07-30-2011, 01:59 PM
Trailer: Uhaul CT-13
Ohio
Cheap 12 volt LEDs
Let's try this again after last nights server issues.
About a month ago I purchased two expensive 12 volt led lights, Revolution 150's, they together cost about $41 with tax, got these at an RV store in NY. I am pleased with them and they seem to be high quality. But they were too darn expensive to invest in all my fixtures, so looking for a cheaper alternative, I took a risk on ebay from a seller in HK. The fixtures I bought below were 1157's, I could not find at the time the similar fixture in 1156, the 1157's have offset prongs but still work in a standard outlet but the 1156 are a better fit. I paid a total of $7.18 shipped and they only took about a week and a half to get here.
1157 link
68 SMD LED 1157 2057 380 Tail Stop P21W bulb WHITE 12V | eBay
1156 link
68 SMD LED 1156 382 Tail Stop P21W BA15S bulb WHITE 12V | eBay
Here is a photo of the $41 Revolution 150 lights
Here is a photo of the cheapos, they give off a bright white light at least as bright as the Revolutions
07-30-2011, 02:41 PM
Trailer: '78 Trillium 4500
Wow!
Do I understand you right- you're just replacing your regular bulbs in the 12v fixture?
And how many did you buy for the $7 plus change? Is that for two bulbs?
Thanks
Francesca
07-30-2011, 05:45 PM
Ohio
Originally Posted by Francesca Knowles
Wow!
Thanks
Francesca
Yes, just replacing the bulbs, and the $7.18 was for two, the seller won't combine shipping but they are still a steal for two bulbs, $1.00 each plus $2.59 shipping each.
07-30-2011, 05:52 PM
Ohio
07-30-2011, 07:08 PM
Trailer: 1991 17 ft Horizon
James, I got some of the same bulbs from what looks like the same seller. I changed all my inside fixtures over to these type of bulbs. I also used some of the ones that are double faced tapped inside the fixture too. Can't beat the price and they ship pretty quick also. Now I will work on changing out my taillights and side markers. I'm thinking about changing the whole fixture on those. Oh I also changed out my outside porch light with one of the bulbs you linked to.
07-30-2011, 08:20 PM
I seen people doing and never asked. Would you mind answering what the reason is for changing taillights and marker lights to LEDs?
07-30-2011, 09:12 PM
When "boondocking" on battery power your lights will stay lit much longer do to the lower power consumption. Also the lower power consumption taxes your converter less and the LED bulbs run cooler and last longer than incandecent bulbs.
07-30-2011, 09:22 PM
I haven't changed out the markers and tail lights, but it's on the "to do" list. My reason... because I can. After seeing the differences between the standard tail lights and markers with regular bulbs and LEDs... what a difference in brightness! And because I can, why not?
I think Bryon has changed everything out on the inside to LEDs or cold cathodes because he boondocks a bunch...
07-30-2011, 09:34 PM
Trailer: Eggcamper
Good question - I added a set of LED tail/brake lights to my regular tail lights because of the following:
1- LEDs are diodes, not bulbs, so they take lots of abuse on rough roads
2- Much longer lifetime, and
3- Safety - the LEDs are 4X brighter than regular bulbs so they can be seen easily in bright sunlight, fog and at night at greater distances.
I really like having all these advantages for vehicles coming at me from the rear or side. Using LEDs in the interior you still get great lighting, but use just a fraction of the battery draw and give off less heat. Hope this helps a bit.
'Do not go where the path may lead, go instead where there is no path and leave a trail.' - - Ralph W Emerson
07-30-2011, 09:41 PM
The taillights and marker lights are NOT powered via the trailer. The power comes from the Tow Vehicle. I agree that interior and porch light, but unless there's some overriding reason I see no need to change taillights and marker lights.
07-30-2011, 09:44 PM
In my humble opinion that's a lot of expense for very little gain. Besides the taillights and side marker lights in tow are most likely NOT LED.
