Cat Fur Gone! Is the Wall Structural? - Fiberglass RV
Old 04-15-2013, 08:22 AM   #1
fusedlight's Avatar
Trailer: 16' 1998 Scamp
Well, I've got 99% of the "Cat" fur that a PO*2 put on a bunch of the fiberglass surfaces. I'm slowly using Goof Off to get the adhesive removed. That's working great* other than a couple of spots where it looks like some sort of epoxy cement was used. After all the gunk is off and the surface lightly steel wooled The Dot is going to put on some nice epoxy paint to match the new cushions (replaced the leopard print monstrosities that the same PO*2 put in).
I know the wrought-iron twisted support next to the range top are structural. Is the panel dividing the dinette and back structural too?
GcB
*I'll be waiting until it's a bit warm to finish this. Even with the door and a couple of windows open I was a bit woozy after working on a couple of square feet of wall. It's too cold (33F) to put in the big exhaust fan...so I guess I'll just have to wait until next week when it's finally supposed to warm up.
fusedlight is offline   Reply With Quote
Old 04-15-2013, 11:23 AM   #2
GcB
Gary I cant say one way or another but as you have a really big roof AC I would be very very reluctant to remove anything from the trailer that currently runs from floor to ceiling as it would be a good bet it is giving some added support.
Old 04-15-2013, 12:00 PM   #3
Trailer: '77 Scamp
I've read a lot of threads about the structal necessity of the twisted rods and agree with Carol. However, many people have sucessfully modernized or updated those rods and changed them out with other structual supports. Do a search and see what others have done. Tap plastics has a spiral clear acrylic rod that I thought would be an interesting change. Don't really know the strength but thought about checking out puting 2 or 3 of them in place of the metal rods. But then since I'm going for more of a vintage look, I've come to appreciate the look of the metal supports. Here's the Tap link. Spiral Rod Extruded Acrylic Bar : TAP Plastics
Otters is offline   Reply With Quote
Old 04-15-2013, 12:03 PM   #4
Gary,
Yes the wing wall does carry roof and cabinet loads.
Russ
Old 04-15-2013, 05:56 PM   #5
fusedlight's Avatar
Ok. Looks like I'm going to have to pop the thing off to her at the cat fur stuck behind it and then reset the rivets. I do not have kind thoughts for that PO.
Old 04-15-2013, 07:05 PM   #6
Have we ever seen any interior pictures of your trailer Gary? How about sharing... how can we appreciate the work you're going through when you post final pictures. And, you will post those won't you?
Old 04-16-2013, 07:55 AM   #7
fusedlight's Avatar
Geez, Donna... pushy, pushy, pushy!
I'll pop out to the Scamp later on today and take some snaps.
Old 04-16-2013, 09:46 AM   #8
David Tilston's Avatar
It's our mantra, we like pictures.
Old 04-16-2013, 10:14 AM   #9
Robin G's Avatar
Trailer: 2007 Casita
I kinda remember one pic someone posted of a cabinet with the fur attached (maybe from a sales ad?) What a project that would be to remove it all. Can't wait to see pics!
If my memory is correct and I remember the details of this project , I believe this project is gonna end up in the hall of fame of, Glass remodel................ But pretty sure all your hard work is gonna be worth it!
Old 04-16-2013, 03:36 PM   #10
fusedlight's Avatar
The Pictures! Click on 'em to embiggen.
Front Wall:
Detail at Top:
Divider:
Detail showing the Nasty Fur stuck under the flange:
The cabinet...note the obnoxious epoxy blobs:
And, Robin... that guy was ME!
Old 04-16-2013, 03:39 PM   #11
fusedlight's Avatar
As you can see, that "Professional" (is there ever an "Amateur") strength Goof Off does a darn good job. You just need a LOT of ventilation whilst using it. The pain in the neck part is getting the Cat Fur out of the spots where it was tacked behind things like the wall flange on the divider. I've tried to poke it out of there, but I think the adhesive is going to necessitate popping the panel off for a bit and then putting it back on. You can also see that the cases that form the dinette seats have come off of their mountings. I'll be taking care of that, too. Maybe the weather will behave this weekend. Or maybe we'll have snow. Again.
Old 04-16-2013, 03:50 PM   #12
OMG! do you have any totally before photos???
Personally I would probable take the cabinets and other items that are removable out and clean them up outside. Might find its a lot easier than trying to deal with them in place and avoid messing up the rat fur. Having to replace rivets comes at some point in every fiberglass trailers life (assuming it has them) so if you do those now you will not need to worry about them again for another 20 years. They are actually pretty easy items to replace ;-)
Old 04-16-2013, 04:07 PM   #13
fusedlight's Avatar
It's been winter, and I really didn't want to poke holes in our baby until spring!
Old 04-16-2013, 04:45 PM   #14
Robin G's Avatar
Yup that furry cabinet pic is the pic I remembered....
I guess I could say it wasn't horrible with brown furry stuff, But I just wonder why anyone would do that? hmmmmmmm
Boy, what a undertaking to remove all that! Otherwise the Scamp looks likes it's in pretty good shape. At least from those pic's. The rat fur looks good for it's age.
'98 Scamp - Cat Fur OFF - Panel Up Next - Need Suggestions fusedlight Modifications, Alterations and Updates 2 03-02-2013 04:30 PM
Structural Crack kyle minor Problem Solving | Owners Helping Owners 2 06-04-2010 10:34 AM
structural Q: front dinette Paula D. Problem Solving | Owners Helping Owners 4 05-28-2006 11:06 PM
RAT FUR..CAT DOESN'T UNDERSTAND Susan Tiller General Chat 12 04-23-2006 10:12 PM
Scamp structural integrity Chris Z Modifications, Alterations and Updates 6 01-06-2006 11:43 AM
