Camco 35953 water heater bypass kit - Fiberglass RV
Old 11-18-2009, 02:45 PM   #1
I'm about to order the Camco 35953 water heater bypass kit to install on my Atwood 6 gal. heater.
Does anyone have this kit installed or any opinions about adding a bypass in general? I read on a Amazon customer review that the ball valves aren't full bore and restrict the water flow somewhat. I'm not too concerned about that though. I won't be using my water heater much so I'd like to keep it empty when traveling. I also ordered a half inch drain valve/ballcock so I can empty it easily.
ThomasE is offline   Reply With Quote
Old 11-18-2009, 03:59 PM   #2
peterh's Avatar
Our Scamp came with a single valve that shuts off the flow into the water heater. Works for us!
Where do you put the drain ballcock? Does it go in-line with the bottom water heater plumbing connection? I'd love to drain our water heater without having to un-wire the HottRod electric heater element that installs into the drain port.
Old 11-18-2009, 04:41 PM   #3
The drain goes on the outside at the water heater panel. I couldn't find a clear picture of the Atwood drain, but it's basically at the front panel, lower left corner. Right now there's a half inch drain plug there, I have to use my 7/8" lug wrench to get it out so it's kind of a hassle to drain. Peter it sounds like you have a an electric heater so I'm sure it's configured differently from my propane one. This is a picture of the drain Camco 11703, I just ordered off ebay for $3.75 + $1.90 shipping. Hopefully it will be drainable without tools now. Good idea about the valve on the input line, I thought about that, and it would be cheaper to get a Pex compatible barbed 1/2" ball valve.
Old 11-18-2009, 05:17 PM   #4
I installed one this fall as I felt that the shutoff valve in the cold line was useless in my Scamp. I had to bye two Pex couplings so I could put the lines back together after installing the bypass.
Bill K
Old 11-19-2009, 05:20 AM   #5
DonDeutsch's Avatar
I install one in an Airstream we had years ago and was happy with it's performance. Don''t remember much else about it.
DonDeutsch is offline   Reply With Quote
Old 11-19-2009, 07:29 PM   #6
I went by Lowes and they had quite an extensive selection of Pex fittings and tubing. I bought a simple 1/2" Pex brass ball valve for under $6. I'll try installing this to the input line of the heater instead of the bypass kit. Thanks folks for all the input.
Old 11-20-2009, 07:38 AM   #7
Then how will you winterize the hot water lines after turning off the valve ?
Bill K
Old 11-20-2009, 08:32 AM   #8
Dan Meyer's Avatar
Bill K
Learn the procedure to winterize your trailer with the shutoff valve on the inlet side of the water heater on my web site.
http://scamp.n0kfb.org/ -> tech tips -> Winterizing your Scamp
-- Dan Meyer
Old 11-20-2009, 09:03 AM   #9
Bill
I was also wondering the same thing about the input valve.
All
Camco also makes a winterization kit part #35983. The difference is instead of two valves, the hot water output valve is replaced by a check valve. This eliminates one step in the winterization progress. Also when installing your W/H bypass kit you also can install a RV pump converter winterization kit. (Camco Part#36543) This kit allows you to pump anti freeze directly out of the anti freeze jug so you don't have to put antifreeze in your water tank and it also protects your pump. You still need to start the winterization process by blowing out your water lines from the city water connection. This will remove water out of the city water line since there is a check valve in the city water hose connector and fresh water could be trapped at the city water connector.
Eddie
Dan
I see how you do it now from your web page. But if you install the pump kit you can winterize with about one gallon of antifreeze and in the spring the water storage tank is easier to deal with.
Old 11-20-2009, 11:56 AM   #10
Bill, I live in sunny California, I do get frost where I live but the absolute lowest I've experienced in the Bay Area is upper 20's. So I'm not doing this for winterization, I'm doing it to travel with an empty tank (unless I'm using hot water of course), and to keep it empty when stored to avoid a stinky hot water tank.
Old 08-26-2015, 11:09 AM   #11
mgellar's Avatar
Trailer: Scamp 16' Oak Deluxe Layout A - "Kiwi"
Maryland
Hi - I know this is an old thread, but this will be my first year winterizing my Scamp 16' Deluxe. I like the idea of pumping the antifreeze right from the container rather than filling the holding tank. However, I've read some reviews on Amazon about the pump converter winterization kit, Camco Part#36543, that it restricts the normal flow of water to the pump and some suggest just getting a valve elsewhere. I've also read the same thing about the winterization kit part #35983. If I use Part 36543, I assume I would install that between the pump filter and the pump?
I know there are various methods, especially with regards to the h/w heater. I will forego the air compressor method and pump anti-freeze in the lines. Any input about the h/w heater, the above kits or any other advice? Some methods talk about backfilling the h/w water heater with antifreeze, just draining the h/w heater, etc. Also, if it doesn't have it, is an anode replacement for the drain valve or a part that you replace the drain valve with where you can just unscrew it without a tool recommended? (This is a gas only h/w heater.) We plan on traveling in the winter from and to the north and south.
mgellar is offline   Reply With Quote
Old 08-27-2015, 07:16 AM   #12
Mike
The Atwood aluminum tank WH does not use an anode. I use the plastic plug. When the plug is removed you can flush the crud out of the tank and it is not as prone to getting stuck in the tank. You just need to get the correct size socket and an extension.
I use the Camco #36543 and have not had an issue with waterflow. Besides the water tank the next most important thing to winterize is the comode water valve. Even though some water is left in the bottom of the WH it will not freeze and damage the water if drained by removing the plug.
When installing the Camco #36543 kit just make sure when the pickup line feeds the trailer and not the tank side. It can be installed backwards.
If you can, try to install the Camco #36543 in front of the filter. The filter bowl will hold water and freeze. I just ordered the filter that screws onto the pump input and the #36543 pick up kit screws to the input of the filter. All connections are 1/2" NPT.
Eddie
Water heater bypass Chris Z Plumbing | Systems and Fixtures 24 07-15-2016 08:01 PM
water heater Sandra Lair Modifications, Alterations and Updates 16 10-09-2009 10:58 AM
Can I run my Hot Water Heater Karalyn Plumbing | Systems and Fixtures 8 06-22-2009 10:53 AM
Where do I find the water bypass switch? Karalyn Plumbing | Systems and Fixtures 9 10-19-2006 01:30 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
