Cheap flat screen mount - Fiberglass RV
Old 03-10-2012, 03:09 PM   #1
Trailer: 1981 Bigfoot
Im totally buying this for my Bigfoot! Such a great deal! only $8.25.
For only $7.25 each when QTY 50+ purchased - LCD LED Cabinet Mount Bracket (Max 17.6Lbs, 9~17inch) - Black | Ceiling / Under Cabinet Mounts for Flat Panel Displays
Colin77 is offline   Reply With Quote
Old 03-10-2012, 03:42 PM   #2
Ed Harris's Avatar
I use these all the time,they work well but I would only partially buy one if I were you!
Old 03-10-2012, 04:19 PM   #3
Matt in SV's Avatar
Monoprice IS the place to get lots of inexpensive home theater stuff. Big box stores gouge on the basic accessories like cabling, screen and speaker mounts and wiring.
This stuff is all made in China, but paying four or five times as much will only get you a name brand - made in China.
Regards,
Matt
Planning our next Escape!
Old 03-10-2012, 05:19 PM   #4
Greg H's Avatar
Trailer: 72 Boler American
Indiana
That's cool.
Old 03-10-2012, 06:20 PM   #5
Jane P.'s Avatar
Trailer: Bigfoot 19 ft
Colin,
I'd like to install a TV in the cabin of my Bigfoot 19.
What type Bigfoot do you own, where will you be placing the TV?
'92 Bigfoot 19' | '07 Chevy Tahoe
Jane P. is offline   Reply With Quote
Old 03-10-2012, 09:52 PM   #6
Jane,
I have the 17.5 Gaucho layout. I was planning to mount it under the front cabinet in the corner with the lamp. The bracket is cool because you can flip it up out of the way when not in use.
Old 03-10-2012, 10:19 PM   #7
IllAnnoy
That is a real price breakthrough!
Old 03-11-2012, 08:40 AM   #8
Ed Harris's Avatar
Originally Posted by Colin77 View Post
Jane,
Actually the bracket will flip up but I would not trust it to hold a TV flipped up standing still much less on the road.
There is a single Hex bolt that sets the tension of the hinge and it will be inviting trouble to think this one will hold while on the road.
Just speaking from experience with this mount.
Ed
Old 03-11-2012, 03:05 PM   #9
Jane P.'s Avatar
Jane,
I have a gaucho layout as well.
Do you mean the front cabinet corner behind the drivers side/street side?
What lamp?
I am playing with the idea of placing the TV at the foot of the gaucho couch between the door and couch. In my 19' trailer there is a upper and lower cabinet between the door and the couch. I was thinking of mounting the TV to the upper cabinet. I was looking at mounts that would allow me to swivel the TV 180 degrees so that we can view it from the front dinette or while in bed.
Mounted into the double cabinet "wall" is a TV outlet for the roof antenna plus power outlets. I'd have to find "just the right" size & weight TV for that spot. Plus a mount that would swivel in a 180 degree ark. I would have to find an appropriate spot for a DVD unit near the TV (they don't seem to integrate DVDs into TVs anymore).
My other option is to mount it under the front, street side cabinet corner. But it would be far away from the antenna outlet, and everyone would have to sit on the curve side of the dinette.
Old 03-11-2012, 03:08 PM   #10
Jane P.'s Avatar
Ed
Most of the threads I have read regarding traveling with a TV suggest taking the TV off the mount and stowing it where it would be safe while on the road.
Old 03-11-2012, 03:48 PM   #11
Ed Harris's Avatar
Thats not what I am suggesting at all.
I am saying that this mount is not capable of holding a TV in the flipped up position really at any time.
I have no problem with it holding the TV in the air when flipped down in viewing position I just would leave it like that all the time and not swing it up and expect it to stay there.
The tension adjustment on it is too crude to really work to keep it up and still be able to swing it down when needed.
It is just fine if adjusted for the down position and left that way though.
All of that of course depends on how well the mount is fastened to the shelf in the first place?
I have never taken a TV down for the road in 6 different trailers now and I have never felt like I should have.
Just too much work for little reason.
I also do not like the DVD built into the TV. When it dies then you have a deeper TV for no reason and will still have to find a way to connect an external player anyway.
Also the all in one units are typically the less nice units too.
Old 03-11-2012, 05:31 PM   #12
Trailer: Uhaul CT-13
Ohio
The mount for my 21" was only like $20 on Samsclub.com. It works perfect for my mounting location on the bed side of the cabinet in my Uhaul.
Panoz77 is offline   Reply With Quote
Old 03-12-2012, 05:09 AM   #13
RE: Flat Screen Mounts
IMHO.... That looks a little on the light side for trailer use. Remember, except for those of us in California, most walls that TV's are attached to stay in one place, the one in a trailer is bouncing (Hard bouncing in most) all of the time. Unless you want to take it off the mount when travelling, I would use a rule of thumb of having a mount with a weight capacity of at least 4 times the weight of the TV.
Here is one I have used at least 8 of for home use and motorhome applications and am also going to use in both my Casita and Hunter-II. It's just a few $$$, and real cheap compared to a broken flat screen.
MyCableMart.com
They also have others on the site. I have been very happy with this company in the past.
Old 03-12-2012, 06:35 AM   #14
Ed Harris's Avatar
Bob
As long as the mount is thru-bolted to a shelf it should be OK for mobile use.
I will say that I mainly use it to hang 4lb TV's in Bathrooms and Kitchens but I have also used it for much heavier sets too.
I even use that mount in my digital Photo Booths which are moved around and banged around in my truck all the time and they are solid mounting heavy touchscreen controllers as well. Then at an event they survive hundreds of screaming children poking at the screen all night long without the monitor moving at all.
I did an event Friday night for 400 screaming monsters and parents and had coffee spilled on me,lightstands knocked over and the printer mauled while they tried to pull the photos out all night long and the Touchscreen didn't budge at all.
If they can stand up to that........
flat screen tv's Laura June General Chat 47 03-07-2012 09:07 AM
Where to mount a bracket to a flat TV screen Cyndi B. Modifications, Alterations and Updates 6 02-09-2012 06:57 AM
Installing a flat screen TV - how to get wiring to it? Carol H Electrical | Charging, Systems, Solar and Generators 23 06-20-2011 02:58 PM
Flat Panel TV Mount Install efawcett Modifications, Alterations and Updates 10 07-23-2009 04:59 PM
Mounting a flat screen tv in a Burro JMS Problem Solving | Owners Helping Owners 7 04-05-2009 07:35 AM
