Can i get some floor pics for ideas/options please - Page 3 - Fiberglass RV
Old 08-27-2013, 06:24 PM   #29
Trailer: 13ft Scamp
Wisconsin
Forgot to ask how many sqft of flooring is need for the 13 ft scamp?
Mcmarkrazz is offline   Reply With Quote
Old 08-27-2013, 06:32 PM   #30
Trailer: '77 Scamp
I thought that statement about the butt seam would be confusing but didn't know how to say it without a long statement. The 4' length, running from front to back, was long enough to install under the table and in the rest of the trailer using only one strip. So I didn't need to worry about staggered joints like they advise in the instructions. I did however, run it continuously into the porta-potti cabinet and about 18" additional was required there. It only took one box at $40. I bought an additional box though in case I needed it later or messed up.
If I'm still not clear let me know and I'll try to explain. They are peel and stick and none are coming up so far. However, where there are shorter pieces around the dining tables benches, I used some additional adhesive. You simply make a score line with a box cutter and then bend the tiles, and it makes a clean cut.
Re. the under bed storage bedskirt, thanks. I just attached with velcro so I can wash easily. I had left over fabric from my window shades I made. The pattern is barbed wire.
Otters is offline   Reply With Quote
Old 08-27-2013, 06:47 PM   #31
Trailer: '77 Scamp
Originally Posted by RogerDat View Post
Is this a vinyl type product that overlaps and is semi-adhesive? How thick is it?
Forgot to address part of your questions Roger. Its peel and stick and doesn't overlap. That worried me a bit but it allows for a really tight seam. You can't even see the seems and I've tested it with pouring a little water on it. No issues there, its tight. That's why I painted the coats of deck paint though--as an added layer of protection for the subfloor.
Old 08-27-2013, 06:53 PM   #32
Trailer: '77 Scamp
I believe the box was 22SF and one box did it. I think it depends on what product you end up with though. Mine was 4' long and some other types are 3' long. I recommend buying 2 boxes because I used every bit of the box and if there were any oopses, I'd have needed to cut into the extra box.
Boler 13 Floor ideas Thintizzy Problem Solving | Owners Helping Owners 9 04-23-2012 10:15 PM
Paint options backpacker Modifications, Alterations and Updates 5 02-23-2012 02:22 PM
Options, Options Options Tezha Problem Solving | Owners Helping Owners 8 09-19-2010 11:55 AM
Floor replacement Options - OSB vs Plywood. Oliver P Problem Solving | Owners Helping Owners 11 08-11-2009 08:34 PM
