09-14-2013, 11:13 AM
Trailer: 17 foot boler
Canadian Winter modifications
hi all
i'm new to the forum as my wife and i just bought our first fiberglass trailer a 17 foot boler i'm not certain of the year due to some restoration/registration issues , any way my question to all of you ( which has probably been asked already) what modifications did you have to do to your trailers to use them in winter ? i put Canadian winter in the title because some people have mild winters but in most of western canada we have not so mild winters .
thanks
09-14-2013, 11:23 AM
Hi David, to FiberglassRV, we're glad you're here
There are lots of kind and helpful people here on the forums. I'm sure some will be along shortly to answer your question(s). I can't help, because for me and where I live, it's not the cold that's the problem... but, the WET.
09-14-2013, 11:56 AM
Hello DAvid and welcome to FGRV,
There is a manufacturer located in western Canada, Escape Trailers in Chilliiwack, BC as seen here Escape Trailer Industries > Home. Anyway they make a nice unit with winterizing options like extra insulation and windows for winter use. You mention your trailer, a Boler. Perhaps you could borrow some info from Escape to make your trailer better suited for winters. Plexiglass storm windows or reflectix on the inside will help as will carpet on floor and a good propane furnace or electric heater. What model do you have and pictures would help.
Jim
Never in doubt, often wrong
09-14-2013, 12:20 PM
cpaharley2008 thanks for the tips , i'm still trying to figure out which model i have , i haven't been able to figure out the year yet so that may help as for pics next time i go to where my trailer is i'll take some pics
09-14-2013, 12:35 PM
thanks
LOL well I guess I am one of those in the real western canada that gets the mild winters Having said that as you know I dont have to travel far to know what your talking about
Besides buying a new trailer with added insulation etc from the good folks at Escape and or Bigfoot there are things you can do and those that do take their not so well insulted trailers out in the winter do. Cutting out reflectix bubble foil to fit the windows is one. Adding an extra layer of throw rugs on the floor helps. If your camping in cold weather and your freshwater tank and black tank are located inside the trailer keep doors to them open and keep the heater running in the trailer. If its *really* cold you may decide to forget about using the water tanks and the piping in the trailer at all & go with using bottle water only for your needs. Dont let water accumulate in your grey water tank and sit for more than a couple of hours - keep it drained and dump anti freeze down all your drains before bed each night. Never leave water hoses connected to the trailer in cold weather.
09-14-2013, 01:54 PM
Name: Norm and Ginny
We definitely avoid winter but have frequently found ourselves in cold weather. It's usually easy to add insulation to the bottom of the trailer. We had a trailer with one under trailer tank and glued foam insulation to the tank. This same insulation could be easily added to the bottom of any wooden floor trailer. As well when we're camping in a cold place, we leave our bathroom door cracked at night and the under cabinet doors open a little.
Certainly having insulation panels for the windows and vents are a good idea.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
09-14-2013, 02:03 PM
Aside from everything already mentioned, if I wanted better winter comfort I would insulate the floor... from below, by adding panels of foam.
09-14-2013, 02:38 PM
thanks all great ideas , brian where in alberta are you?
09-14-2013, 03:23 PM
Trailer: Casita Spirit Deluxe 17 ft Hybrid
You might also consider taking along a couple of tarps to rig up a skirt around the bottom of the Boler. They will cut the wind and create a fair dead air space and lessen the heat loss. Saving a few degrees and an insulated floor as mentioned by Brian, spells comfy.
"When a Blue Norther blows through, the only thing between here and the North Pole is a few barbwire fences" - Local Saying
09-14-2013, 05:42 PM
Trailer: 2007 Eggcamper & Homemade Tear Drop
Here is a simple solution for insulating your floor from the inside they are easy to cut and install and you could cover them with carpet if you don't like the look.
Norsk-Stor 240275 Multi-Purpose Foam Flooring Mats - Walmart.com
Jason
If you think you are to small to make a difference just try sleeping with a mosquito –- The Dally Lama
09-14-2013, 07:05 PM
Originally Posted by kirkman
Good idea. Harbor Freight has these quite inexpensively, too.
4 Piece Anti-Fatigue Foam Mat Set
09-14-2013, 08:23 PM
Foam on top of the floor would be good, too, but it would be limited in thickness and would not be under the plumbing which runs inside the cabinets and in part directly on the floor.
David, I'm near Edmonton... where are you?
09-14-2013, 08:35 PM
Brian i'm in edmonton , trailers in ryley
09-14-2013, 09:16 PM
If you have access to power an electric blanket will go a long way.
09-15-2013, 07:07 AM
Good point!
Jason
09-15-2013, 07:22 AM
IF you will be connected to power, consider heat pads for the interior floor. Toasty warm on your feet. Here's a discussion: http://www.fiberglassrv.com/forums/f...ing-56243.html. Steve L. uses them and is happy... see post #22. I plan on using these in my new trailer
09-15-2013, 07:27 AM
Jim
09-15-2013, 12:15 PM
Have seen people use 40 watt bulbs in the storage areas to keep areas from frost. That is if you have elect availible.
09-15-2013, 01:03 PM
On our motorhomes we kept ac lightbulbs in selected storage compartments, does the job.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
09-15-2013, 01:05 PM
The last several posts indicate something else you will need to winter camp, electricity.
Jim
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Modifications
pageleigh |
8 |
11-09-2012 01:10 AM |
Modifications
happycamp88 |
11 |
07-08-2012 07:01 PM |
Canadian Winter
JonE |
Fulltiming in a Molded Fiberglass Trailer |
18 |
07-26-2009 11:38 AM |
Modifications
Lisa F |
12 |
03-11-2006 12:06 PM |
Modifications
Legacy Posts |
6 |
04-19-2003 05:29 AM |
