Casita hitch light wiring - Fiberglass RV
Old 05-16-2017, 07:14 PM   #1
New Jersey
I recently purchased a 2017 Casita Spirit Deluxe and would like to wire brake/stop/tail lights on a rear bumper mounted bike hitch. Where is the easiest place to tap into the wiring.
Thanks Alan
Alan Dilley is offline   Reply With Quote
Old 05-16-2017, 08:29 PM   #2
Pull up the angled toe board along the back wall at the floor level, which will require the use of a screwdriver with a #2 Robertson square drive bit. It is not a Phillips head. Find the wires you need to tap into in the wiring bundle in the "rats nest" under the toe board.
I installed a 4-Pin flat trailer plug in the rear by drilling a hole through the floor in the area under the toe board. I would recommend drilling a 3/8" hole from the inside so you don't drill into any existing wiring and routing the wires in from the outside. (The wires you want to tap into are shown below.)
Finish up by caulking the hole around the wires with a good grade Marine sealant when your done with the wiring. My recommendation would be Sika-Flex 231 or 3M 4200.
My 2008 has the following color coding for the rear wire bundle under the slant board, which I had to decipher wire by wire in the rear bundle under the toe board when I installed a 4-Pin flat connector to power the lights on my Stow-Away box. The actual trailer wire colors are the far left column.
TRAILER----------------FUNCTION---------------------4-PIN CONNECTOR
WHITE-------------------GROUND-----------------------WHITE
GREEN------------TAIL/RUNNING/LIC.----------------BROWN
RED--------------LEFT TURN/BRAKE LT.---------------YELLOW
BROWN---------RIGHT TURN/BRAKE LT.--------------GREEN
Old 05-16-2017, 09:54 PM   #3
Borrego Dave's Avatar
Welcome to FGRV Alan. Just a bit of an add on to Greg's info just "in case". I used Greg's info when I added the plug on my '06 SD 17 but the right turn wire was not under the center panel. Who ever wired mine put it under the curb side bench . I pulled the bench for access which was fine as I installed a deck plate to the water tank and wired in a lighted shut off switch to the CO monitor to eliminate the battery draw while stored. Just a heads up.....had me scratching my head for a while .
Old 05-17-2017, 04:04 AM   #4
New Jersey
Thank.you Greg and Dave for your speedy reply. Very clear and excellent info. I really appreciate it.
Alan
casita, light
Hitch wiring plug options Lainey Problem Solving | Owners Helping Owners 5 07-20-2007 11:23 AM
Hitch Wiring Stuff... Sitah Problem Solving | Owners Helping Owners 1 06-15-2006 07:28 PM
Newbie Hitch Wiring Question Scott Bacon Problem Solving | Owners Helping Owners 5 06-01-2006 05:56 PM
Newbie: Hitch & wiring questions Anne H Problem Solving | Owners Helping Owners 8 05-20-2006 04:17 AM
Pilot light won't light (Casita) SW6P Legacy Posts Problem Solving | Owners Helping Owners 5 08-06-2003 09:12 PM
