Cheap interior light LED mod. - Page 2 - Fiberglass RV
Old 09-28-2015, 05:57 AM   #15
Night Sailor's Avatar
Connecticut
I use these for cabinet lights controlled through magnetic door switches. I originally used tape to hold on the switches and one fell off leaving the light on for a day or more. The double stick failed from the heat. I've since drill small holes and screwed on the magnetic switches.
I also have four of these in my bathroom replacing incandescent lamps there. I use it so briefly there are no issues.
I've replaced the fixture type lamps with LEDs with bayonet type LEDs. These are pricey but reliable. Available in warm and cold versions. The cold ones are very bright and some people find the light objectionable. I don't mind them. I use the Warmer colors for reading lamps and above the galley area.
I have left one of my outdoor lamps on for weeks with no issues.
Old 09-28-2015, 05:47 PM   #16
Trailer: scamp
After I replaced my lights with leds in my scamp 16, I had an issue with the crosshatching on the inside of the light dome. The crosshatching had changed the light pattern, giving off bands of lighter and darker light. I thought of lightly sanding the inside, but ended up coating the inside of the dome with a light layer of white glue. When the glue dried, it left a nice thin "frosted" coating that got rid of the light patterns.
redwings fan is offline   Reply With Quote
Old 09-29-2015, 05:24 AM   #17
Trailer: 1999 Casita 17' SD
Ohio
Colinn.
The light bulb just came on
The area of your fixtures where the panels go is flat
Mine are curved making the contact surface much less.Maybe that's why the two strips along the sides is working??
Joe
Old 09-29-2015, 07:55 AM   #18
colinn's Avatar
Trailer: Trillium 13 ft
hi joe
That makes sense. Maybe you will get better venting having a curved back to stick to.
colinn is offline   Reply With Quote
light
LED Interior ceiling light FTTRV Commercial Posts and Products 0 11-24-2014 07:02 PM
$4 LED Interior Light Thomas G. Modifications, Alterations and Updates 4 05-23-2012 07:02 PM
LED interior light bulb replacement Larry Singer Modifications, Alterations and Updates 10 03-11-2012 05:37 PM
LED interior emergency light don bowman General Chat 2 05-22-2007 11:45 AM
New Interior lighting led light strips jimtesla Modifications, Alterations and Updates 2 09-15-2006 08:42 AM
