Cheap solar on a LiteHouse - Fiberglass RV
Old 06-27-2018, 10:26 AM   #1
Davie B's Avatar
Trailer: Lite House
This is a work in progress. The roof of the trailer has a center stiffener that limits the width available to install a solar panel. A 21” just won’t fit. What does fit are the inexpensive Harbor Freight solar panels. I know that they are suboptimal compared to the newer panels, but they fit.
I bought the 45 watt set when our power was out at home for several weeks after a hurricane. They work good enough to charge the battery. I’m thinking of upgrading to the 100 watt system (same panel form factor) if we keep the trailer (lusting for a slightly larger one with a shower and toilet).
My mounting system was quick and dirty. It involves 12 holes in the roof. We were about to leave on an extended trip time was limited. I plan to redo the mount, and glass over the holes.
Davie B is offline   Reply With Quote
Old 06-27-2018, 10:30 AM   #2
Davie B's Avatar
Trailer: Lite House
The left battery box holds the solar controller and some related parts. The right box contains a standard SLA marine battery.
I use a standard waterproof 12 v connector between the battery and the controller. When we’re connected to shore power, I unplug the solar and plug a charger into the battery.
Old 06-27-2018, 10:31 AM   #3
Davie B's Avatar
Trailer: Lite House
As per usual, please disregard the #testdirt.
Old 07-15-2018, 08:51 PM   #4
Markz's Avatar
We used an SAE roof connector on the side of our tongue box. I suggest looking for one with 10 gauge wires though I can't find the name of the company we used. They are harder to find then the 12 ga wired units. We also purchased a few double sided SAE wires to make adapters and cable ends out of. Each double sided wire makes two ends. Stick with 10 gauge wire for best performance. Click image for larger version
ID:	122003Click image for larger version
Markz is offline   Reply With Quote
Old 07-15-2018, 08:53 PM   #5
Markz's Avatar
Sorry, not sure why the app is posting my pictures twice tonight.
Old 07-15-2018, 09:19 PM   #6
Davie B's Avatar
Trailer: Lite House
That's awesome. I'm off to research 10 amp SAE connectors.
Old 07-17-2018, 01:20 PM   #7
Trailer: Scamp 13
Look for Boat trolling motor plugs and outlets.
https://www.basspro.com/shop/en/bass...or-receptacles
Old 07-17-2018, 01:32 PM   #8
mszabo's Avatar
Trailer: U-Haul VT16
https://www.ebay.com/itm/Pactrade-Ma...72.m2749.l2649
solar
Need ideas for cheap cheap cheap! Glasswheels General Chat 33 11-02-2016 06:10 PM
LiteHouse for Two Kevin K General Chat 2 04-20-2014 07:53 PM
LiteHouse side windows. Davie B Problem Solving | Owners Helping Owners 6 03-15-2012 06:13 PM
LiteHouse trailer manual -- help Legacy Posts Problem Solving | Owners Helping Owners 46 05-26-2007 07:56 AM
