Check this out NOT Poliglow...Time will tell.. - Page 2 - Fiberglass RV
Old 08-23-2010, 01:59 PM   #21
Trailer: 1976 Boler 13 ft
Where do you buy redmax?
cyndi H is offline   Reply With Quote
Old 08-23-2010, 02:27 PM   #22
Bud Kennedy's Avatar
Trailer: 1984 U-Haul / 02 Mazda pick up
It's called Redmax pro and we got it at Lowes for about $15 for a gallon.
A gallon would probably be enough to last for a century or so.
Bud Kennedy is offline   Reply With Quote
Old 08-23-2010, 02:33 PM   #23
Thanks. we dont have lowes here but i'll look around. so far the best ive used is the mothers wax. thx
Old 08-23-2010, 06:55 PM   #24
Mark G.'s Avatar
Trailer: 16 ft Scamp
This stuff is nothing like a wax. You don't wipe it off. I used a micro-fiber towel, wetted then thoroughly wrung out.
Apply to the applicator, evenly wipe the stuff on the trailer and let it dry (drying time is very short). Reapply until you reach the desired gloss and coverage.
Mark G. is offline   Reply With Quote
Old 08-23-2010, 07:49 PM   #25
Mark Shaffer's Avatar
Trailer: 2008 Scamp 16 ft Custom Deluxe Deluxe Side Dinette
Mark, when you say wet and wrung out, do you mean wet with water or wet with the redmax?
Mark Shaffer is offline   Reply With Quote
Old 08-23-2010, 08:18 PM   #26
Mark G.'s Avatar
With water…… Then I wring out all the water that I can (This was only done once at the beginning, it softness the towel), apply RedMax Pro to the towel and spread over the trailer.
I found that this gives the best results (for me anyway).
DO NOT apply RedMax Pro directly to the trailed then attempt to spread (I did this in one small section). The result being….. Clear runs. This was a bit of a pain to correct.
I transferred the RedMax to a standard dish soap bottle and squirted some on the towel as needed (more convenient than dealing with a gallon bottle).
Old 08-23-2010, 08:23 PM   #27
Rick Brown's Avatar
Trailer: Compact Jr
Make sure the trailer is clean or you will trap the dirt!!!!!!!
Rick Brown is offline   Reply With Quote
Old 08-23-2010, 08:35 PM   #28
Thanks everyone for the input. i just washed the bugs off tonight so i will look around for it.
Old 08-25-2010, 10:05 AM   #29
Trailer: One 13 ft Scamp and One 13 ft Trillium and Two Trillium 4500
For a update on mine, they still look as good as they did on the first day I got done with them..One good note I went on a fishing/camping trip had to go down a muddy road and got mud all over the camper and it dried on hard, when I got home I sprayed it down with a hose to get most of the mud off then was going to carry it to a car wash...But after spraying it with the hose everything came right off like it was covered in teflon or something, nothing seams to stick to it very well even bird dropping come right off with no scrubbing what so ever..I now have 4 Trilliums (3) 4500 and (1)1300 3 of them has the Floor Finish on them and 1 has the poliglow the one with the floor finish shines the best by far...............
Randy Bishop is offline   Reply With Quote
Old 08-25-2010, 10:20 AM   #30
I am intrigued and debating whether to do the poliglow or redmax. The question is seeing as my trailer is yellow will yellowing really matter? lol
Old 08-25-2010, 10:25 AM   #31
I wouldn't think there would be a yellowing problem, the one that I done back in early spring has set in the hot sun here in Alabama all summer long and in the past month we have had several days with it over a 100 and it sets out there on a concrete slab so I know it has to be even hotter there... The last camper I done was 3 weeks ago and setting beside the other one I can't see any yellowing at all...Hope this helps.....RANDY
Old 08-25-2010, 10:50 AM   #32
Cyndi B.'s Avatar
Trailer: 2010 Scamp 5th Wheel/2019 Toyota Tundra
Iowa
Will this help bug stuff and tree sap come off easier? Our 5th wheel is extra high because of the Tundra so cleaning the top often is a problem for the one cleaning it.
Cyndi B. is offline   Reply With Quote
Old 08-25-2010, 11:58 AM   #33
With the experience I've had with the product I would say YES it would make it alot easier to clean the top.......
Old 08-25-2010, 02:46 PM   #34
Trailer: 2005 13 ft Trillium Outback
Question: I just went to Lowe's and found two Red Max floor finish products. One is what I'll call regular and the other is stain resistant. The text on the regular says it will provide a high gloss finish. The text on the stain resistant just says it will enhance the gloss of the flooring while protecting it from stains.
I'm guessing the regular product is the one everyone one is using.
Is that correct?
2005 Trillium Outback w/ 30" tongue extension
1989 Award 730, 30'
2003 PT Cruiser
1998 K2500 Chevy Silverado 6.5 Turbo Diesel, 4X4, ext cab, short bed
Curtis F. is offline   Reply With Quote
Old 08-25-2010, 05:52 PM   #35
Mark G.'s Avatar
You need the one with item number 216595 on the upper right of the front label.
Click on the pic of the bottle in the first post, that is the one you want.
Old 08-26-2010, 12:46 AM   #36
Trailer: Uhaul CT-13
Ohio
I read this post and followed your lead, I am extremely impressed with the quality, look and duribility of Red Max Pro. FYI, it doesn't come off with either mineral spirits or 90% isopropyl alcohol, I need to touch up a few drip areas and I think I may have to buy the Red Max floor stipper to get it off and touch up the areas.
Panoz77 is offline   Reply With Quote
Old 08-26-2010, 09:48 AM   #37
Mark G.'s Avatar
Letting it run can be a huge pain. I leveled my runs with light sand paper on a sanding block then recoated the area.
If you try out the stripper please post your results. Ammonia was mentioned for removal but I have not tested it.
Old 08-26-2010, 11:09 AM   #38
Sandra L's Avatar
Trailer: 2009 Escape ('Suite Escape')
Smile
I'm going to keep an eye on this thread! We have lots of hot sun here too!
Sandra L is offline   Reply With Quote
Old 08-26-2010, 05:26 PM   #39
Matt in SV's Avatar
Trailer: U-Haul VT16
I bought the stuff but have not applied it yet. Any tips for cleaning and application? I was thinking about one using one of those narrow 6" rollers, but not sure if a rag or foam tip would work. Sometimes they want to skid rather than roll.
Does it go on like paint? Does it have any gap filling quality? I am kind of wondering if I should try and scrape the dirt/discoloration out of some of the spider cracks.
Regards,
Matt
Planning our next Escape!
Old 08-26-2010, 06:12 PM   #40
Ohio
It is much thinner than paint, more like water, I wouldn't use a paint roller. Use a sponge or lint free rag.
poliglow
check out Emmitt G. Classified Archives 1 03-09-2010 02:33 PM
Check this out Kevin K General Chat 4 06-13-2009 10:30 AM
Check this out Kevin K General Chat 5 02-02-2009 11:07 AM
Hey Web Guy Check this out ! Glen G General Chat 12 02-20-2008 02:06 PM