FYI.. Not all diodes are created equal. If they're not ruggedized they won't last as long as incandescent. Look as some of the older truck trailers with dead LEDs.
07-30-2011, 09:48 PM
Everything except taillights, backup lights, and marker lights. There's such a thing as too bright for taillights. So be careful when changing to LEDs some my exceed brightness limits unless they are made specifically for taillights, brake lights, and marker lights. You don't want to blind the driver behind you.
07-30-2011, 09:49 PM
I guess manufacturers of tugs are changing to LEDs because there's very little gain? Check out the new crop of vehicles, most have all gone to LEDs for tail lights. If you don't want to change your trailer to LEDs, then don't. The newer LEDs have a much longer life. I wouldn't compare OLDER truck trailers to anything that's been made in the last couple of years.
I'm looking to change the tail lights and markers to sealed units... waterproof. Since they're manufacturered as tail lights and markers, it's doubtful they'd be too bright for DOT.
07-30-2011, 10:07 PM
Trailer: Eggcamper
Byron -
Is it just me or is it time for you to move to Washington, D.C. and join the Boener team? ...Post a question - get straight answers, reject all constructive comments and conventional wisdom?
Can't speak for everyone, but next time I may hesitate to respond...
BTW - my tail lights are safely bright - not 'too bright' and they are DOT certified.
Happy trails!
07-30-2011, 10:18 PM
woow doggie. I think Byron asked a valid question.. why? All the lenses on my trailer are original and old. His trailer is only five years old and he keeps it spotlessly clean. So do I, but not so the previous owners.... at least not the cloudy lenses. I can, and will, only answer for MYSELF. For somewhere around $50-60 I can change everything on the outside to LEDs. Will that mean my trailer is safer to tow? Maybe not, but I can afford it and want to be seen, especially in that "just before the sun goes down" time. Pitch black, nearly any light is bright... not so late afternoon, early evening. YMMV
07-31-2011, 12:30 AM
The newer vehicles also have electronic circuitry to control brightness according to ambient light. Not quite the same thing as replace incandescent with very bright LEDs.
LEDs have an indefinite theoretic life. With manufacturing flaws they don't achieve that, but the newer one last a very long time. Another reason they're using them in newer vehicles reduces copper usage. They can use smaller wire.
07-31-2011, 12:31 AM
Ohio
My original post had nothing to do with brake lights, I am referring to using them to replace INTERIOR bulbs, i.e. ambient light, the pros are as bright if not brighter than incandescent bulbs, whiter light, longer life, and much lower power consumption. The post I made had nothing to do with brake or turn signal lights although you could replace them as well but I won't do that unless mine start to burn out.
07-31-2011, 12:44 AM
Byron -
Happy trails!
Simple answer it's you...
A bit about my background and a suggestion that you keep negative comments until you have the full story
First.. My question was to Tim as to his reasoning. I got a lot of other responses. I tried to answer each response with factual information.
Second.. My background. Retired Electronic Engineer that spent several years working with automotive electronics and electrical systems. Mainly in the heavy duty trucking. I designed several electrical parts that are now on the road in some trucks. One was an LED readout that had a light detector that dimmed the readout when it got darker. Otherwise it would blind the driver at night.
Your apology is accepted.
07-31-2011, 12:45 AM
Yup, and my question was originally to Tim who said he was replacing exterior lights.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Two 6 volt vs. 12 volt deep cycle
Kevin242 |
Electrical | Charging, Systems, Solar and Generators |
15 |
05-13-2017 09:52 AM |
Installed new LEDs
Raz |
18 |
11-17-2011 09:43 PM |
LEDS lights from Princess Auto
Scott S. |
21 |
06-23-2011 10:57 AM |
Hooking up new LEDs??
Timmy T |
2 |
06-17-2009 10:28 AM |
LEDs
Byron Kinnaman |
14 |
11-13-2007 09:26 PM |
