B for now
NY
You can get the piston type on Amazon like David has, or some have made their own from springs at TSC tractor supply.
Old 10-25-2012, 10:46 AM   #13
Steve L.'s Avatar
MOONLITE MARINE Hatcharm at West Marine
I've used this one for years despite the one review...
http://www.westmarine.com/webapp/wcs...classNum=50683
Old 10-25-2012, 11:29 AM   #14
These spring cylinders are what are used on almost all new trailers. Usually about $3 at most RV shops. Marine stuff always cost more and, unless you have a houseboat!!!
http://www.campingworld.com/shopping...FYp_QgodFRQAdw
New Scamp cabinet doors kootenaigirl Modifications, Alterations and Updates 35 08-03-2015 05:57 AM
Cabinet doors Filbert V. Modifications, Alterations and Updates 16 08-23-2012 08:15 PM
Cabinet Doors fidgetboy Modifications, Alterations and Updates 20 04-18-2012 08:48 AM
Cabinet Doors fidgetboy Modifications, Alterations and Updates 9 03-06-2012 06:59 PM
cabinet doors Rarebird Modifications, Alterations and Updates 15 12-07-2008 09:05 AM
