ceiling fan - Fiberglass RV
Old 04-28-2012, 09:04 PM   #1
Kenny Strong's Avatar
Trailer: Bigfoot 13'
Utah
ceiling fan
I installed this Comfort Air 14"x14" 12volt, 4amp max. ceiling fan It has a remote, automatic rain sensor, auto temp control. retail cost $395.00. I bought it for $200.00. because of the economy. I ran the wiring to the dome lighting in the rear upper cabinet. on the interior I made a spacer 1 1/2" high. I screwed the outside of the trailer thru the 1/4 " ply ceiling material with 4 stainless screws, because the contact cement was not holding the foam lining and the ply up tight to the fg roof. I used countersunk machine screws, with nuts, a washer, and lock tight. the interior spacer is 3/4" wide and it sits proud of the screw nuts. The spacer was screwed to the plywood ceiling, and then the interior bottom trim was screwed to the spacer. It is all very tight.
Later Kenny
Kenny Strong is offline   Reply With Quote
Old 04-28-2012, 11:19 PM   #2
Trailer: gave up!!
Ummm... You did measure to make sure you can still get it out of the garage now, right?
just kidding! Looks great Kenny.
John_M is offline   Reply With Quote
Old 04-29-2012, 11:47 AM   #3
sparky1's Avatar
Trailer: Casita patriot deluxe (sold)
Virginia
I left the original Vent in the ceiling added a VORTEX upgrade Fan, 12 volt $42.50 from the net (1) speed but you don't have to remove any thing but the hand crank and screen-,no worries about any leaks,12 volts all ready in the ceiling.
sparky1 is offline   Reply With Quote
Old 04-29-2012, 03:29 PM   #4
cpaharley2008's Avatar
Now you need to cover the screw heads with some caulk, other than silicone.
Old 04-30-2012, 11:10 AM   #5
Utah
cover screws
The screws are stainless steel and the caulking under the vent is LEXEL, got the idea to use LEXEL from a post by Norm. "We don't need no stinken" silicone. Would one still want to cover the screw heads?
Old 04-30-2012, 11:48 AM   #6
sparky1's Avatar
Virginia
Most RV dealership Shops use (Dicor) Lap sealant (flo seal) stays plyable and holds a very long time-
sparky1 in S.Va.
Old 04-30-2012, 03:43 PM   #7
It will only help the situation.
tv ceiling mount Carol A. Modifications, Alterations and Updates 19 03-04-2012 06:52 AM
Fan-tastic Fan Seller - Best Price I Found barryra General Chat 1 07-11-2011 04:51 PM
carpet on ceiling Nyle R Problem Solving | Owners Helping Owners 5 04-11-2011 09:05 PM
Burro ceiling Dave Russell Problem Solving | Owners Helping Owners 3 08-04-2010 03:11 PM
Replacing Scamp Ceiling Vent With Fan Parker Buckley Modifications, Alterations and Updates 6 02-29-2008 02:08 PM
