Originally Posted by Jon in AZ
I think I recall one person set it up as a freestanding unit on the floor in front of the front bunk using a quick-connect propane fitting.
Sounds like that person could have been me, except that I dont use the floor because of the dog. But I did install a quick connect fitting, and even rigged the manometer to use the quick connect.
I did look at places to install the smallest Wave (3) and never found a good place that met the minimum clearances, would not be a hazard to me or the dog, etc.
Jon's cautions are important. You will see more in this thread I am sure, and some might sound quite dire. For me, the wave is only for occasional use, or emergency use where I have lost all electric (120 and 12) and need heat to survive. I have used it an average of once a year.
So for occasional use I have the legs for it and I set it on the kitchen counter on an extension with a small (pull) chain attached to the grill and the upper cabinet, allowing it to hang far enough forward so as not to overheat the upper cabinet. I do not sleep with it on. For occasional use while awake I would set it on the floor if I did not have the dog.
If you find an acceptable location, let us know.
