Cell phone booster external antenna - Fiberglass RV
Old 02-03-2015, 08:32 AM   #1
John Linck's Avatar
Madison, Wisconsin
My business requires connectivity, but we like to camp in National Parks with their weak or absent cell signals. I chose to add a Wilson Sleek cell booster to my rig. This is especially necessary in a Scamp with its aluminized bubble wrap insulation that attenuates radio waves. I mounted the Sleek's antenna on the Scamp's roof. The antenna works better with a metal ground plane, like a car roof. Fiberglass will not work. So I made the antenna base of an eight inch square of aluminum with a steel washer glued on for the antenna's magnetic mount. Some tricky angles in the aluminum bends gave it a nearly level position on the double sloping fiberglass. I used 3m tape for mounting and fed the wire thru the roof vent. You can see a 100 watt solar panel in the background.
Haven't tested it yet. Will update this when the results are in.
Happy Trails, john
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is offline   Reply With Quote
Old 02-03-2015, 08:54 AM   #2
Straighttalk.com sells a Home unit that is a cell phone unit that works over the Verizon network and you plug an ordinary home phone to it. It costs $15 a month for unlimited nation wide calling. You can buy it at Walmart or a refurb unit straight from Straighttalk for very little.
This uit would be ideal for camping as you could activate only when camping. It has a battery in it so you could unplug it and take it outside to make a call if you had low coverage inside the camper.
Old 02-03-2015, 09:04 AM   #3
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
For anyone wishing to install an external antenna without the need for a ground plane, the WirEng BoatAnt is a solution.
goTenna... turns your cell phone into a cell-free 2-way text device accrete General Chat 3 09-01-2014 04:08 PM
Cell Phone Booster Jim Bennett Problem Solving | Owners Helping Owners 9 07-10-2013 11:40 AM
Cell Phone and I-net while on the road Weinel, Alan General Chat 28 07-03-2010 07:52 PM
Samsung Turbo 3000 Cell Phone Sharon Herman Jokes, Stories & Tall Tales 3 05-09-2008 10:24 AM
cell phone amplifier & add-on antenna Tom Trostel General Chat 4 01-25-2007 06:11 AM
