Cabinet Lights - Fiberglass RV
Old 10-13-2014, 11:42 PM   #1
Night Sailor's Avatar
Connecticut
Cabinet Lights
I started putting in cabinet lights. Here are two examples. I used stick on LEDs from eBay, connected to magnetic switches found on Amazon.
Name:	ImageUploadedByFiberglass RV1413264785.408404.jpg
ID:	77613Click image for larger version
Name:	ImageUploadedByFiberglass RV1413264818.250245.jpg
It looks like I'll need another lamp for the bottom shelf.
Name:	ImageUploadedByFiberglass RV1413264853.237562.jpg
ID:	77615Click image for larger version
Name:	ImageUploadedByFiberglass RV1413264893.228215.jpg
These aren't cabinet lights. I added some strip lights under my galley counter. These are for stealth mode to provide light inside when I don't want it to be obvious that I am inside.
Name:	ImageUploadedByFiberglass RV1413264937.278158.jpg
ID:	77617Click image for larger version
Name:	ImageUploadedByFiberglass RV1413264946.879536.jpg
Old 10-14-2014, 06:39 AM   #2
Trailer: 1994 Scamp 16
Arkansas
Conrad,
Great idea on your lights! Thanks for the pictures. Were they hard to install?
Thanks,
Carl
If you don't know where you are going, you might wind up someplace else! Yogi Berra
Nut501 is offline   Reply With Quote
Old 10-14-2014, 02:37 PM   #3
Connecticut
Originally Posted by Nut501 View Post
Conrad,
Thanks,
They were easy to install. I have a few sub panels so the wire runs were short. Using sub panels makes it all easy. I plan to buy one more sub panel for my Ham radio gear. I thought I could mount all that on a pajama cabinet door and lift it up for use, and close it to put it all out of sight.
The magnetic switches were a bit pricey @ $10 each. The come with plenty of wire, so I used that to make the connections. I only bought four (4) so I will need to order a few more. I am not sure how many cabinets I will do. It is a little bit of luxury, that makes you smile every time you use it.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
The magnetic switches and LED lamps were both stick on. The wiring was pretty easy. I would have done more, but I ran out of small gauge (red) butt splices.
The smallest fuses I could find were 1 A. I wish I had smaller ones. These LEDs do get hot, so I am not sure how well they will hold up, or if they are regulated. They will only be on for brief periods. I may move all these circuits onto one switch, so that I can turn it all off when I'm in stealth mode.
The wire is small enough, you can tape the leads in place out of sight.
Old 10-14-2014, 02:40 PM   #4
Connecticut
Example of a Sub Panel:
Amazon.com: Blue Sea Systems 5026 ST Blade Fuse Block with Cover: Sports & Outdoors
Old 10-23-2014, 10:33 AM   #5
Connecticut
I ordered some more SMC LED panels. These have stick on backs. Here is what I bought. They seem a bit like overkill as you don't need all that much light in a cabinet, but they are on for such brief periods, I don't think it matters much.
Warm White Light Panel 48 SMD LED Interior Bulb T10 BA9S Adapters | eBay
light, lights
Free: 16'/19' Scamp cabinet door and overhead cabinet Isaac M Parts: Buy | Sell | Trade 7 09-11-2014 10:51 PM
Four Head, LED Under-Cabinet Lights ShawnKK Misc: Buy | Sell | Trade 0 10-18-2013 08:00 AM
Ikea under cabinet lights courtney Modifications, Alterations and Updates 1 06-20-2013 02:12 PM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 09:10 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 10:54 PM
